Question about Nikon Coolscan LS 50 ED Film Scanner (35 mm)
My scanner is not being recognized by my PC. I have been using a Windows XP PC to support my slide and negative scanning. The scanner was last operational in the spring of 2010. Several months later when I tried to use it I started receiving cannot find the hardware type messages. I have changed USB cords and tried to connect it to two other PCs and none of them recognize the scanner when attached and then turned on. I have tested both USB cords and connection points on other USB devices and they are not the problem. I believe something has happened to the USB connector within the scanner. I value your thoughts and/or input on how to get it fixed.
    Top Expert:
  • Nikon Master
  • 48,384 Answers
Try right clicking on the unit , click on properties, click on compatibility, tick box click on win xp, apply and ok
next click on details , drivers , update drivers
it will be a communication problem that has occurred in the programs between the scanner and the winxp operatibg system
Posted on Apr 06, 2017
SOURCE: Nikon Scan doesn't recognize scanner
You need to check that the ASPI drivers are loaded, otherwise it will not work. The LS-2000 works with Adaptec ASPI v4.71. These drivers do not come with the Nikon product.
Posted on Aug 07, 2008
  • 48 Answers
SOURCE: dell laptop wont recognize ls2000 scanner
The LS-2000 is a "legacy" device to XP and the Nikon software. It needs to be connected to a true SCSI bus adapter, and it's actually pretty finicky about which ones will work in XP. Sorry, you won't be able to use this with your laptop.
Posted on Mar 21, 2009
  • 48 Answers
SOURCE: nikon scan was unable to find any active devices
The LS2000 is older than XP and has some fairly tight requirements to work. The recommended SCSI adapter is an Adaptec 2906, and you will probably need to backrev the ASPI layer driver files to version 4.7 (available on site). You may need to boot in Safe Mode to remove the later versions of the ASPI files before you can install the 4.7 files. You will also need to update your Nikon Scan software to version 3.1.2, available online by googling "nikon scan 3.1.2".
Posted on Apr 04, 2009
  • 39 Answers
SOURCE: After the flood I lost my manual and installation
Here is the link to the full software package for xp.
And here is the link for the manual.
Posted on Oct 24, 2009
  • 4924 Answers
SOURCE: I am using a Nikon
try to see if the scanner is present in the device manager and if it is ,,to be installed and not in yellow,,
if a driver for windows wasn't provided it means that the driver is included in the software try to update it and be sure that it is the one suitable for the operation system you use..
Here is the support site where you can check and read all trouble shooting issues that may occur ...
cause the error specifies that it is a hardware related error ..I think that it worth to go to bios of the pc...and activate the feature called optimal factory defaults...and after that save all changes by pressing F10
The thing that I try to underline is that may be a problem with a disabled bus...if it uses a firewire..or another like thi s..and the action will enable all buses if they were disabled by default or other causes..
Posted on Aug 16, 2010
Will not recognize 5th image on negative strip because 4 and 5 overlap (slight double exposure). How do I scan 5th image?
I inserted my negative holder in backwards on my Nikon 5000 35 mm scanner. Then I could get the last (5th) slide scanned. But I can not get the scanner to work on my new IMac because of no working driver. Silver Fast has no drivers for the Nikon 5000
Jun 16, 2011 | Nikon Super Coolscan 5000 ED Film Scanner
I have one of your Brookstone iConvert Slide and Negative Scanner, item # 598581. I have had it for awhile and when i finally wanted to install the software last month, it did not work. The software is for...
I have one of these scanners. I scan my slides to a SD card, put it in the slot in my Gateway computer and copy the files to a folder on my computer. Some pictures need fixing for color balance. I use Photoshop Elements to make the necessary adjustments..
Jan 17, 2011 | Computers & Internet
Driver for 5470c scanner will not work with windows 7
Hi ,
Scanjet 5470c does'nt work under W 7 . No drivers available .
Here are a few hints :
1° hint :
Do not connect scanner .
Load XP driver ( yes , XP) , reboot , connect scanner and wait for confirmation of successfull operation .
Reboot .
Dowload and install FreeKapture ( yes , it's free ) from
Open Freekapture , clic on Scan and select WIA-Hewlett-Packard . Scanjet 4470c works fine in this mode but if you choose HP PrecisionScan Pro , program will hang .
In any case , no slides or negatives scans possible but the rest works .
