Question about Kenmore Freezers
My Kenmore upright freezer is not working properly. Model: 253.9208212 Freezer still has power to it and the fan is still blowing cold air around but the freezer is nowhere near as cold as it should be. Settings is set at maximum and the freezer is three years old from date of puchace (New). What would be the cause and what can i do if i have options.
  • Kenmore Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 11, 2010
Kenmore upright freezer hot on the sides, stop freezing
Without the model number I'm not sure how to answer your question. Does your model have fans that blow warm air on the outside bottom or a front kick plate? What is your model number? Kenmore has model numbers like this example=> 123.3214567 If the fan has a restriction that causes a lack of airflow it can cause the hot Freon liquid that normally flows around the Yoder Loop inside edges of the freezer door to prevent frost buildup to become very hot because the condenser fan is defective or coils are dirty with dust restricting airflow. If the outside is hot you may have a defective condenser fan motor. That will cause the freezer to ger hot. I am here should you want my assistance....Sea Breeze
Kenmore Freezer Parts
Aug 31, 2013 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Freezer does not get cold enough to freeze the food in the summer.
I am assuming that you have it in a place where it gets hot in the summer.
If the freezer has a fan either in the back or at the bottom, make sure the fan runs, and the coils are clean. If the freezer has the condensor against the back wall you could help it by adding a small fan so as to blow away the hot air.
Jun 01, 2011 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore fridge over pullout freezer. Freezer has snow. Model 59673502201 . Fridge runs, and shuts off apparently normally. Freezer is cold, air blowing (fan?) from behind freezer temp control. Thought...
Please : - Clean up your freezer - set the thermostat to middle - check the fan for malfunction
There are many things that cause your freezer work abnormally.
Nov 07, 2010 | Kenmore Freezers
Freezer not cold enough and fan doesn't blow.
if door was left open for extended period of time it has probably iced up around the evaporator fan, try to defrost around fan area using a hair dryer
Jul 28, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer @ +28 deg/appears common problem B 1st 2 answer right....
Model numbers of Kenmore , starting with 253. are made by Frigidare . The compressor probably has a valve out , either the high-side , or low-side . Probably the low-side valve is bad , therefore , the high-side will pump but not get the freezer as cold as it should be . Both sides have to work . Low-side helps pull the refrigerant thru the system , while the high-side pumps pressure thru the system .
Aug 26, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Food in freezer is thawing, compressor very hot to the touch
It sounds like the motor to the circulating fan is wearing out . This fan is hard to diagnose as it will spin the blade , but as you said it will not spin fast enough to circulate air thru the freezer and refrigerator. The motor is DC non brush type. It will cost a minimum of $300.00 to repair/replace this fan assembly, but it is worth that compared to replacing the refrigerator
Jul 27, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer Not Freezing Food
there is a circulation fan and also a vent. Either the fan is blowing, or there is a cloged vent.
Feb 11, 2009 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Kenmore Upright 13 cu.ft freezer- uneven freezing
no it sound like there is a problem with the seal system where the freon is kept this model does not have a fan because is the shelves get frosted so there is a leak or restriction so try calling a tech but i would just buy a new if i was you since to fix will cost about the same
Nov 08, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore Freezer Model 23041
I have an upright freezer which temp was unstable. The coils were frosted up, and the circulating fan was unable to pull air across the cooling fins.I defrosted the unit, cleaned it up, and turned it back on. Worked fine until it frosted up again. The unit was a no frost model. I had to have it serviced, and one of the defrost sensors was bad. No problems since this was fixed.
Aug 13, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezers Logo
176 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
