Question about Philips Televison & Video
My philips tv 21pt9470/55 Is showing a screen saying factory mode
Turn on your tv , now wait for a screen show the number chanel an rapid digit in your remote handset the secuence keys.. smart sound---smartpicture---OSD. quickly . now in the screen show adjust an press 781206 menu to initialize eeprom data.
Turn power off the tv and wait for a 10seg to power on.
enter SAM mode and adjust the vertical size . horizontal size and EW convergency
Posted on Oct 26, 2010
  • luchosa Apr 14, 2011
    presionar en el control remoto la secuencia menu,8,9 y sales de factory mode a modo de servicio para salir de modo de servicio presionar el boton osd y listo
S video stays on screen on my 27 Philips tv. How do i hide it? Also tv has black at top and bottom of screen,how can i get full screen display?
Do a factory reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Feb 26, 2017 | Philips Televison & Video
Need information on a philips t.v. model 32PT6441/37
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Aug 12, 2008 | Televison & Video
I have a philips 42PFL5432D/37 that has a shadow covering about a 1/3 of the screen and will not change screen format. Stuck on Zoom setting that doesn't fit the entire picture on the screen. Bret
Try a factory reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Aug 05, 2016 | Philips Televison & Video
Philips 40PFL7705DV Stuck In Factory Service Mode
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 22, 2015 | Philips 40PFL7705DVF7 LCD TV
Not possible to select screen modes but Philips logo comes permanently.
Corrupted firmware. A firmware update is necessary. Contact any service technician; or the authorized service center for Philips. It is a skilled work. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Before doing anything, try a hard reset to this set, and check.
There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option.
May 22, 2015 | Philips Televison & Video
Philips 26in flat screen tv is stuck on language menu, how do i reset/ return to normat tv
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 04, 2014 | Philips Televison & Video
Tv word factory screen remove
What is the brand name to your TV? Your TV is now in service mode [factory mode] now. That is why, it shows the display 'Factory' on screen. You have to quit the service mode. Then only you can enter into its normal menu. But, entering and exiting factory mode/service mode, to different brand TVs will not be the same. http://electronicshelponline.blogspot.com/ Check this link. It has service mode entry and exit methods to many brand TVs. Pull up older posts there, either by its left side bar, or, view it in 'Timeslide' option. Look for the service mode entry and exit method to your brand TV. You'll get details there.
Jun 19, 2013 | Sansui Televison & Video
26PF5521D wont show menu after reseting factory defaults
Switch the TV to analogue mode (if possible)
Press and hold the "MENU" button on the side of the TV. The settings menu should appear. Continue to hold the menu button until this menu disappears. (If you let go before the menu disappears, start again)
The TV should now go blank for up to 2 minutes, and then revert to factory settings and intitial installation screen.
Procede as per original installation.
Oct 26, 2007 | Philips 26PF5521D 26 in. HD-Ready LCD...
'F' displaying on screen and remote not responding.
Excavated with Google from Philips website: " When a letter F appears on the right hand corner of the screen it means the television is in factory mode. To exit from factory mode, press the 'VOLUME -' and ?CHANNEL -? buttons on the TV set simultaneous for 5 seconds. " Hope this helps Michael Junge
Aug 04, 2007 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Televison & Video Logo
387 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
