Question about NetGear WGR614 Wireless Router
Wpa passcode - NetGear WGR614 Wireless Router
    President:
  • 2,571 Answers
You set it yourself.
Log on to your router, go to wireless / security
Posted on Oct 11, 2010
How do i find my wep key
Most routers today no longer use the easily defeated WEP encryption. Most all use WPA/WPA2. Thar said, you must know the passcode as most routers will not display the code even internally (just shows a string of ******). The only thing you can do is go into router setup and change the passcode to something you know. But then all other devices attached to the wireless network must change passcode as well.
Aug 25, 2014 | Computers & Internet
Wpa pass phrase
Although the information you've left is very vague.
I'm assuming you want to know what the WPA passcode is so you can connect to your network to get online Xbox 360?
It will be the wireless password you use to get on the internet with a laptop of sorts. If you have a 2wire gateway/modem its on the bottom of the modem in brackets usually. I'd check to see who setup your wireless router and they'll be able to get you the passcode for your wireless.
Mar 01, 2011 | Microsoft Wireless Network Adapter Xbox...
How can I find the WPA Passcode without resetting my D-Link DIR-655. I'm trying to install a wireless printer and it won't accept my passcode that I set up for wi-fi. I'm afraid if I reset I won't be able...
Hi tammi the pass code if unchanged is normaly on a sticker under the router if it has been changed on a computer wich is connected to the router i would go to Start>run> Type (cmd)>ok
type (ipconfig).enter look for the wireless settings and take note of the Default gateway numbers. enter the numbers in a web bowser adress bar then will conect you to the router settings after loging in look for security setttings key could be displayed hear or beable to change you will have to attache all wifi items with the new passcode
Jun 03, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I'm trying to connect my son's MAC to our wireless internet that uses a Siemens speedstream 4200 router. The mac keeps asking for a wpa password. I found a 10 digit *** password under settings but can't...
Deriving the WPA passphrase is supposed to be VERY HARD. This is why no one uses WEP anymore, deriving the key was possible.
How many wi-fi devices do you have? If you enumerate all of them, including levels, someone may have an idea, because all the working devices have to know the passphrase. For example, if one of them is a Windows device, well, the passcode is somewhere on the windows device so that the driver can get it and it is possible to reconstruct it, I am just not sure how. Someone might know or it might be possible to find the procedure with a web search.
But what I would do is just change the passcode and then reconfigure all the devices you own to use the new one. Then I would write the passcode on a piece of paper and tape it to the router. You mostly care about the passcode to stop over the air attacks, (from people sitting in your front yard) and if someone can physically get to the router, they are allowed to know the over-the-air encryption code.
Jan 10, 2010 | Gateway Wireless-B Router (wbr-100)
Cant find my linksys passcode!
You require a wired or connected PC
How do I find out my Wireless key (WEP or WPA) ?
There are numerous ways to find out these values so I will cover a few.
Easy Solution (you should be so lucky)
Sometimes the value for the Wireless Key is written on the underneath of the router, look for SSID (this is the network name) and WEP or WPA key (called the encryption key)
Alternative Method
In order to find out your Wireless Network Key you must first use a cable to connect to your router.
Once connected check that you are connected to the internet by opening Internet Explorer
The address or the router is usually one of the following values:-
http://192.168.0.1
http://192.168.1.1
http://10.10.0.2
http://192.168.2.1
http://192.168.2.254
Try clicking on each and see if you get a logon box popping up
If you do, that is the correct address for your Wireless router, note it down.
If the box has the username and password completed, then click OK
If there is no value for username try "admin" and for the password try one of the following "password", "admin",
Also try nothing for the username and "admin" for the password
Sometimes the value for these are written on the underneath of the router
Once the router page is displayed, look for an item called Wireless Settings.
Next see if a further option for Wireless Security exists.
The names of these items vary from Router to Router
Once security is displayed the SSID (Network Names) and the WPA or WEP Key can be found.
Jan 25, 2009 | Linksys Wireless-G WRT54G Router
Passcode forgotten
the passcode it's asking is the wireless security that was setup on your router. it could be a wep or wpa.
in order to get it, you need to access the setup page of your router. for most routers, all you need to is open a web browser and enter the router's ip address.
i can't provide the exact steps since i don't know the exact model of your router.
you can try to ask the person who manages your router for the wireless key.
hope this'll help you but if not, provide me the exact brand and model of your router
ciao!
Jul 24, 2008 | Dell TrueMobile 2300 Wireless Router...
My xbox says i have to give it an WPA key where do i find this key
The WPA key is found in your wireless router. This is the passcode for your wireless to get on to the network.
Jun 11, 2008 | Video Game Consoles & Games
NetGear WGR614 Wireless Router Logo
117 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
