Question about Mustek MP70C Portable DVD Player
I do not know how to charge the battery on the Mustek MP70C...
I have changed the backup battery, i have charged it for about 22 hours, but when i turn off the electrical supply, it goes off! ( the ups) MUSTEK POWERMUST 800
Remove batts, Check battery connector, fuse and batt volts, if you have dummy load (car headlight etc) check batts are working and measure voltage under load.
Also check if UPS needs to be told there are new batts read manual or check support for maker.
Let me know what you find, hope this helps
Thanks for using FixYa
Jul 30, 2010 | Mustek PowerMust 800 (POWERMUST800USB) UPS...
I power it up and insert a disc and it says Wrong Region on the screen. This is a Canadian unit that has worked fine for two years now, and I've tried several different DVDs which work fine on my larger...
If you have relocated then the region code may need to be changed. However using region 0 is most practical. Clean the optical head of the player with a CD/DVD cleaner too & see if it responds............sodeep
Sep 25, 2009 | Mustek MP70C Portable DVD Player
Lost the charger for mustek dv 4000 model where can i get replace
United Kingdom :
Hotline: 0870-0132017
E-mail: support-uk@mustek.eu
Monday till Friday, between 9:00 AM and 17:30 PM
but to be honest best thing to do is look by the charging point will have the voltage and ampage inputs to charge get a charger that matches those inputs if i remeber correctly (i used to work in the service center for mustek) the old fatter nokia chargers work in this to charge it
Aug 28, 2009 | Mustek DV4000 Memory Card Camcorder
SUPER slow charging
Sounds like your battery is shot. replace it.
Jun 15, 2009 | Mustek MP70C Portable DVD Player
Spares required.
Battery spec as per manual 1000m Ah x2 doesn't give the voltage but the charging addapter is 5volt 2.0amp.
George
Apr 24, 2009 | Mustek PVR-H140 Digital Media Player
Mustek H140
you can order a new battery from mustek in germany
I have got there email address at work i will post it here in the next couple of days
But I had the same trouble the battery would only last half an hour or so
I had to send 30 euros in cash !(due to horrific bank charges)
but went very smooth got it all sorted in about 2 weeks start to finish
now mine works fine
May 20, 2008 | Mustek PVR-H140 Digital Media Player
MUSTEK 7" pORTABLE dvd PLAYER lcd PROBLEM
You might need to adjust the settings by pressing the LCD button then using the up/down/left/right arrows on the player or remote to change color or brightness. If this doesnt work, your screen might be shot. There isn't much you can do if thats the case.
Nov 03, 2007 | Mustek MP70C Portable DVD Player
My Mustex MP-100
my mp100 mustek player will not switch on or charge up also it will not switch on when the mains charger is plugged in. the light on the charger went out and will not come on anymore.
Aug 12, 2007 | Mustek MP100 Portable DVD Player
Portable mustek dvd player
try this: power up your dvd without a disc. using your remote keypad input 9735. a secret menu should apprear. select your region code or choose 0 which will allow all discs to play. this will work with the mp70c but not with all mustek models. other solutions are available with an exhaustive google search
Feb 11, 2007 | Mustek MP70C Portable DVD Player
Mustek MP70C Portable DVD Player Logo
21 people viewed this question
Top Mustek Televison & Video Experts
Jonathon summesfield
richie46
Are you a Mustek Televison and Video Expert? Answer questions, earn points and help others
