Question about Kohler 12 kW Emergency Power System - 12RES-L
Generator won't start. Screen showing OC. - Kohler 12 kW Emergency Power System - 12RES-L
  • 81 Answers
OC means OVERCRANK safety circuit stopped the auto start-up so you wouldn't burn up the starter. There is a reason the generator didn't start. Low battery, not enough fuel pressure, clogged air filter, bad starter... You just have to eliminate as many as you can visually. Rebooting the generator should clear the OC condition and you can try to start it manually.
Posted on Oct 11, 2010
Kohler 12.5 res gen. Battery is good. Get OC code. If I reset auto switch by clicking off, then clicking run, then clicking auto it will start. Any thoughts on this issue?
OC is Over Crank which generally means it cranked and cranked and failed to start. Turning the switch off and on again is the way to clear the fault. How long is it taking to start whilst cranking? It should start within 8 seconds
Sep 11, 2013 | Kohler Electrical Supplies
Kohler 12RES only starts on second try
Check gas pressure. Oc is over crank. Means tried to start but did not.
Nov 25, 2012 | Kohler 12 kW Emergency Power System -...
The generator has stoped working after runing about 9 hours
Check what fault was logged on the controller and address the fault from there. Also note that the generator will not operate automatically at all if it is out on a fault until the problem is addressed and the unit is reset and put back in automatic. On the 18 open the top cover and the fault should show up as a 2 digit abbreviation and the definition will be defined just below it on the sticker.Such as OC is overcrank which means it tried to started but failed possibly due to lack of fuel or LOP is low oil psi, usually means it burned all the oil out of the crankcase.
Jul 12, 2011 | Kohler 18RESL 18 kW Emergency Power...
Have Kohler 12RES. Gives a CC1 code thenan OC code. Have checked out the starter, it's OK, have cleaned all ground cables and connections and had the battery tested it's OK. Where do I go next?
check your load wires there probaly reversed. I had the same problem friday. The week before the electrican wired it. did the same cc1 then oc. had a generator company come out it was the wireing. my load and netural were reversed.
Sep 07, 2010 | Kohler 12 kW Emergency Power System -...
I have a Kohler 12RESM1 propane generator with oc/uu code
U need to make sure that the relay driving ur auto start stay closed all thru the crank cycle.
Feb 04, 2010 | Kohler 12 kW Emergency Power System -...
When I try to start my generator the code oc comes
Check battery volatge while you are cranking engine if voltage drops below 9 vdc you have a bad battery. If it doesn't you probable have a bad starting solenoid or a bad ground at the starting solenoid.
Nov 11, 2009 | Kohler 12 kW Emergency Power System -...
My 2000 monte carlo isnt showing the temperature in the screen
Replace the ambient air temperature sensor.
Above the left side of the grille is where the sensor is located. You will have to remove the grille to replace the sensor.
Jul 22, 2009 | 2002 GMC Envoy
Hello, I have a Kohler Marine Generator that says OC on the menu when I try to start it. Any ideas?
OC stands for Over Crank. How long does it take before the genset starts?
Apr 20, 2009 | Electrical Supplies
Kohler 12 kW Emergency Power System - 12RES-L Logo
1,216 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
