Question about Dell Latitude D630 Notebook
Dell LatitudeD630 I dropped it. Not from a great height, from the settee. Now the thing is slower than ever, and the processing icon on the computer itself is permanently on where as before it used to flicker. Reckon I have dislodged something inside, but cant open it either............
  • ssm7209 May 31, 2008
    I want to fix it preferably. Surely if I dropped it it can only be a case that something has come loose or disconnected?
    I have managed in last half hour to get keyboard out, and made sure all the connections of things I could see were connected. Still then same. The processing light is still perm on, and after logging on nowt else happens........
  • Agugua  Lims
    Agugua Lims May 11, 2010
    explain yrself more or rather what do u want?
    Sergeant:
  • 324 Answers
It sounds like you may have damaged the hard drive. Can you get the thing to come up to the point that you can run any diagnostics?
Ron
Posted on Jun 02, 2008
11z 1110 dell freeze
Download, install (MIND THE TRIAL PRO, UNCHECK, YOU WANT THE FREEWARE, free MALWAREBYTES at: http://www.filehippo.com/download_malwarebytes_anti_malware/ RUN a FULL SCAN, Depending on the size of your HDD it could take hours. Delete ALL RESULTS. ALSO Download, install CCLEANER at :http://www.filehippo.com/download_ccleaner/ Run to clean junk from your computer. Look in TOOLS, STARTUP, DISABLE ALL PROGRAMS THAT ARE NOT NEEDED AT STARTUP. Open the TASK MANAGER, PROCESSES, and see what is making your CPU, MEMORY, max-out. It may be you have WAY to many processes at startup. REMEMBER, the more things that are running, the slower the computer. On your broswer IE, TOOLBARS/ ADD ONS will slow you down as well. Take a look at this procedure for tips on speed: http://www.howtogeek.com/107280/the-best-tips-for-speeding-up-your-windows-pc/
Nov 27, 2012 | Dell Inspiron 11Z (dndmit1) PC Notebook
I need the computer system password for #HRCFMF1-595B Dell LatitudeD630
To get more helpful info, u can search the method source:
Windows Password Reset Std/Windows Password Reset Pro/Windows Password Reset Deluxe,and have a try.
Follow my steps:
Step1:Download Windows Password Reset from http://www.windowspasswordreset.net and install it.
Step2:Burn Windows Password Reset ISO file to CD/DVD,or USB.
Step3:Put in your newly created CD and remove your Windows Password.
Hope it can help you reset windows password soon .
Jul 30, 2012 | Dell Latitude D620 Laptop (Latitude-C620)...
VERTICAL LINES ON MONITOR
The Dell LatitudeD630 has a 15 pin VGA port that can connect to an external monitor located
on the back of the laptop.
Jul 23, 2011 | Dell Latitude D810 Notebook
Need unlock code for dell latituded630
Hi, Check out the link to generate a new code based on the service tag of your computer: http://www.tech-faq.com/reset-dell-bios-password.html
Regards, Icom1
Dec 19, 2010 | Dell Latitude D630 PC Notebook
Slow, stalls, freezes up
If your hard drive is too full, then your computer is going to perform slower. Delete old files which are not required.
Remove programs that you are no longer using. Delete temporary files.
Empty your recycle bin. Right click on Recycle Bin. Click Empty Recycle Bin>Yes.
Run an error check on your computer. The error check can remove errors that slow down your computer. If you are using Windows, you can do this by clicking Start>My Computer. Right click on your hard drive (typically c:) and then select Properties. Click the Tools tab>Check Now and then Start.
Clean up your registry. You can purchase software that will fix any registry errors on your computer.
Perform this computer maintenance on a weekly basis.
Apr 24, 2010 | Dell Inspiron 1501 Notebook
BIOS PASSWORD UNLOCKER
go on youtube and and type the problem you havin now and you will find someone to help you in your area
Aug 28, 2009 | Dell Latitude D610 Laptop Computer -...
Slow downloading and slow general usage
If the computer has always been slow, then yes additional RAM will help. If you are running XP, 1 Gb or ram runs great, 2 Gb runs a touch better. If you are running Vista, I highly recommend moving to 2 Gb.
If the computer is generally getting slower and slower, then it just needs a tune-up/clean-up. I am assuming you are not computer savvy, so I would suggest calling a local computer shop. Ask them for a general cleanup service on your computer. Do not pay more than $100.
Jan 03, 2009 | Dell Dimension 4300 PC Desktop
I got a trojan and spyware viruses how can i get rid of them?
This one helped me rid my daughters computer of some nasty stuff. I recommend it.
http://housecall.trendmicro.com/
Nov 14, 2008 | Dell Dimension 3000 PC Desktop
Aio 922 does not scann
» Uninstall Existing Dell™ Printer Drivers
Before reinstalling any printer drivers, it is necessary to remove any printer drivers that were previously installed. Not doing so can cause problems that prevent the computer from communicating with the printer. To uninstall previous printer drivers:
  1. Turn off the printer.
  2. Disconnect the USB cable from the back of your Dell printer, click the Start button, point to All Programs, point to Dell™ Printers and then point to the listing of your Dell printer and then click the Uninstall Dell Printer icon.
  3. When the Dell Printer Uninstall confirmation window appears, click Yes. This process may take several minutes to complete. Do not attempt to power off the computer at this time.
  4. When the Dell Printer Uninstallation window appears (Figure 1), click to select the Yes, I want to restart my computer right now (recommended) option, then click OK. (The system automatically shuts down and restarts.)
    After the system restarts, the printer uninstallation process is complete.
new_note.jpg Note: Do not reconnect the USB cable to the printer until after you have downloaded and reinstalled the printer's drivers.
Back to Top
» Download the Printer Drivers for the 922 All-In-One Printer From Support. Dell.Com
  1. Click the following file name to download the 922 driver: 922ENA04.EXE. By downloading, you accept the terms of the Dell Software License Agreement.
  2. In the File Download window, click Save.
  3. In the Save in: window, click to select Desktop from the drop-down menu.
  4. Click OK.
  5. Click Close when the download is complete.
Back to Top
» Install the Drivers, Files, or Utilities
  1. Locate the file. It is usually on the Desktop or in the My Documents folder.
  2. Double-click the file icon and click Continue.
  3. In the Select the folder where you want to unzip the files to window, click OK.
  4. If a message appears asking to overwrite the folder, click Yes to All. If a message appears asking to create a folder, click Yes.
  5. In the All files were successfully unzipped window, click OK.
  6. Follow the prompts that appear to install the driver.
  7. If prompted to restart your system, click OK.
Jul 30, 2008 | Dell 922 All-In-One InkJet Printer
When typing, words skip and often scatter or stop
go to my computer icon, right click, properties>hardware tab>device manager, then lok down the list to keyboard, click on the + sign and right click on your keyboard and select uninstall.
Restart the notebook and the driver will automatically load again and should type as normal.
Oct 21, 2007 | Dell Latitude D600 Notebook
Dell Latitude D630 Notebook Logo
55 people viewed this question
Alun Cox
