Question about Frigidaire 24 in. FDB510LC Free-standing Dishwasher
The top jet washer in my dish washer is not rotating and cleaning my dishes. The bottom is working well. I am just wanting to know what the problem might be.
  • Frigidaire Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Mar 27, 2011
There are no error codes showing, water is definately getting hot but dishes on bottom tray not cleaning, i have used few products specially designed to clean the dishwasher itself without any dishes in,...
Check that the arms spin freely when spun by hand, then check the outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the upper dishes do not get enough water and chemicals. .
Jun 18, 2011 | Baumatic 23 in. BDW13 Built-in Dishwasher
Dishes and glasses on the top rach are not getting clean-bottom rack is fine.
Check that the arms spin freely when spun by hand, then check the outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the upper dishes do not get enough water and chemicals. It may also cause water to continue dripping onto dried dishes after the the drying cycle has stopped.
Jun 14, 2011 | Kenmore Dishwashers
GE Dish Washer GSD 2800 DO3 runs a partial cycle...(even empty) and then beep and gives a message on control panel "washer arm blocked". Even ran without dish rack in washer still got the...
the rotating arm has a magnet in it to let the controls know if it is turning. Yours is not turning so
  • check the jets for blockages... you might have to remove the arm to clean them properly
  • make sure there in nothing stopping the arm from turning...spin the arm manually to see if it rotates freely.
  • knives etc sticking upward can stop the arms from rotating on the top rack
  • if you run without the rack the arm will obviously be not telling the electronic it is not blocked because it is not there. the rack must be in the machine with the magnet and the magnet passing correct messages.
  • If there is really no blockage then there is a elect fault that need to be sorted professionally.
  • PS have you taken the arm off anf squirted a hose up the inlet to see if water comes out all of the jets????
Mar 01, 2011 | Dishwashers
Bottom sprayer does not clean or work, all items on bottom are the same as put in. Top is fine. runs through whole cycle.2 hr 29 min
Check the free rotation of the spray arm. If arm jets are clogged clean them.
After placing the dishes see to it that, the arm is freely rotating without any obstacles.
May 20, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Top rack dishes have a white gritty residue on them. i use washer cleaner and jet dry and it does not help. i don't know if there is filter to clean or not . what do i do?
Check whether the top rackspray arm is moving freely. Check the jet holes and remove clogs if any.
Hope the bottom rack is good in wash quality!
Apr 12, 2010 | KitchenAid 24 in. KUDG25SH Built-in...
My maytag mdb8600aws jet clean 2 only cleans dishes in bottom
The seals that the racks "plug" into need replaced. Ours had the same issue and replaced the seals and it works fine now.
Nov 23, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
MY KITCHENAID DISH WASHER TOP SHELF IS NOT CLEANING AT ALL .
There may be something plugging up the arm that sprays over the dishes. And of course, I'm sure you know not to place items like bowls, pots, etc that will block the flow of water from the bottom sprays.
Although the bottom jets do most of the working cleaning the top items, the spray from above is vital. Take the stem pipe leadin from the top to the bottom off and separate the spray arms carefully. If you can, look throgh each end to make sure no deposits are in there.
Another way is to blow compressed air from the center stem down in the water supply unit. If food particles are there you'll see them.
May 14, 2009 | Jenn-Air JDB6510 Built-in Dishwasher
GE dishwasher GSD2200G00WW dishes not clean
Make sure the spray arm is actually rotating and the jets aren't clogged. You should be able to hear the arm rotating when the dishwasher is operating.
Otherwise, perhaps the pump is plugged or not working and the water isn't "jetting"
Sep 06, 2008 | GE Nautilus 24" Built-in Dishwasher
Wont clean dishes
Check to see if the Upper and lower spin arms rotate easy .. check to see if there is anything blocking them.. also check the venturi assembly (the tower is in the center of the lower spray arm} As it is what supplies the upper spay arm. let me know if this helps?
Mar 06, 2007 | Zanussi 24 in. DA6141 Built-in Dishwasher
Frigidaire 24 in. FDB510LC Free-standing Dishwasher Logo
143 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
