Question about MXL 770 Professional Microphone
I don't hear any output from my mxl 770 condensor mic. I have it plugged into a Audiobox Presonus interface. I have 48v phantom power on it. My other mic works fine on it.
5 Suggested Answers
  • 10 Answers
SOURCE: Bought an MXL V88 Mic and i hear no sound ,not working
go to control panel> hardware and sound> sound; click recording tab, select USB Audio Codec, select Properties, click Advanced tab, select 2 Channel 16 bit 44100Hz and then hit apply. You have to make sure you have the 2 channel option selected. otherwise the computer just recognizes one channel and assigns it for playback. HTH
Posted on Jul 06, 2009
SOURCE: Rode NT2 got Phantom!
Well... Rode NT2's are condenser mic's that require phantom power to work. So the phantom switch should be on. When you turn phantom power on you usually hear a bump sound (through the amplifier). In this case, nothing is broken.
Your picture is of a Rode Videomic (not an NT2) which is a stereo mic for video cameras. If you had some kind of stereo mini to (single) XLR adaptor, and put phantom power through it, the mic would probably be damaged. But maybe not... just try again without phantom power to see. a stereo mic won't work very well with the Mbox Mini because it only has one mic preamp.
Posted on Feb 15, 2009
  • 1138 Answers
SOURCE: I just purchased a MXL 990 condenser mic.
Phantom power comes in different voltages. Make sure your power supply is delivering enough. Also make sure that your mike cable is wired properly. 1 is ground or shield. 2 is hot or Ve+ and 3 is cold or ve- If 1 and 3 are bridged for unbalanced use or if you have a short it won't work and will probably damage the mike or the power supply. I think the power supply needs to be 48 volts and you have to use the stereo XLR cord that is recommended for it. I hope this helps.
Posted on Jul 11, 2009
  • 12 Answers
SOURCE: Adobe Audition 3 Not Sensing Mic
Check the input and output settings. Look in the preferences or settings menu for "i/o settings" or "i/o setup." You're going to set it from the default internal mic input to this one. It sounds like it may be that simple.
Posted on Jul 29, 2009
Mxl condenser microphone cuts off intermittently
Failing more obvious things like a dodgy cable, condenser mics need phantom power 48v. Perhaps the phantom is cutting out?
Feb 25, 2015 | MXL Audio Players & Recorders
Does an MXL 990 microphone only work with an inbox?
By "inbox" do you mean a transformer that powers it?
Condenser mics need 48 volts (phantom power) to run, so you normally switch the phantom power button on for the channel you have the condensor mic. plugged into.
May 29, 2014 | MXL 990s Professional Microphone
How do i get my MXL 770 mic to work in my PC
There is an interface box that adapts USB to Phantom Power. Look at your local music store or online at Musicians Friend or a similar site.
Feb 20, 2013 | MXL 770 Professional Microphone
No sound from mxl 990 condenser mic
From the Micropower PS400 product description it states:
"routes the microphone signal to a mixer or a microphone preamplifier."
• these is just a phantom power supply.
One reason your former setup is OK , is that
tascam m-50 is a mixer preamplifier.
• phantom power supply is just a part of the mic preamp of the mixer
to power up your mxl 990 condenser mic
• What you may need is something like these:
X2u XLR to USB Signal Adapter
Sep 29, 2012 | MXL 990 Professional Microphone
I am trying to record with my mxl 990 micrphone onto my laptop but when i try to record no sound is heard
you can't just plug and play with these high end mics. You require a +48v phantom power source from something such as a mixer. Then plug the mic into the mixer and the mixer into the LINE IN on the PC
Jan 07, 2011 | MXL 990s Professional Microphone
I just took my MXL 3000 out of the box and it does not work while pluged into m mic cord
This microphone requires 48v Phantom power. So if you are trying to connect it to your computer, you will need to use a USB interface that will provide phantom power. If you are connecting it via a mixer, make sure Phantom power is switched on if it is available. As the MXL 3000 is only available new from Guitar Center or Musicians Friend, they can also provide you with what else you need.
Dec 30, 2010 | MXL Audio Players & Recorders
I bought a GXL2200 and i cant hear my vocals.
The GXL 2200 is a condensor microphone. It needs Phantom power to operate, and get the correct levels for recording. Your lexicon interface should have a button/switch that says +48V phantom power, or something similar. This needs to be enabled before the GXL 2200 will work.
Mar 07, 2009 | CAD Microphones GXL2200 Professional...
Can't operate my MXL 990
If it is an MXL 990 Condenser that comes in the grey case with a shockmount and a black hard mount I can solve your problem. (If it is USB I know nothing about that unit).
This MXL 990 microphone MUST have 48v phantom power in order to operate. If you aren't familiar with the term phantom power read the first link:
Phantom power - http://en.wikipedia.org/wiki/Phantom_power
MXL User Guide - http://www.mxlmics.com/support/guides.html
If yours is one of the older MXL 990's it should have an XLR connector on the bottom -
XLR Defined - http://en.wikipedia.org/wiki/XLR_connector
Your mixer (I am guessing its a Peavey, Tascam, Mackie) or something entry level like that may or may not have phantom power. I am guessing not. But if it does, it will have a switch that says 48v phantom power and most likely a green or red LED next to it to show you when its on. This mic will NOT work without phantom power.
Best suggestion: Verify that your mic is the MXL 990 Condenser, if it is it needs 48v phantom power. Check your mixer and see if it has 48v phantom power. The only computer soundcard that I know of that is used by a lot of folks is the M-Audio Delta 1010LT. It has XLR inputs but NO phantom power on it.
There's your answer.
Ray
Feb 09, 2009 | MXL 990s Professional Microphone
MXL 990 doesn't work
Your other preamp does not have phantom power to supply power to the microphone. All condensor mics like this need phantom power. The Audio Buddy provides phantom power, which is why it was shipped with those condensor mics
Jan 16, 2009 | M-Audio MXL 990/991 Recording Mic Duo and...
Pls help
The MXL 990s requires 48 volts to operate. If your mixer does not have a phantom power option, you will need to purchase a microphone pre-amplifier with phantom power to interface the microphone to your mixer.
Nov 19, 2008 | MXL 990s Professional Microphone
MXL 770 Professional Microphone Logo
249 people viewed this question
Top MXL Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Will Godwine
Are you a MXL Audio Player and Recorder Expert? Answer questions, earn points and help others
