Question about Health & Beauty
Viganal bleeding during vowel movement - Health & Beauty
  • 490 Answers
Please seek immediate medical assistance from a professional.
Posted on Oct 12, 2010
How do I break the work "exhibition" into syllables?
Have your program split the word into groups of vowels and consonants ie 'exh', 'ib', 'it', 'ion'. For example if the word starts with a vowel, in this case 'e', continue to group it until it reaches the first vowel (i in the 2nd group) after the group of consonants (x and h in the first group), and repeat.
Sep 26, 2014 | Computers & Internet
How do I divide the word meat into syllables?
Given your list of words, It appears to me that what makes up a syllable is the vowels in the word.. each time 1 or more vowels are separated by 1 or more consonants/symbols, a syllable is born.
so, have an array of characters containing vowels.
now iterate through the given word and create a new syllable(String) by adding the characters you are inspecting until you find a vowel.. now continue to add the vowels you find until you find a consonant/symbol.. that's where your new syllable ends (you can add it to a List if you want or just output it to the command line) ..and if you haven't gone through the entire word yet, create a new syllable(String) and repeat the process.
Good luck
Sep 10, 2014 | Computers & Internet
What is diphthongs
Diphthong (, literally "two sounds" or "two tones"), also known as a gliding vowel, refers to two adjacent vowel sounds occurring within the same syllable. Technically, a diphthong is a vowel with two different targets: That is, the tongue moves during the pronunciation of the vowel. In most dialects of English, the words eye, hay, boy, low, and cow contain diphthongs.
Apr 14, 2011 | Computers & Internet
Tell me any girl name without vowels ?
Hi.
Y is not a vowel. Names like Cyndy or Bryn have no vowels. If you decide that Y is a vowel, then the choice is restricted to very uncommon names (you can call a girl M, or RN if you want).
Regards.
Ginko.
Mar 08, 2011 | StumbleUpon Social Network
Replaced power boster master cylinder and brakes and the brakes are still spongy
Indicates air still in the system. I suggest that you start at the master cyl, remembering to keep it full during & after each attempt at bleeding the system and to only fill it by using a funnel & allowing the brake fluid run down the side to eliminate new air being put into the system.
Bleed the master cylinder first by loosening those lines while someone has pumped up the system & is holding the pedal to the floor. Make sure your assistant is not releasing the brake pedal before you are tightening the lines and that all brake pedal movement is done slowly, especially releasing the brake pedal. It causes fluid to rise into the air, bring air back into the fluid.
Next, go to the farthest brake away from the master cylinder & bleed it, working yourself to the next farthest until you finish with the closest brake. This prevents air from switching lines on you during the process.
If there are no leaks & you have followed this method, there shouldn't be any air in the system & your brakes should be good.
good luck
Feb 15, 2010 | 1996 Chevrolet Monte Carlo
Write a program for analyzing which of severaol diff.vowels ,cont
# Since no language was specifiec, here's a solution in the
# gawk dialect of awk.
# Familiarity with awk is assumed, so only minimal comments
# are present. I have a version with more comments...
BEGIN {
IGNORECASE = 1
{ r0 = $0 } # Copy the input record into the variable r0, for efficiency
wc += gsub(/[[:blank:]]+/, "", r0) {} # Destructively count all the white spaces in r0
vc += gsub(/[AEIOU]/, "", r0) {} # Destructively count all the vowels in r0
cc += gsub(/[BCDFGHJKLMNPQRSTVWXYZ]/, "", r0) {} # Destructively count all the consonants in r0
END {
printf("%d vowel%s\n", vc, (vc != 1) ? "s" : "")
printf("%d consonant%s\n", cc, (cc != 1) ? "s" : "")
printf("%d white space%s\n", wc, (wc != 1) ? "s" : "")
Jan 02, 2009 | Computers & Internet
I need a program in turbo c that would count the vowels in the sentence using for loap
Here's an example:
//This is the array of characters that holds your sentence.
char YourSentance[];
//This is all of the Vowels, note that capitol and lower case are
//considered different.
char Vowels[]={'a','e','i','o','u','A','E','I','O','U'};
//This holds the counter of how many vowels we find
int NumVowels=0;
//Loop through the Sentence using i until we encounter a 0
//which signifies the end of the string
for(int i=0;YourSentance[i]!=0;i++) {
//Now loop through the vowels
for(int x=0;Vowels[x]!=0;x++) {
//Check to see if this character is a vowel
if(YourSentance[i]==Vowels[x]) {
//If it is, increment NumVowels, and end the loop early
NumVowels++;
break; // This line optional
//Now NumVowels contains a count of how many vowels
//we found
printf("There are %i vowels in the sentence.\n",NumVowels);
Feb 29, 2008 | Computers & Internet
Program
I wrote this as a vbscript. It's Visual Basic code in windows script. If you have XP, just copy the text into notepad and save it as "vowel.vbs". Now double click the newly created script file.
' vowel.vbs
' This VBScript is used to count the vowels and consonants in a string.
' Designed and Tested on Windows XP Pro SP2
' Version 1.0.0 - 02.20.2008
' This code may be freely distributed or modified.
Option Explicit
Dim str
Dim vowels
Dim consonants
Dim i
vowels = 0
consonants = 0
str = "hello"
for i = 1 to len(str)
select case mid(str,i,1)
case "a"
vowels = vowels + 1
case "e"
vowels = vowels + 1
case "i"
vowels = vowels + 1
case "o"
vowels = vowels + 1
case "u"
vowels = vowels + 1
case else
consonants = consonants + 1
end select
next
msgbox "Vowels = " & vowels
msgbox "Consonants = " & consonants
'End of script.
Feb 21, 2008 | Computers & Internet
Hi........
' vowel.vbs
Option Explicit
Dim str
Dim vowels
Dim consonants
Dim i
vowels = 0
consonants = 0
str = "hello"
case "a"
vowels = vowels + 1
case "e"
vowels = vowels + 1
case "i"
vowels = vowels + 1
case "o"
vowels = vowels + 1
case "u"
vowels = vowels + 1
case else
end select
next
'End of script.
Feb 21, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Health & Beauty Logo
82 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