2° hint :
If you have the W XP install disc , you could install a virtual version of W XP on your HDD ( ) You could also partition your HDD ( ) and install W XP on the new one . Regards .
Jan 06, 2011 | HP Scanjet 5470c Flatbed Scanner
Cannot connect hp scanjet 4470c to windows 7
There is no driver for this scanner under W7 but I succeeded to make it work this way :
Make sure driver XP ( yes , XP ) is correctly installed . Then , go to and install FreeKapture , it's free .
Load FreeKapture , clic on Scan and select WIA Hewlett-Packard . Scanner works fine in this mode . If you choose HP PrecisionScan Pro , program will hang .
Regards ,
Nov 27, 2010 | HP Scanjet 4470c Flatbed Scanner
Please, how do I install my flatbed mercury scanner 1200cu+. I cant find my installations disk
I found an Windows XP driver here: The documentation for the Mercury KOB 1200cu+ scanner indicates support for Win 98se/Me/2000/XP. On a newer Windows OS, it may not work but you can try and see if a generic scanner driver installs when you plug it into the computer. If it is recognized, scan using Windows Fax and Scan (File, Import from Scanner) or Paint (Import from Camera or Scanner).
I hope this helps.
Dec 16, 2009 | Mustek Be@rPaw 1200CU+ Flatbed Scanner
Konica Minolta Dimage Scan Dual IV won't scan slides properly
Forget about the Minolta software. It's buggy at best. Use VueScan instead. A free trial is available so you can test it before you commit to buying it. Available for Windows including Vista.
Jul 08, 2008 | Konica Minolta Dimage Scan Dual IV Film...
Scanning negatives
Are you saying
The scanner worked with negative with XP but not with Vista?
Uf so this is a drver problem
Two thing to try- 1, Go to Programs/Accessories/system Tools Compatability Wizard and rest to XP then try.
Or 2 Google for suitable Vista Driver
Jun 11, 2008 | HP Scanjet 4070 Flatbed Scanner
I have the same problem (on XP, Nikon Scan 3.1.2) ... IF I turn the scanner on before the computer (or turn the scanner on and then reboot) then Nikon Scan recognizes it. Can't say I'm happy with the solution, but it works consistently for me.
Apr 18, 2008 | Nikon LS 2000 Film Scanner
Unable to use film adaptor
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
1) In the program you are working from, begin the scanning process. If working in full auto mode, as the scan begins you will see a message that reads TO CANCEL SCANNING IN FULL AUTO MODE AND SWITCH TO MANUAL MODE, CLICK CANCEL. At this point, click CANCEL, then MANUAL MODE.
2) You will now see all Epson Twain settings displayed. If the scanner has not previewed automatically, click the full page preview button (icon of a paper with one corner folded down).
3) Ensure the settings on the right hand side of the Twain are correct. For example, the DOCUMENT SOURCE for transparencies must be either TPU: COLOR NEGATIVE FILM, TPU: MONOCHROME NEG or TPU: POSITIVE FILM.
FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes. (If you are scanning a black and white slide in true colors, choose TPU: POSITIVE FILM as the DOCUMENT SOURCE and BLACK AND WHITE PHOTO as the IMAGE TYPE.)
If the DOCUMENT SOURCE is flatbed, the scanner will not activate the backlight in the transparency unit. If the DOCUMENT SOURCE is greyed out and you cannot select a TPU option, close the twain, reseat the power/communication cable connecting flatbed to TPU, then re-open the twain and try again.
4) Ensure the other twain settings are correct for the type of scan you are doing.
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no guidelines on this; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing an AUTOMATIC THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, click the CONFIGURATION button and uncheck AUTOMATIC THUMBNAIL PREVIEW FOR FILM, then OK, and try the PREVIEW button (page with corner folded down) again.
In this mode, you will have to manually marquee or crop the slides you wish to scan. Use the left mouse button to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process (manually crop then scan) for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Aug 16, 2007 | Epson Perfection 1200 Photo Flatbed...
Pacific Image 1800u scanner and XP pro compatiability problems ?
If it is loaded and running then that side is OK. It seems to be a firmware breakdown in the scanner. Checkout the makers website
Jul 31, 2007 | Pacific Image PrimeFilm 1800u Film Scanner...
Nikon Coolscan LS 50 ED Film Scanner (35 mm) Logo
Top Nikon Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
