Question about Whirlpool GY398LXPS Electric Kitchen Range
E2 -F3- I was cooking a turkey at 325 degrees for 5 hours.  When the timer went off and I checked the turkey the oven coil glowed orangy and then beeped 3 times and displayed E2 -F3-
  • chataccs Dec 27, 2008
    My GY398LXPS Electric Kitchen has E2 F3. Please, help
  • 15,935 Answers
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 29, 2010
How long will it take to cook a 15lb. turkey? From the Utube, I saw 30 minutes at 450
Just cooked a 15 pounder with stuffing wrapped tightly in foil on a rack in a roasting pan at 450 degrees 1/2 hour then dropped to 350 for 4 1/2 hours in a convection oven, the foil keeps the moisture in. Uncover last 1/2 hour for crispy skin
Nov 23, 2017 | Grilling
Whirlpool GR396LXGQ oven comes on by itself & goes into clean cycle, code reads E2 -F3-
Whirlpool F3 faults relate to temperature problems in the oven. In the case of the error E2-F3, F3 is the general fault code and E2 is the specific error code. An E0-F3 error indicates that the oven's temperature sensor is open; E1-F3, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E3-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in the clean mode. Here is the probe to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 07, 2012 | Whirlpool Ovens
At what temerature and for how long do I cook a 16 pound turkey?
Between 300 degrees and 350 degrees for 4 to 5 hours. Add one hour if the turkey is stuffed.
Nov 25, 2010 | Rival 18 Qt Roaster Oven with Buffet...
Have 16 pound turkey how long to cook in 16 quart roaster oven
The manuals are basically the same and a related manual is here:
http://www.rivalproducts.com/manuals/MANUALS/RO188BR_43_81844057.PDF
But they recommend 375 and I find that the turkey is much better at 325. The Rival manual suggested 375 for pre basted or 350 for fresh 9-14 minutes per pound. In my experience this is too hot. I use 325 for 4 to 4 3/4 hours at 325 for an 18 pound turkey; a 21 pounder takes about 35-45 minutes more. Do start checking the end temp with your instant read thermometer about a half hour before it "should" be done.
The USDA now uses 165 as the end point temp (down quite a bit from a few years ago), but if you stuff, that has to be in the middle of the stuffing, and the turkey will overcook somewhat while it gets there. All experts agree that turkeys cook better and safer if unstuffed, so considering that you will have to make an extra pan of stuffing to have it for everyone, you would be well advised to cook your turkey unstuffed and use some of the drippings to flavor the pan of stuffing while the turkey rests.
Nov 26, 2009 | Rival 18 Qt Roaster Oven with Buffet...
What temp should i cook a 20lb turkey in a rival roaster oven model num r01801
This turkey is right on the edge of the size recommended for this roaster, so first, check the fit- you need about an inch all around including the top to get good cooking. Any place it touches the sides it will tend to overcook.
The Rival manual suggested 375 for pre basted or 350 for fresh 9-14 minutes per pound. In my experience this is too hot. I use 325 for 4 to 4 3/4 hours at 325 for an 18 pound turkey; a 21 pounder takes about 35-45 minutes more. The USDA now uses 165 as the end point temp (down quite a bit from a few years ago), but if you stuff, that has to be in the middle of the stuffing, and the turkey will overcook somewhat while it gets there. All experts agree that turkeys cook better and safer if unstuffed, so considering that you will have to make an extra pan of stuffing to have it for everyone, you would be well advised to cook your turkey unstuffed and use some of the drippings to flavor the pan of stuffing while the turkey rests.
Nov 24, 2009 | Rival 18 Qt Roaster Oven with Buffet...
New Rival 22qt. Roaster Oven
If you want to use it for food tomorrow, you need to burn it in tonight; 1 hour or longer at 400 degrees, outside but protected, to burn off the factory oils, etc. If you cook in it without doing this, you will ruin the food (and the atmosphere) with bad smells.
This turkey is really bigger than Rival recommends for this roaster, so check the size/fit tonight, also. You need an inch all around for best cooking.
I use 325, not 375 as the Rival manual suggests, 4 hours for an unstuffed 18 pounder.
Nov 24, 2009 | Crock Pots & Slow Cookers
Can you cook a stuffed turkey in the roater oven
Yes, similar timewise to a regular oven. But it depends on the size of the turkey, if stuffed you definitely want to check the fit- you need about an inch all around including the top to get good cooking. Any place it touches the sides it will tend to overcook.
The Rival manual suggested 375 for pre basted or 350 for fresh 9-14 minutes per pound. In my experience this is too hot. I use 325 for 4 to 4 3/4 hours at 325 for an 18 pound unstuffed turkey; a 21 pounder takes about 35-45 minutes more. The USDA now uses 165 as the end point temp (down quite a bit from a few years ago), but if you stuff, that has to be in the middle of the stuffing, and the turkey will overcook somewhat while it gets there. It adds about 1-2 minutes per turkey pound if stuffed.
Nov 21, 2009 | Hamilton Beach Toaster Oven with...
Convection cooking
Convection ovens are great for roasting!
I cooked a 15 lb  stuffed turkey in 2 hours in mine. And it was juicy and fab!
My auto degree set for convection  is 325.
I have a Jenn Air wall oven, so I don't know, it might be different for different brand.
Roast or bird should be in the middle of the oven. THe air has to circulate well to get best results.
I believe rule of thumb is a convection oven takes 1/2 LESS time than conventional.
Hope this helps.
Jan 13, 2009 | Frigidaire PLEF398AC Electric Kitchen...
Whirlpool GW395LEPQ console is completely black and E2 and F3 err
If digits on control board does not shows up after resetting power you need a new control board(part# 9760013 $174.20).
sensor for this model(part# 4455636 $89.78)
Dec 02, 2008 | Whirlpool GW395 Gas Kitchen Range
Whirlpool GY398LXPS Electric Kitchen Range Logo
231 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
