Car Audio & Video Logo
Posted on Oct 11, 2010
Kicker zx350.4 protect light red and blinking
3 Related Answers
Anonymous
  • 807 Answers
  • Posted on Mar 17, 2008
SOURCE: blinking protection light on mrv-t757 amp
Could be the power supply or output stage electrolytic capacitors.
Possibly breaking down/drying out inside.
Anonymous
  • 22 Answers
  • Posted on Mar 27, 2009
SOURCE: protection light just blink on and off
check that your ground wire is connected properly to both your amp and body of vehcile you may need a thicker earth wire
Anonymous
  • 99 Answers
  • Posted on Jan 04, 2011
SOURCE: MY KICKER ZX 750.1channel amp "FLIP FLOPS" from
Are you getting any sound output at all from amplifier?
Is there a popping or banging coming from speaker?
It could possibly be a faulty output mosfet that is ocillating cause DC to leak onto the speaker output causing it to flip into protect.
please advise
thanks,ben
2helpful
2answers
Kicker amp powers no audio all connections made properly
Is this the first time installing it or have you had it a while and it suddenly stopped playing ?
2helpful
2answers
I have a kicker 500.2 red protection light is on and red light on top of amp flashes every couple seconds. Have checked all connections and other amp in truck works good. I bought two of these amps and...
Disconnect all the wires except the three main power wires, ground, 12v battery and remote. Now, turn on your radio, if the protect light is still on then there's an internal short in the amp. If the light turns green, then there's a short in either the auxiliary cables or the speaker outs. If it turns green, then troubleshoot the other wires that plug into the amp by connecting them one at a time until the protect light comes on, which will tell you that there's a problem with that speaker/aux wire.
4helpful
2answers
MY KICKER ZX 750.1channel amp "FLIP FLOPS" from protected mode(red light) to normal (green light) every 2 seconds.
please advise
thanks,ben
No sound no protection light
u must have a faulty wire...recheck youre instalments....or get a professional to do it for you..
2answers
Kicker zx1000.1 green light flckers and the turns red and then does the same thing over and over
seems like a protection feature kicks in and out
check your fuses and possible but a bigger size in and also check your wires make sure your ground is tight
1helpful
My kicker zx 750.1 amp is not working.
that is protection built into the amp. try turning down the gain levels on the amp
Blinking protection light on mrv-t757 amp
1helpful
2answers
Amp Power LED Display blinks red and no sound
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. Does the voltage on either the B+ or remote pulse below ~11 volts when the LED flashes?
Top Kicker Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
