Question about Bunn GRX-B
Don't understand how it works, given it by a friend. no instruction maunal with it, I put in 10 cups of water and truned on the switch and nothing is happening?
  • 35 Answers
Http://www.retrevo.com/support/Bunn-BX-Coffee-Makers-manual/id/3878ci356/t/2/
You can download a manual here I believe.
Posted on Oct 13, 2010
  • 1 more comment
  • ocean723 Oct 13, 2010
    manual never pulled up.
  • trewly617 Oct 14, 2010
    I can run over the general instructions for you.
    -BEFORE plugging in, with a pot in place under the filter basket, pour through enough water until it flows from the basket.
    -Then (and only then) is it safe to energize the heater inside.
    -Once the brewer reaches brewing temperature put your coffee in the filter and pour through one pot of cold water and brew.
    As recommendation I would say to pour through a little water before brewing in the morning (or anytime the brewer has sat overnight) as there may be some short potting due to evaporation. This will also assure that you are getting fresh water in your brew. This brewer has a reservoir that holds probably 2 or so pots of hot water. If the heating element is energized without water there is a good chance of burning up the heating element.
  • trewly617 Oct 20, 2010
    Did the other suggestions help you out?
How to activate a 10 cup bunn coffee brewer model nhb?
I don't understand the question, but here is a try.
1 - put in two pots of water.
2 - put in third pot, the water should start coming out
Allow the water to heat (thirty minutes) then put coffee in filter housing, put in one pot of water, put empty pot on warmer, close lid, wait for brew cycle, enjoy coffee.
Feb 27, 2015 | Bunn 10 Cup Home Coffee Brewer
The machine will not pump water to make cup of coffee. Cleaned needle area, powered on and off, nothing. The descale light has never come on in 3 years we have had machine. Can't even attempt to descale...
Step 1: Lift up the water reservoir and drop it back into place. There is a magnet that has to be in the right position and putting the reservoir back into place causes it to go back where it should be. This method has worked for me.
Step 3: It could be that your Keurig's water line is clogged. To flush out debris, run water through your brewer a few times without a K-Cup. I'd recommend this step if your Keurig is brewing some coffee, just not a full cup.
Step 4: Try turning the power on and off or try unplugging (for a long stretch if you can). When you turn the Keurig back on, be sure to give it plenty of warm-up time. This has also worked for me.
Step 5: It may be time to descale. Most models will give you a message when it's time to have the mineral deposits cleaned. Go here for instructions
Step 6: Turn off your brewer and use an unfolded paperclip to clean out the holes in the top needle.
Step 7: If you've given your Keurig a good spanking and it still won't behave, contact Keurig (866-901-BREW) for help.
Oct 04, 2013 | Keurig B60 Coffee Maker
Fridge part freezes up , lost manual cant work out what the on/of switch is meant to do?
If this was my fridge
1 I would give it a soft kick with my right foot/ your left
2 nothing happens
3 empty the fridge
4 push the off switch
5 should the unbeliveable happen that the frozen part would start to melt
6 then I put some boiling water in a wash basin in the fridge and a few towels on the floor-we don´t want water on the floor, do we?
7 when all the "frozen places" have disapperaed .
8 clean the fridge´s insides
9 push the on button and close the door properly
10 wait for 30 min open again and see if the places that are supposed to be frozen arn´t frozen
11 if they are put the good things back into the fridge
12 and have a good cup of coffee
Good luck
kollagunn
Jun 04, 2011 | Freezers
Chefmate rice cooker instructions 10 cup
if you put a 10 cups of a rice rinse it first before you add a water , the measure of the water is equivalent of the cup of the rice.now,put 10 cups of water. then put it on the rice cooker, then press rice cooking, it is automatically turn to "keep warm" after it's getting boiled. wait for about 45mins of cooking.thanks.
May 07, 2011 | Microwave Ovens
I have a 5 cup riceperfect cooker, how much water to rice do i need
I also had problems deciding how much water to use - the measuring cup that came with the machine was not user friendly! I just use twice as much water as rice and it works fine. ie. - 1cup rice and 2 cups water I have a different model of cooker but a friend had the same issue and uses the 2/1 ratio and it works fine for her also. Good luck
Oct 16, 2010 | Wolfgang Puck BDRC0010 10-Cup Rice Cooker
Plastic cup lost, how much rice shall I measure?
I learned that the measure probably held 200 ml, and will experiment to confirm.
Apr 10, 2009 | Hitachi RD6106 10-Cup Rice Cooker
Whay is the coffee to water ratio per cup?
I have the Regal 10 to 30 cup model K7030C.
Instructions read as follows:
CUPS COFFEE
(5-oz serving) ( 8-oz dry measure)
10 ........................2/3 Cup
20.........................1 1/4 Cups
30.........................1 3/4 Cups
Hope this helps
Mar 06, 2009 | Regal Ware (RW58230R) 30-Cup Coffee Maker
Instructions/Manual needed
all rice cookers are the same 2:1 that is 2 cups water and 1 cup rice .... i like my rice fluffly so i allways add a 1/4 cup extra water . dont forget to put cover all the time its cooking and only open to stir
Feb 23, 2009 | Homesmart HRC-10 WI Rice Cooker
The Hitachi has notches on the inside of the pot. You put your rice in the pot and than start adding water until your water level reaches the notch labeled 7. Remember that the rice has to be inside the pot when you start adding water so that you will have the correct amount of water for the rice you're cooking. It doesn't work the other way around. Rice in pot than add water. But usually the average cup that comes with these rice cookers only holds 3/4 of a cup when you fill them to the top.
Jul 09, 2008 | Hitachi RD6106 10-Cup Rice Cooker
Lost rice cooking instructions
From the users guide for the 550 FOR BROWN RICE RICE: 2 half cups WATER: To 2 mark, plus 3/4 cup TIME: 32 minutes MAKES: 2 cups RICE:4 cups WATER: To 4 mark, plus 3/4 cup TIME: 39 minutes MAKES: 8 cups Here are the rest: 6 cups To 6 mark, plus 3/4 cup 44 minutes 13-1/2 cups 8 cups To 8 mark, plus 3/4 cup 48 - 49 minutes 15 cups 10 cups To 10 mark, plus 3/4 cup 51 - 52 minutes 21 cups Here is a link to the user guide for all the instructions. http://www.blackanddeckerappliances.com/dyn/prod/user-guide/139/RC410%20RC550.pdf
Jun 22, 2007 | Black & Decker RC550 10-Cup Rice Cooker
Bunn GRX-B Logo
289 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
