Question about Kitchen Ranges
Maytag oven not heating up
Burners and Broiler is working, however oven bottom burner is suddenly not lighting
  • 1 more comment
  • Anonymous Jun 02, 2008
    My Maytag model nos. MGR5775QDW oven when trying to bake will not heat any higher than 100 degrees.
  • johano Dec 22, 2008
    I have a Maytag MGR5775QDW gas range.I have changed the igniters on the bake and broil burners.The broiler will ignite as it did before the new parts were installed, but only on the self clean cycle.There seems to be a switch in series with the door lock that allows the gas to flow independantly from the bake and broil cycles.Should I change the gas regulator assembly next or is there some other module in series with the igniters.I don't think it is the oven sensor.
  • cedewitte Feb 19, 2009
    My burners, broiler, and controls work but the oven will not heat up. It's reads 100 degrees and never changes.
  • 413 Answers
The igniter has failed. In many cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve.($50.00 to $90.00 for igniter). The igniter can get hot enough to raise the temperature 100 to 120 degrees without activating the gas valve.
Posted on Jun 04, 2008
I have a maytag model # mgr5775qdw and the oven will not ignite. I know it is not the gas line as the burners all light, and the broiler lights as well. It is only the oven that does not heat. . .what...
This could be two possible problems. The igniter maybe bad, but doubt it. The igniter works both the oven and broiler, I believe on this model. The first thing I suspect is the switch in your wiring harness. The harness has a switch attached to it for each manifold. The switch for your oven maybe out.
Go to this site for diagram of parts:
Jun 18, 2011 | Maytag Ovens
Top oven not heating up on BAKE, broiler gas and flames come on. Stove top burners work, Bottom oven heats for BAKE and BROIL.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
Jan 08, 2011 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Neither the oven nor the broiler burners will light. In both cases, the igniter glows, but no gas to the burner.
Mar 10, 2010 | Maytag MGR5750 Gas Kitchen Range
The ignitor in the stove heats up, but we don't get a flame in the oven. The burners and broiler work fine. What's broken?
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Feb 05, 2010 | Maytag PER5710 Performa Electric Kitchen...
I have no heat coming from the oven portion of my kenmore 790 electric range after hearing a "pop" sound. fyi, the element looks intact.
Top burners are working, broiler is working, bottom oven burners dont ignite and dont heat the oven? What can we do?
Dec 30, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Bottom burner for maytag gas oven will not light. The broiler will turn on and heat, but not the bottom burner.
will have to replace the oven ignitor part #120000035 / this will correct burner problem / mm
Dec 08, 2009 | Ovens
Oven doesn't light. I have a Maytag MGR5750. The pre-heat light comes on but no ignition. Stove top burners work okay.
First thing to do is verify if the hot surface igniter or spark igniter is working. If the oven has a bottom broiler compartment then you can check from the bottom compartment. If it has a top broiler then you may need to remove the inner bottom cover inside the oven to look at the burner and igniter. Now turn on the oven and watch for the hot surface igniter to start to glow or the spark igniter to come on. If the igniter comes on then give the gas control valve(located at the bottom broiler/storage compartment) a tap with a wrench or a screwdriver. If the burner comes on then shut the oven back off and on several times COMPLETELY. If it works then you may have fixed the problem by dislodging debris in the valve. If it does not come back on then the gas control valve may be defective or the igniter could be weak. The igniter should be tested with a ohm meter and if it tests good(500-700 ohms usually) then the gas control valve will need to be replaced otherwise the igniter is bad. On spark ignition systems there is a different procedure. Another thing to check is the "runaway valve" that is located on the gas regulator for the range. It is a little lever located where the oven gas pipe comes off the regulator and cuts the gas to the burner when closed.
Oct 16, 2009 | Maytag Kitchen Ranges
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven will not work,burners and broiler all work fine
under the floor of the oven, possibly can be see by removing the bottom drawer. the ignitor is hte most common aprt to go bad in any gas oven, visually it might not even look broken though and some even appear to glow(just not strong enough to open gas valve
Mar 01, 2008 | Kenmore 78570 / 78571 / 78572 / 78574 /...
Kitchen Ranges Logo
1,213 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
