Hampton Bay window A/C compressor runs when unit is turned off.
We have a Model HBLG1400E window unit A/C and it continues to run even when the power switch is turned off. From the sound and due to the fact that there is no air blowing, I assume it is the compressor that is continuing to run. It does turn off if I unplug it but immediately starts again (even though all lights and fan are off) when plugged back in. Weeks ago this happened and we left it off for a day and it started working normally again. Leaving it off for a few hours is not sufficient though.
Thanks in advance for any help you can give me about this.
  • Anonymous Sep 01, 2008
    Mine does the same thing. Is it really difficult to find and replace the contacts/relay??
    Problem Solver:
  • 7 Answers
I have the some problem with a frigidaire model number FAM157S1A. going to try to fix it. will post findings later. pretty sure its a relay problem.
Posted on Sep 13, 2009
I took the unit apart and found several relays in a slide-out section behind the controls. My guess is that the compressor is controlled by one of these relays and that the contacts may have fused together or may have gotten something on them (e.g. water) which caused a low enough resistance to fool another relay further in the chain. They were soldered in though, so it would not have been easy to test for which one was the culprit. It's not a very safe design. I decided to replace the A/C rather than attempt to find which relay was bad.
Posted on Jun 24, 2008
Mine does the same exact thing? Sounds faulty?
Posted on Jun 23, 2008
I have a Hampton Bay air conditioner model # HBLG 1800H. The unit is about 4 years old now. Here lately when I turn the unit on low cool it starts cooling the room and then the compressor shuts off which I...
Sounds like a bad thermal overload which opens when the compresssor gets too hot. After the compressor cools down it closes and does not re-open unyil the compressor gets hot again. Check your wiring diagram if you have one and look for a symbol like two question marks on top of one another or the letters O/L. That seems to be what is occurring here.
If this helps you please rate me on fixya.com
Aug 03, 2011 | Hampton Bay Heating & Cooling
My hampton bay air conditioner has started leaking badly after running it lfor a few hours, from the front right side
For window mount units, the unit must slope towards the outside. Water is a normal byproduct of refrigeration, like condensation on a glass of ice water.... Volume of water is not an issue, water dripping inside is. All water is intended to go outside, via unit slope.
Jun 28, 2011 | Hampton Bay Heating & Cooling
I have a window air conditioner Hampton Bay the window only opens to the side and the unit is to wide can i put it on its sideways? Will the conditioner run and be ok like this?
No,it will not,the ac compressor has to be setting the correct way,and the ac line on top of the compressor has to drip,to help cool the compressor,you will have to make the window wider to use this unit,if this was at all helpful,please rate,and thank you.
Jul 03, 2010 | Heating & Cooling
Hampton bay fan model 761 567 running faster on
Your issue is most likely a faulty speed control. The part is integral to the remote receiver in the fan housing. You can purchase spare parts for this fan through Home Depot (Hampton Bay) Service at 800-654-0688.
The receiver is located in the upper portion of the housing for the fan motor. Look for a semi-circular black control box (usually manufactured by Rhine)
Jun 05, 2010 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Coil freezes up. is there away to recharge window unit. The unit is heat and ac the unit is a hampton bay Is there a manual that can be down loaded?
Check your filters first and make sure the fan is running. These will cause it to freeze up also. A window unit can be recharged, but depending on what has to be done it can cost as much as a new unit. Check around for prices on service calls.
May 10, 2010 | Hampton Bay Heating & Cooling
Hampton Bay Ceiling Fan - remote problem
Hello Espanbauer,
KEEP in mind it could be the receiver also
(cheapest & best first guess is the REMOTE).
I get all my REMOTES from eBay...
(Although AMAZON does sell these)
Believe it or not if they are advertised as GENUINE & new
and come from ESTABLISHED sellers... You are well
protected by both eBay & PayPal
ALWAYS pay close attention to SHIPPING COSTS
LOOK here:
Genuine Hampton Bay Ceiling Fan Remote Control UC7078T with Up Down Light...
InTHIS price range
Hope this helps
Carnac the Magnificent
Sep 20, 2017 | Hampton Bay Dryers
RUNS BUT DOES NOT COOL TOO WELL.
if the compressor runs for a short time only it could be overheating due to a lack of refrigerant i would suggest finding a contractor who specializes in hampton bay to take a look at it
Jul 29, 2009 | Hampton Bay HBLG5004 Air Conditioner
Blown capacitor on 4 year old ac hampton bay is
Not common, keep in mind compositor work almost like a fuse but restrict certain amount of voltage to flow through, power surge or unit overload from AC compressor kicking on and off can cause the resistor to fail; its parts of electronics working. My AC unit trip my main fuse box once in the great while, nothing surprises me when it come to electronics.
Jul 16, 2009 | Hampton Bay Heating & Cooling
Hampton Bay Dehumidifier Model# HB50
MY dehumidifier leaks water from upper part of unit causing water to leak on floor while running.
Feb 23, 2009 | Dehumidifiers
Heating & Cooling Logo
203 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
