Question about Magic Chef Refrigerators
I can't find a model # on refrig. and part # on thermostat does not show up in search
  • 4,066 Answers
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
Thermostat or temperature sensor seems defective
you might be right, its either your thermostat or your defrost timer. take down your model number and look up your part you need..Hope this helps you
Feb 18, 2013 | Amana Refrigerators
Refrig is not cooling at all. thermostat controller light shows two lights on the frezer side of the display, 5 and 6. the refrig display shows nothing and i can't change it. please help
ok,do as i say
Keep your hands on the side panel of your refridgerator and see whether its hot,if its not its due to low gas ,fill it up with the help of some skilled persons
Mar 28, 2012 | LG Refrigerators
Refrig will not syay cold Only 6 months old
Good day,
Not your problem. The machine carries a full one year warranty on all parts.
Call Sears for a warranty service call.
Feb 05, 2010 | Kenmore Refrigerators
Have 8550510 Kenmore Refrig that stopped running.
Sounds like the thermostat is bad . Without the complete model number , including the first 3 numbers , such as 110. , 106. , 253. etc , I can't tell you how to access it . If you can get access on your own , jump the 2 wires connected to the thermostat , and see if the compressor cuts on . If so , replace the thermostat .
Oct 20, 2009 | Refrigerators
Whirlpool Model ED5SHAXML12 is freezing food in refrigerator even when dial is at off. Happened from one day to the next.
At the refrig controls , the freezer control , controls how much air goes into the refrigerator section . Open the refrig door , and up at the top left , put your hand over the damper (air vent) . Turn the freezer control from high to low , and feel the difference in the air flow . If you turn your freezer control to a lower setting , less cold air will enter the refrig . Think of it as : the freezer control adjusts the temperature , and the refrig control , tells how long to run the compressor . In actuality , this is how it works . However , with the dial (refrigerator thermostat) in the off position and refrig still running , this indicates a bad thermostat . Pt # 2198202 .
Sep 09, 2009 | Whirlpool Refrigerators
M# 596.72219200 Kenmore with bottom drawer refrig keeps freezing
That is a broken thermostat control part number 67003000 when they stop they can break while on or off. Sea Breeze
PART NUMBER AND MODEL SEARCH FEATURE
Jul 23, 2009 | LG LSC26905TT Side by Side Refrigerator
Refrigerator section on side by side losing cooling
Here is the Amana website with the manuals which should show you where the defrost timer etc. is located. Witht your model number and manual it will be a lot easer
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=AMA
And yes the defrost timer thermostat and heater are the most likely problem.
Do not let this keep running and running or you may lose your compressor too which means a lot more expense than now.
May 09, 2009 | Amana Refrigerators
Refrigerators Logo
32 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
