Question about Citizen Promaster Cyber Aqualand Nx Dive Computer Watch
It keeps flashing file! And it's not logging anymore dives.
When the amount of available memory in flash memorybecomes low, "FILE" flashes in the lower left corner ofthe display in all of the submodes of the standard mode as well as in the dive mode. Thewatch automatically switches to the flash memory statusdisplay of the system monitor mode when the water sensor gets wet while thiswarning function is activated. Please note that although it is possibleto use the watch for diving in this state, log data may not be recorded inflash memory during diving. The file error warning function is also activated andadditional log data is not recorded if the duration of a single dive exceeds 2 hours or if morethan 15 dives are made in a single day. The file error warning function may also be activated whenthe water temperature during diving is low. It may not be possible to receive watchsettings by data communication while the file error warning When the watch has switched to the file error warningdisplay, perform the garbage collection procedure in the system monitor mode of the standardmode. Thedisplay returns to normal following completion of garbagecollection. Garbage collection begins when button (C) is pressedfor at least 2 seconds during the flash memory status display. • During the garbage collection operation, an alarmsounds and "G.C." is displayed on the display. When garbage collection is completed,"Done" is displayed on the display. • Garbage collection cannot be performed when"G.C." has changed to "NG" on the battery charge indicator or when the water sensor hasbeen activated. "Fail" is displayed on the disPress button (B) in the system monitor modeof the standard mode to switch the watch to the Flash Memory Status Display. Formatting Flash Memory Formatting of flash memory begins when button (B) is pressed while pressing button (C) simultaneously forat least 2 seconds.play at this time. theoxrysa@freemail.gr
Posted on Mar 22, 2011
How do I use the moveable outer numbered ring on the t49825dh?
The numbered bezel can be used by divers to measure elapsed time on their oxygen supply. Place the zero where the minute hand is now and you'll know when 20 or 30 minutes have passed when the minute hand reaches bezel number 20 or 30.
In the same way, you can use the bezel to tell when 30 minutes have passed on your parking meter if you simply put the 0 on the minute hand when you leave the car. When the minute hand reaches the 30 mark, a half hour will have passed.
Typically, the bezel only turns counterclockwise to keep the wearer from bumping and changing the elapsed time number. On some less expensive watches, the numbered bezel does not turn and is decorative only.
Oct 23, 2014 | Timex Tiex en T49825DH Expedition Military...
Hello i have a problem with my Citizen Cyber Aqualand NX. He is flashing FILE. I have tried to do the garbage collection, but he said Fail. Also the Formatting of the Flash memory dos not work, and said...
I got last year same problem, easy to resolve :) I was doigng GC and i got my watch in failur exactly like yours. Solution? Buy 4 fresh, alkaline, good brand batteries. Put it in charger unit. Let the watch to charge for 12hours. After do garbage collection again or formatting if you cant do GC. If you got again fail, charge again it for 12 hours. I did it for 3 times and...the third days, I got "Done!" and solved :) It happens when battery is not full charged, so do GC just when is very charged. I love my Cyber, but sicne seems that GC collecting drink a lot of energy seems that low level battery doesnt let the inside flash memory to work well when try to format/GC datas.
Jun 01, 2011 | Citizen Promaster Cyber Aqualand Nx Dive...
My aqualung duplex alternates flashing seconds then "ER"in the lower display window, I've reset it as the manual instructs, after pushing the stem back in it beeps twice then starts the same...
This watch needs to be sent back to the factory to get the movement replaced. I am doing this for the second time in 4 years. Citizen Europe states it's a defective design. The watch goes into dive mode with sweat, humidity and washing your hands. The water sensor tells the computer it's gone diving but the pressure sensor isn't telling it the same thing which causes a fault with the computer. I was told to cover the water sensor with WAX by the factory repair facility. WAX on a $400 dive watch. Great. They shold have used the pressure sensor to initiate dive mode. Customer Service said it wasn't defective, so it was designed to need this part everytime the battery has to bre replace.
May 27, 2011 | Citizen Aqualand Duplex JP104009E Wrist...
Which way does the bezel turn on a tag watch
Tag Heuer watches are constructed with scuba-diving bezels-- that is to say, it only turns COUNTERCLOCKWISE. This is so that when you are diving, you set the triangle marker to the time you went down. If you accidentally bump your watch while diving, it will move only counterclockwise, leading you to think you have LESS time left to dive, which is so much safer than thinking you have MORE time to dive, than you really do.
May 03, 2011 | Tag Heuer 2000 CN1110.BA0337 Wristwatch
How does the log function work and how do I recall the information about each dive?
I had the same problem when I got my watch. It was resolved with help user manual on the page 72.
Conditions for Storing Log Data in Memory>
• The log number and log data are stored in memory when
the watch remains at a depth of more than 1 m (4 ft) for
3 minutes or more, or it remains at a depth of more than
8 m (27 ft) for 1 minute or more.
