Question about Maytag Neptune MDG5500AW Gas Dryer
Maytag mgd3500bww i changed out the ignitor and it still is not heating and the coil is not glowing either
  • Maytag Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 17, 2010
Whrilpool dryer not heating up
MDG6400AW Gas Dryer: If you hear the click then the fuse is not blown. The ignitor is being powered up along with the sensor and coils. If the ignitor is not glowing then it must be bad. If it is glowing and shutting down then the sensor is doing its job. that leaves only them pesky coils. They are intermittent before they finally croak which means they heat a little then get hot and quit.
HOW THEY WORK
Slopefront service manual
Jul 23, 2012 | Maytag Atlantis MDG6400AW Gas Dryer
First cycle dryer will fire as normal. each time after it will not light. glow plug is working but no gas allowed to turn on. i'm feeling it may need coils for gas valve?
I would change the ignitor first...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Jan 16, 2011 | Maytag Neptune MDG5500AW Gas Dryer
May Tag Gas Dryer Model MDG3000AWW - Dry works but no heat, more dry/ less dry lights flashing. Whats wrong? How do I get heat again?
it is either your glow coil or it is your ignitor
open the door and remove the four screws
take the front panel off.
leave the door attached so you can test the dryer
be very careful not to touch any wires while you are doing this
now close the door and turn the dryer on
does the ignitor turn on?
if yes that is good
does the ignitor glow and no flame?
sometimes it will take a minute to show it's problem
if the ignitor glows and no flame replace your ignitor coils
make sure to turn the power off when replaceing the coils
Aug 24, 2010 | Maytag Dryers
Maytag model # DG313 wont heat, coil glows but no gas
change the coil kit your ignitor is glowing
Dec 07, 2009 | Maytag Dryers
My Maytag model # mdg6000bww doesn't heat up?
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Jul 18, 2009 | Maytag MDG2600BWW Gas Dryer
Gas keeps shuting down and not heating the air
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor does not glow then it or the thermostat is bad.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.   If the gas ignites but does not stay on either the flame sensor or the coils are at fault.  If the gas ignites but the cycle stops and repeats quickly the lint filter, exhaust vent or outlet may be clogged.
Jun 03, 2009 | Maytag Dryers
Maytag gas dryer runs but does not heat
If yo smelled gas then the ignitor may not be working.
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor does not glow then the thermostat is bad.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.   If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
May 30, 2009 | Maytag MDG2600BWW Gas Dryer
Dryer does not heat up
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.  If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
May 29, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Stops heatinng
Hi, first thing to check is the venting. If the vent is plugged, it will cause the heat to short cycle.
If later in the cycle, the ignitor glows but will not ignite the gas, you will need to change the coils on top the gas valve. This is a common problem.
Please let me know if I can assist you further.
Thanks
Vic
May 24, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag gas dryer model#NDG2330AWW heating problem
your gas coils are bad. they open up for the first cycle but fail to after. Replace your coils and this will solve your problem
Dec 13, 2008 | Maytag Dryers
Maytag Neptune MDG5500AW Gas Dryer Logo
83 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
