Question about Grundig Televison & Video
How can i connect ypbpr cables to my grundig vision 26 lxw 68-8510 top television set?
3 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: My grundig lcd vision32lxw82-8510 has sound but no
If the screen goes completely black but still have sound then the backlight inverter board may be going out.
Posted on Oct 31, 2009
Testimonial: "Thanks very much budmrtn I'll look into it "
  • 1738 Answers
SOURCE: lcd problem
Unplugging the television for about fifteen minutes or so, then plugging it in again.
Posted on Dec 26, 2009
Ypbpr no signal
Did you make sure you hooked a yellow end cable to the right jack as that is the one that controls the settings the others control the color and definition abilities
Jun 03, 2014 | Sanyo DP37647 37 in. LCD TV
Tv pin code
tray -oooo- or 1000 or 1111 if not tray 8500 this is the service cod
Nov 25, 2013 | Televison & Video
Grundig Lenaro tv: White line appearing on the screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 16, 2017 | Televison & Video
Lcd problem
Dec 26, 2009 | Grundig GU19WDT 19 in. LCD TV
How do you connect a Sansui STB-HD01 (set top box) to an LCD tv?
Hi trishallan! I will be more than glad to assist you in this concern.. On the back of your Sansui STB-HD01 (Set top box) there is an input name - ANT In- Attached an external antenna to this terminal. If your LCD TV is an HDTV you can use the HD-YPbPr (you will see there Red, Green, Blue) on the back of the Sansui-STB-HD01, The cable that your going to use is the component cable - the color is Red, Green, Blue) - connect the 1st end to the back of the sansui-set top box and the other end is going to your LCD-TV. If your LCD TV is not and HDTV you cand use the other terminal which is on the right side of the HD-YPbPr, the SD-YPbPr, you can use the same cable - the Red, Green, Blue, .. then there is s display switch-Set this switch in conjunction with MODE switch according to your TV display capability.and there is a mode select- Set this switch in conjunction with DISPLAY switch according to your TV display capability, then u need to tune in the tv to compionent channel, use the LCDtv remote to cycle the input of your tv.
if you have any query please feel free to get in touch..
Aug 28, 2009 | Televison & Video
Grundig Vision 26 has vertical fussy lines taking up 1/4 screen
LCD panel faulty.You can try to resolder the LVDS panel and place a cooling block on the flatpack IC.
Jul 22, 2009 | Televison & Video
DVD picture is in Black & White only.
Are you trying to play an NTSC disc in a PAL player, If so,your player has a switch or
on-screen setting to select the output format for NTSC discs,
Or maybe you have connected one of the component outputs (Y, R-Y, or B-Y) of
your DVD player to the composite input of your TV.
Please rate this solution
Jan 20, 2009 | Toshiba 26AV500U 26 in. LCD HDTV
Televison & Video Logo
127 people viewed this question
Top Grundig Televison & Video Experts
Henry  Thomas
Henry Thomas
Raj Patel
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
