Question about Konica Minolta Magicolor 2530 DL Laser Printer
Fatla error code 16H
Fatal error code 16 H
  • 300 Answers
It relates to the transfer belt unit, replace it
Posted on Jun 13, 2008
How do I fix Fatal Error Fatal Codes:0X50 for Epson WF-2530
there is a driver update to this on there website.. http://2682220.r.msn.com/?ld=d3r7GeHDlTJrBUpqiKpMxT4jVUCUxr5V_qRawzP5W1kwg55cbcz5eg53VjPRThl_AClX5g-BdWf6mHDw2SlSJsTLfN9nJeK4phMY0-ErdgNCyKWWQgEXUUIi9nCuedGmcy6X7gtUKmemkIwZMZZFqFwJ3TIWhMol4QEau4TTcG8TFQ8ApN&u=https%3a%2f%2fwww.pcsupport4me.com%2fprinter-tech-support%2f
Nov 11, 2014 | Epson WorkForce WF-2530
How to clear error service call (16H)
Take belt out did you remove all the tape that KMBS applied. check the inst again. also reseat the belt properly.
May 13, 2014 | Konica Minolta magicolor 2500W Laser...
Fatal code 0x50
Hi, Hope this helps,I downloaded & manually Translated it from a Russian Website (I speak Fluent Russian)!!
fatal error code 10x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 20xF1 PF PID excess load error. Possible causes : PF Motor failure, PF drive mechanism overload (paper jam, foreign object, insufficient grease, deformation of the Main Frame), Tooth skip of the PF Timing Belt, Improper tension of the PF Timing Belt, Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 30x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 40x0A CR load position excess load error. Possible causes : CR Motor failure, CR Unit drive mechanism overload (paper jam, foreign object, Change Lever failure), Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 50x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Oct 10, 2010 | Epson PictureMate 500 InkJet Photo Printer
Fatal error code: 16H
The Belt Positioning Sensor does not detect the Transfer
Belt position detection hole a second time even after
the lapse of a predetermined period of time after it has
detected one while the Transfer Belt is rotated.
Oct 04, 2010 | Konica Minolta magicolor 2430 DL Laser...
Errors after building
ok DIALOGSET is referenced in your code but where is it declared , or defined, could be a class or structure etc.
May 30, 2009 | Compaq Digital Visual Fortran Standard...
My split system is not working. I made a check with remote control and it give me code 16h. Someone tell me it is the outside board. I check it out and find that the compressor has some oil around. I want...
I thort that 16h was just the timer on split system airconditioners. meaning 16 hours till it will turn on.
If you have any questions please dont hesitate to ask
Dec 04, 2008 | Heating & Cooling
Fatal Error Code 16H
Hi, pretty sure its the transfer belt not able to turn, remove it and make sure there is nothing blocking it, maybe a paper jam
Aug 05, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Fatal error Code 16H
Jun 04, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Minolta magicolor 2300
16H means, that the transfer belt does not rotate correctly, open all covers, remove any paper, whats stack inside, remove waste toner box, drum unit then open 2 nipple screws and pull out the transfer pelt, if the belt looks ok, reinstall everything and power on again. if works, then everything is ok, if not, then there is something wrong with TBU or TBU
Nov 14, 2007 | Minolta magicolor 2300W Laser Printer
Konica Minolta Magicolor 2530 DL Laser Printer Logo
212 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
