Question about Marvel 61WC Wine Cooler
My repair guy told us that our marvel 61wc needs a new compressor and coil how much do these parts cost
aborcass
  • 2651 Answers
SOURCE: Marvel 61WC Wine Cooler
sorry for the delay in response time you definatly have a bad thermistor, not able to stabilze temp so it contionues run never shutting doen freezing everything, who ever repairs it (if they haven already,)make sure they put all 3 new peices in, thermistor, potentiometer, and contol box. all 3 come in one kit, 20 min to install
Posted on Mar 01, 2008
Krazytech
  • 725 Answers
SOURCE: Marvel model 61WC Wine cooler
first do you have power to the compressor? if not it could be a control... if you do it could be a relay...let me know and I can help
Posted on Sep 01, 2008
  • 101 Answers
SOURCE: marvel 61wc temperature will not go below 67
The 61 WC is a cycle defrost/plate sensing control. If your unit was manufactured before 2001 it will use an electric/mechancal thermostat that has a capillary tube that senses temperature. If it was made after, it will use a solid state control box that has a "thermsitor" sensing temperature and a potentiometer for user input (OFF through 7). If the unit runs constantly, and does not reach desired temperature...it is low on freon due to a leak. This will be evidenced by ice build-up where the freon first enters the evaporator plate and no where else. You will have to have a technician fix the leak and recharge the unit. Don't wait to long to ge this corrected. If the unit runs too long with a low charge it could draw air and contaminants into the system and the compressor will get damaged.
I hope this helps.
Posted on Sep 12, 2009
  • 101 Answers
SOURCE: EVAPORATOR LEAKING
You can order a replacement evaporator assembly directly from the factory at 800-223-3900. I believe (working on memory here) the part# is 42244047 (for black) and 42244046 (for white) It comes with the suction line and capillary tube already brazed to the evaporator plate and comes with a new filter drier. They can also recommend a service technician in your area if you need one, They accept all major credit cards.
Posted on Jan 09, 2010
Testimonial: "I was told by Marvel, evaporator part is 42241493. (I provid serial) I hope they didn't miss this one... :-( :-( Thanks fr your support :-) "
  • 101 Answers
SOURCE: Marvel 61wc wine cooler turns on, but doesn't cool
If you can hear the compressor running and there is no cooling happening your unit has either lost it's refrigerant due to a leak or the compressor is completly worn out (or both). If you just hear the condenser fan running (air blowing), then maybe the compressor just has bad electricals (starting relay, overoad, run capactor) or it has developed a bad winding and will need to be replaced.
If you know you have lost refrigerant the repair will be quite costly and you should consider replacement. If you feel it is a failure of the small electrical parts for the compressor, repair would be more cost effective.
You can get further trouble-shooting assistance and order parts direct from the factory at 800-223-3900.
You can look up a local servicer on their web-site at www.lifeluxurymarvel.com
Should you desire to attempt electrical repair yourself, reply to me and I will provide further troubleshooting assistance or you can contact Marvel Customer Service at the number above. Good-Luck, Subdriver
Posted on Feb 05, 2010
Why does my wine cooler run too cold?
If after adjusting your thermostat to desired temp and is still cooling. The thermostat is bad or your relay is bad
If you disconnect the thermostat and the compressor stops it most likely a bad thermostat
If you disconnect the relay from
The thermostat and it stay running it is the relay. It is sticking
If possible store you wine somewhere else and shut the unit down and unplug for 10 to 20 minutes this may cause some melt of condensation some water may be on the floor if is to cold
This may also reset the system.
Jul 26, 2015 | Marvel 61WC Wine Cooler
Marvel 6BAR6004 not cooling
check you themoistat it may be coated with sofa
Jul 04, 2014 | Marvel 61WC Wine Cooler
Jan 28, 2010 | Marvel 61WC Wine Cooler
My marvel wine cooler is 9 years old and no longer runs. The light works but nothing else runs. Might this be the thermostat? iif so where would I ge a replacement and would would it cost?
This could very well be the thermostat (pre-2000) or part of the temperature control system (2000 to 2009) which has three parts: The thermsitor (usually the culprit), the potentiometer (connected the the control dial) or the control board. Call the factory at 800-223-3900 with your serial number (to identify which control it uses) and you can buy the part direct from them. The control kit is about $150.00, the old style thermostat about $100,00 and if it is just the thermsistor, it's about $50.00 (I haven't checked their prices in awhile)
Jan 18, 2010 | Marvel 61WC Wine Cooler
EVAPORATOR LEAKING NEED PART, FOR MARVEL 61WC
Jan 07, 2010 | Marvel (6SBARBSG) Wine Cooler
Humidity and temp control not working.unit is 12yr old
The 61WC does not have humidity control in it unless it was added after the factory. The old style mechanical control is still available from the factory at 800-223-3900 PN 42241702 (ask them to double check my memory on the part number)
Jan 06, 2010 | Marvel 61WC Wine Cooler
Marvel 61wc temperature will not go below 67 degrees F. Ice has accumulated on the back wall on the coil.
I hope this helps.
Sep 09, 2009 | Marvel 61WC Wine Cooler
Marvel 61WC Wine Frige Won't Turn Off
Check he frost pattern on your evaporator. That is a plate sensing control and if the system developes a freon leak you will have frost on the beginning of the cycle (middle bottom and travels to the left, then across the top middle, then to the right and back to the lower middle) but not at the end where the thermsitor senses temperature. This will cause the unit to run almost continously no-matter what setting you have it on. If this is so, you need to have the leaking component repaired/replaced. You will not want to let your unit run like this since the longer you do..the more components will get damaged. If you are still with-in your warranty period, contact your dealer to initiate service. If not, contact any appliance repair shop you trust in your area. I hope this helps.
Jun 25, 2009 | Marvel 61WC Wine Cooler
If the unit was made after 2000, there is a solid state control in the back that you can test. If it was made before then, it will have capillary tube style thermsotat that you can test.
Made after 2000:
First, pull the unit out to access the back lower area and disconnect the power. Remove the lower backing to access the mechanical area. There will be 2-inch square back box with seven terminals and 4 dip switches. Disconnect the red and black wires from terminals # 3 and 2 respectively and connect them together (this bypasses the control). Plug the unit in...if it runs you need a part of or all parts of the control.
Made before 2000. With power disconnected, remove the front grill to get access to the thermostate (usually on the right side). It will have up to three wires connected to it and a sensing line. Leave the green (ground) wire as is (if connected), disconnect the other two wires and connect them together or run a jumper. Plug the unit in...if it runs then you need a new thermostat (only one part).
If the compressor does not run but the condenser fan does...something is wrong with the compressor.
You can also call the factory at 800-428-6644 and ask for technical assistance. They can assist you with further troubleshooting and/or finding a servicer near you. They should still have parts to repair that unit.
Sep 01, 2008 | Marvel (6SBARBSG) Wine Cooler
Dec 02, 2007 | Marvel 61WC Wine Cooler
Marvel 61WC Wine Cooler Logo
67 people viewed this question
Top Marvel Furniture Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Joseph Hoffmann
Are you a Marvel Furniture Expert? Answer questions, earn points and help others
