Question about Barska Optics Optics
:barska 6/24/44 will not zoom : is stuck on 6 power :
I want to know if my barska telescopes atainable power is 600 what planets can i see and how good would the imag be??
Telescopes that are advertised as having powers of 300, 500, 600 or whatever are scams. You will not be able to see anything but dim blurs if you attempt to use them at such magnifications.
There is a good website for telescope beginners that explains the issues clearly at THIS LINK
Feb 05, 2011 | Barska Optics Optics
What do the numbers 10-30X60 mean?
The numbers on binoculars in the form 00x00 are the power and the diameter of the objective (the main lens). A common one is 8x30, for small binoculars of 8 power and an objective 30mm in diameter.
10-30x60 is a bit more complicated. The diameter of the objective is 60mm, but the first numbers with the hyphen indicate a range of powers, from 10 to 30, because these binoculars have a zoom feature, giving variable power.
In my view, zoom on boinoculars is a gimmick. It isn't useful in practice, usually giving too much magnification to be useful at the high power end, and the complication it adds to the optics means that the image is not as good as with simpler binoculars of similar quality.
Dec 10, 2010 | Barska Optics 10-30x60 Gladiator Zoom
How do I adjust the magnification for my Barska 4x28 electro sight rifle scope?
in a word you cant,,,,,its a 4x28mm so its a fixed scope at 4x's mag with a 28mm lens
Nov 27, 2010 | Barska Optics BARSKA 4x28 Electro Sight IR...
Cant find out where to chang the batteries
Go to Barskas service/help desk, their Email; service@barska.com , they are in California and are quite helpful.
Good luck. :)
Apr 18, 2009 | Barska Optics Barska® 50 mm Red Dot Scope...
How do you use mildots on a Barska 10-40x50 varmint scope?
One Milliradian (mil dot) is one onethousandth of a unit (1000 yrds its 1 yrd, 1000m its 1m)
for a more indepth explanation visit this site :)
www.shooterready.com/mildot.swf
GL
Apr 04, 2009 | Barska Optics Barska 10-40x50 Ao Varmint...
Recoil from 300WSM
Well, it Barska says it's .50 cal proofed, whatever that means. One would presume it could take 30 magnum recoil then.
On the other hand, Barska is a low end quality manufacturer. You cannot expect durability in a low end scope. Of course, you could get lucky.
Unless you're target shooting at an immovable object, 10x - 40x is much more power than you'll ever be able to use. You're much, much better off considering a 4x - 16, for instance, in a higher end scope line than this scope.
Consider that at 40x the exit pupil would only be 1.25 which would make even the highest quality scopes quite dim. Barska won't have be best glass in the world and so would probably be unusable beyond some level like 18x unless in very favorable conditions anyway.
The problem with heavy recoilers and scopes is that the heavier the scope the more likely it is to take damage due to recoil. It's because it hangs out there on those high scope rings, and is heavy.
Nov 06, 2008 | Barska Optics Barska 10-40x50 Ir Swat...
Barska Reflector telescope 70076
Sorry only a Barska dealer would have one of these-- none are located on the internet.
Sorry-
www.telescopeman.org
www.telescopeman.us
Apr 06, 2008 | Barska Optics Barska AE10104 - 70076, 350x...
Zoom is stuck
Just check the DC power supply flowing to the Lens block control. Some times the SMD fuse blows off and power may not reach the lens block motor.
Dec 02, 2006 | Sony Handycam DCR-PC105 Mini DV Digital...
Optics Logo
Top Barska Optics Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
xalint1
xalint1
Are you a Barska Optics Optic Expert? Answer questions, earn points and help others
