Question about Dryers
Cabrio electric dryer not working properly
Hi. my dryer turns on and spins but my clothes do not dry. can you tell me what the problem might be?
    Genius:
  • 1,028 Answers
If dryer is heating ckd vent system to outside must have good air flow to remove moisture away from clothes..if not heating suspect low ,voltage to dryer motor runs on 110 volts but must have 220 to heat..also possible thermal fuse on element or control bd bad
Posted on Jun 01, 2008
My cabrio dryer wed7600xwo is no longer drying right, I have to run loads 3 times to get them dry. What could the problem be?
This dryer has 2 belts. A smaller belt operates the blower. The nut tends to back out and the small belt falls off. Here is the result:
Bravos dryer innards of a failed blower belt
Look around on my foggy site for your service manual. Let me know
Feb 22, 2013 | Whirlpool Cabrio WED7600XW Electric Dryer
My dryer dont heat up to dry cloths
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 02, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
WGD5530SQO WONT DRY CLOTHES BUT TURNS ON SPINS N DOES NOT WARM UP N GAS LINE FLOWS
heatman101
Jul 25, 2011 | Whirlpool WGD5900S Gas Dryer
My drying is running and spinning properly but no heat is coming out to dry the clothes, any ideas?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 09, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
When I put the dryer on it does not dry the cloths are still wet. and where it says how much more time is left to dry it is blinking AF what does this mean. I dont know where the book is could you help...
heatman101
Jan 15, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
On the screen of my dryer where it tells me how long I have till the cloths are dry keeps flashing AF and it takes me all day to dry one load of cloths.
The AF stands for Low airflow condition. We had it too. Check the lint trap first as it is the easiest. Then check the dryer hose ductwork make sure its not crushed or blocked. You may need to clean the line from the outside too.
Dec 30, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Suddenly drier spins ans work as usual but does not heat up. therefore, clothes are not dried even after three hours of spin.
heatman101
Aug 29, 2010 | EuroTech EDC158 Electric Dryer
Dryer won't shut off automatically
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Thank you!
May 09, 2010 | Maytag MED5800TW Electric Dryer
Why is the dryer not turning off
Hi, If your dryer seems to run forever and doesnt turn off, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Apr 15, 2010 | Roper REX4634KQ Electric Dryer
Dryers Logo
83 people viewed this question
Top Dryers Experts
