Question about Zojirushi NYC-36 20-Cup Rice Cooker
Why does my rice sometimes does not get cooked all the way?
2 Suggested Answers
  • 86 Answers
SOURCE: how do you cook light brown rice in the zojirushi rice maker
Hi! Thanks for using FixYa - here's the instruction manual:
http://www.zojirushi.com/servicesupport/manuals/manual_pdf/ns_pc.pdf
And here's your recipe guide too!
http://www.zojirushi.com/servicesupport/manuals/manual_pdf/nsxac05_xbc05_recipe.pdf
Please take a minute to rate my solution!
Gregg
Posted on Mar 27, 2009
How much water to one half cup of jasmine rice
Hello, Steve -
If you are cooking the jasmine rice the traditional way on a stove, the ratio of rice to water is:
3/4 cups of water to 1/2 cup of rice (per most instructions on packages); for softer rice, add just a little bit more water, plus it is recommended to rinse the rice and drain it prior to cooking
See:
https://www.onceuponachef.com/recipes/perfect-jasmine-rice.html
If you are using an electric rice cooker, the rice to water ration is:
1/2 cup of rice to 1/2 cup of water; rinse and drain the rice prior to cooking
See:
https://www.wikihow.com/Make-Jasmine-Rice-in-a-Rice-Cooker
Best wishes.
May 01, 2018 | Cooking
Tip
Rice cooking
This morning I have encountered a great many questions on rice cookers, so I remembered the time when I had one and why I started cooking rice again.
The rice was beautifully cooked in the cooker, but it took up too much space on my kitchen bench. So I turned to pots and the micro.
Cooking rice in a microwave
  • take 1cup water
  • 2 cups rice
  • a pinch of salt
  • put the water, salt and rice together in a bowl with a lid
  • blend well
  • put the lid on the bowl
  • put the bowl into the micro
  • on the micro, keep full force and set the timer on five minutes
  • start the cooking
  • after five minutes open the micro, open the bowl and stir the rice with a fork.put the lid on again keep the micro going for another 10 minutes.
  • repeat the stirring prosess, until the rice is nice and fluffy andready to serve.
Cooking rice in a pot with a lid.
  • take 1cup water
  • 2cups of rice
  • pinch of salt
  • put the ingridience in a pot, and an oven safe pan
  • in the pot, now with a tight lid. Put on a cooker on highest temperature for five minutes.
  • open the pot, stir the rice with a fork.
  • lower heat and cook for another 15-20 minutes,, stirring occasionally.
  • the rice is cooked when fluffy.
Cooking rice in a pan in the oven
  • Put the temperature in the oven on 150 degrees Celsius
  • put the ingridience as in the recipe above in a pot and start boiling
  • remove from pot into a ovesafe bowl or pan
  • Cover bowl/pan and cook further for another. 20 minutes.
on Aug 12, 2015 | Miscellaneous
What is the rice to water ratio for cooking rice in the rice cooker?
Here's a simple one page guide for cooking rice in a rice cooker. It will tell you how much water to add depending on the type of rice you're cooking - How to cook rice in a rice cooker
Sep 17, 2011 | Hitachi RD5086P 8.3-Cup Rice Cooker
Was using rice cooked for sometime. My cooker is not starting to cook whne I press cook button. That is there is no blip and light above cook is not coming. Whereas when I press on warm button, warm button...
In the top cover of your rice cooker there is a sensor that controls the cooking circuit. Most of the t\ime what happens is the wire in the hinge area breaks due to the opening and closing of the lid. I even had to repair my own rice cooker by cutting away the damaged wire then soldering a longer new wire in BOTH wires. I also added shrink tubing over the 4 connections on 2 wires.
Jan 09, 2010 | Aroma ARC-838TC 20-Cup Rice Cooker
Manual
Here are the instructions that came with the cooker:
Cooking times may vary due to variations in microwave ovens. Adjust cooking times for best results in your oven.
To Cook Rice:
1. Remove basket.
2. Pour 1 cup of uncooked rice into the bottom of the basket, rinse rice thoroughly with cold water.
3. Transfer the rinsed rice from the basket to the bottom of the cooker.
4. Add 1 1/2 cups of water and 1 tsp salt (salt is optional).
5. Secure lid and lock clamps. Open vent holes.
6. Microwave on medium setting (50%) for 10 - 12 minutes (white rice) or 18-20 (brown rice).
7. Remove from microwave, close vent holes and let stand with the lid fastened for 4-5 minutes (the steam continues to cook the rice.)
8. Remove rice from the cooker and fluff with a fork.
Yields: 3 cups of cooked rice or 4 to 6 servings.
Cooking Potatoes and Vegetables:
1. Insert Basket.
2. Pour one cup of water plus 1/4 tsp. salt into the bottom of the cooker.
3. Peel vegetables (if desired), cut into evenly sized pieces and place inside basket.
4. Secure lid and lock clamps. Close vent holes.
5. Microwave on high for 3-4 minutes.
6. Remove from microwave and let stand with lid fastened for 3-4 minutes (the steam continues to cook the vegetables.)
Cooking Pasta:
1. Remove basket and lid (lid not used initially for preparing pasta inside the microwave).
2. Pour 2 cups (5 oz.) of uncooked noodles into the bottom of the cooker.
3. Add 2 1/2 cups water.
4. Microwave on high setting 10 minutes, stirring after 5 minutes.
5. Remove from microwave, stir noodles, secure lid and lock clamps. Close vent holes. Let stand for 3-4 minutes.
Sep 01, 2008 | Nordic Ware 64000 8-Cup Rice Cooker
Rice cooking
if that rice when cooked is too soft or too hard.. then , you might want to add more water to it. the correct ratio for cooking rice is always 1 cup rice and 1 cup water. it also depends on what type of rice your cooking though, some type of rice become too mushy when too much water is added... so always have some minimal water to the uncooked rice.
May 15, 2008 | Continental Manufacturing Company CE23201...
Rice
hi!
i love eating rice.
when you want to cook rice in a rice cooker, the ratio is 1:1.
1 cup of uncooked rice is to 1 cup water.
just be sure you use the same cup.
hope you will have a delicious rice meal!
Jan 16, 2008 | Town Food Service 57155 55-Cup Rice Cooker
How do I cook brown rice?
yup! there is a different ratio for brown rice.
1 cup brown rice = 2 cups water
hope this helps
Jan 01, 2008 | Continental Manufacturing Company CE23201...
Sticking of cooked rice inside pan
Buy a rice cooker with non-stick inner pot.
Dec 04, 2006 | Panasonic SR-3NA 1.5-Cup Rice Cooker
Zojirushi NYC-36 20-Cup Rice Cooker Logo
55 people viewed this question
Top Zojirushi Kitchen Appliances - Others Experts
30yrmech
Level 1 Expert
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
