Question about Kodak EASYSHARE M1063 Digital Camera
As soon as i turn it on it immediately turns off again, what can this be? the lens comes out and goes back to the initial position, please help me? Kodak M1063
  • 144 Answers
Your battery could be bust and needs to be replaced
Posted on Oct 11, 2010
Camera can't take photos
Most of the time, when a camera asks to shut down there is a problem with the camera. Could be the lens can't come out complete or other, almost invisible things. Even the battery can be a bit low, so as soon as it wants to make the camera ready to "shoot" the voltage goes low. Lots of cameras, will go off then. If you can't find any obstruction on the lens, please charge the battery and try again.
Nov 27, 2013 | Panasonic Lumix DMC-LS70 Digital Camera
My camera turns on then turns right back off again?
Same thing happened to mine, and it had to be sent away for repairs.
May 07, 2017 | Kodak EASYSHARE M763 Digital Camera
As soon as i turn it on it immediately turns off again, what can this be? the lens comes out and goes back to the initial position, please help me, its a kodak easysharev1253 hd
Your problem is likely due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may be due for replacement, or the camera may have a problem that requires professional repair.
Dec 05, 2009 | Kodak EASYSHARE M1063 Digital Camera
My lens is stuck in everything eles is fine
Please try initializing the Camera to resolve the issue.
First, please press the HOME button on the Camera to display the home screen on the LCD screen of the Camera.
Then, select the "Settings" option and then select the "Main Settings" option on the Camera.
Now, select the "Main Settings 1" and select the "Initialize" option and press the middle of the control button to initialize the Camera.
Then, select "OK" and press the middle of the control button to initialize the Camera. If the issue still persists, it is required to service the Camera.
Nov 24, 2009 | Sony Cameras
Power immediately turns off with lens out and flash open
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
Aug 29, 2009 | Kyocera Finecam S3R Digital Camera
Lens error message on nikon coolpix L18 I purchased my Nikon L18 Cool Pix camera last September ('08). Last week when I turned it on, the lens extended fully, then retracted fully as I got a "lens error"...
When system control does not get lens initialize signal while extending it, then it try again by folding it and extending and still no required initialize signal then generate error and stop further functions.
Please remove battery and open camera and remove flexible wire of lens mechanism from connector, there would be lock that needs to release to remove flexible wire. Clean wire terminals with alcohol, let it dry and put back flexible wire in connector and lock it. Now put battery and power camera up, hopefully lens will work properly.
Hit "add a comment" button for further query / info.
Thanks.
May 01, 2009 | Nikon COOLPIX L18 Digital Camera
Goes off after lens come out.
Get it repaired under warranty. Sounds like a logic circuit problem.
Dec 10, 2008 | Pentax Optio S50 Digital Camera
Camera won't turn on
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.
Hope its helpful to you
Sep 26, 2007 | Samsung Digimax L60 Digital Camera
Kodak EASYSHARE M1063 Digital Camera Logo
199 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