It's not a bug it's feature :)
Jan 26, 2011 | Citizen Aqualand JV0030 01E Watch for Men
My battery is out on my Jaques Leman diving watch. I wanted to repair it myself. I was told if I took the back off I would break the seal. Im attempting to fix it myself
Thank you for contacting FixYa.
If you have a good quality scuba dive watch that needs to be repaired, such as needing a battery replacement, it can be tempting to do it yourself. After all, don't you just need a screwdriver, a battery and rubber gasket (possibly)?
Well, yes. But if you do it yourself, you run the risk of voiding the warranty.
So if you change it yourself and the watch later floods, you are out of luck. So check your warranty information carefully before you attempt to do anything yourself or have someone other than the manufacturer/authorized dealer do the work.
If the manufacturer changes the batteries or does any other dive watch repair, they will normally retest the watch and certify that it is still water resistant to whatever level applies.
This is not to say that a qualified watch repair shop can't do the job. It's your decision but at least it will be an informed one.
So the long and short of dive watch repair - if it's a good dive watch, you'll probably want the manufacturer/authorized dealer to handle it if you don't want to void the warranty. A cheap dive watch? Probably not worth the bother.
Aug 26, 2010 | Jacques Lemans 1378B Sports Chronograph...
Why do the Omega Seamaster watches have a second crown close to the top of the watch? What is its function?
This is a helium release valve.
The purpose and function of the helium relief valve is a common point of confusion. It has nothing to do with normal underwater diving. Neither does it have anything to do with the depth rating for a diving watch. Helium does NOT seep into the watch while the watch is in water at any depth!
To put it simply, you can completely ignore a helium relief valve. This feature is not used in any way with any form of normal SCUBA diving or anything else that involves less than a multi-million dollar deep sea exploration project.
SCUBA diving activities normally occur at depths of no more than 120 feet. At 250 feet, air becomes toxic due to changes caused by the high pressures at such depths. For those who do very deep sea research, they often use diving bells, dry dive suits, and other types of very deep ocean exploration vessels. In some of these, a highly helium-saturated atmosphere is used to avoid the air toxicity effect.
The purpose of a helium release valve is for people who wear their watch inside the helium-saturated environment for an extended period. Because helium is the smallest atom, it will seep through the watch's seals under the high air (not water) pressures in this environment. If the watch stays in this environment for an extended time, helium will continue to seep in to the watch until the air pressure inside the watch (initially surface air pressure) equalizes to the air pressure in the environment.
This becomes a problem when the vessel is brought back up and depressurized. The helium which seeped into the watch over a couple of days, cannot seep out any faster. The excess pressure inside the watch needs a way to release faster than it seeped in. It is only in this situation that a watch needs a helium relief valve at all. If a relief valve was not on the watch, the excess pressure would likely escape by pushing the crystal out.
But, unless you are in this exact situation, you should never keep this valve open. While the watch is designed to maintain most of its waterproof abilities even when the valve open, it still serves no purpose and increases risk of damage to the watch to do so.
Sep 23, 2009 | Omega Seamaster 2541.80 Wrist Watch
Navy Seal Luminox watch second hand problem
It is a feature of this watch, it is referred to as the end of life (EOL) feature, it is a way of letting you know its time to change the battery before it dies to the point where it cannot keep time anymore
Oct 24, 2008 | Navy Seal Luminox Dive Watch
Aspen watch
Setting my Aspen Digital Watch
Button designations:
(NITEGLOW) B C (START/STOP)
10:47
(MODE) A D (SPLIT/RESET)
To Set Time, Date and Day:
Press A 3 times; Seconds Flash; Set to 00 with C
Press D; Minute Flashes; Set Minutes with C
Press D; Hour Flashes; Set Hours with C
Press D; Date Flashes; Set Date with C
Press D; Month Flashes; Set Month with C
Press D; Day Flashes; Set Day with C
Press A to Quit
To Set Alarm Time:
Press A 2 times; Hour Flashes; Set Hour with C
Press D; Minutes Flash; Set Minute with C
Press A to Quit
To Set Alarm ON or OFF:
Hold D in to see Alarm Time and Press C to toggle Alarm ON/OFF
Operation:
Hold C to see Month and Day.
Hold D to see Alarm Time; Press C to toggle Alarm ON/OFF.
Mar 27, 2008 | JCPenney Armitron Sport Link Bracelet...
How deep can I dive with this watch
Per "Sector" all of their watches are "water resistant to a minimum of 300 feet". Note that they do not say "water proof".
Aug 20, 2007 | Sector 450 2653450035 Wrist Watch
Citizen Promaster Cyber Aqualand Nx Dive Computer Watch Logo
230 people viewed this question
Top Citizen Watches Experts
Jimmy Accardi
Are you a Citizen Watch Expert? Answer questions, earn points and help others
