Question about Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50 blinking "Err" message
I have a 2yr old nikon D50. Last September it worked great. I tried it recently and I am getting an blinking "ERR" message. I took it to a local camera shop and they tested the lens and the battery. They are charging me $185 to fix it. This is my fourth Nikon and I am very disappointed because it is the most expensive one I own and the only one with a problem. What could be the problem with it? Thanks.
  • 1 more comment
  • megansh62 Aug 25, 2008
    Hi I get the blinking "Err" message as well. It seems as if the shot is freezing and when i click the button again the message goes but I am not getting a photo. This happens with all lenses that I put on.
  • mawtrey Sep 03, 2008
    I have the same issue. A camera shop wanted $255.00 to fix. They said it was the shutter and it needed to be replaced.
  • Anonymous Mar 13, 2014
    Built in flash doesn't work, auto focus does not work, will take photo but nothing shows on the card.
    President:
  • 423 Answers
Make sure the lens is mounted fully (give it a little twist to see if the error clears). Also, check the gold contacts inside the body, where the body touches the gold "points" on the lens, to make sure they are clean. A pencil eraser is a good cleaning device for these contacts. I hope this solves it for you.
Posted on Jun 02, 2008
Err on top of display on camera
Unfortunately, this probably won't be a good situation. Most of the time the ERR(or) message you're getting shows when there's an internal problem, and most likely a shutter error. Not an uncommon problem with the older consumer models like D40, D50, etc.
Dec 27, 2013 | Nikon D50 Digital Camera
I get "Err" on the
The ERR message indicates a camera malfunction. In my D-90 manual it says that it can be cleared by releasing the shutter. The only way to do that is to turn the camera off and back on. Rarely, that won't work and you have to remove and reinstall the battery.
The manual also says that it this have frequently or persist to contact a Nikon authorized service center. I would contact Nikon tech support at www.Nikon.com and discuss the problem them before contacting an authorized service center.
Jan 25, 2011 | Nikon D50 Digital Camera
I have a Nikon D50 with a Err message and I can't take pictures anymore. What would be the cause for this? Eric
"err" is a cmara malfunction. If the camera has a hardware reset button, give that a try. If that does not work, then examination by an authorized Nikon Service Center is advised.
Nov 01, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
Err message nikon f-100
Read pages 99-101 of the manual. There are numerous err messages referenced. Some blink others only have the E of Err blink and the like, all with different solutions. If you cannot find the manual call Nikon Film 1-800-645-6687.
Aug 10, 2010 | Nikon F100 35mm SLR Camera
I shot a wedding and got the ERR message 3
Take your manual reset a little further...remove the card and battery...press all the buttons...leave the camera alone for at least 20 minutes...insert the card and then the battery...turn it on. See if that works.
Oct 08, 2009 | Nikon DSLR D90 Digital Camera
Nikon D50 Flashes Err and clicks
hi..
This screen shows areas of the photo that are overexposed slightly.
It flashes them to help you.
You get to this screen by pressing the up or down arrows when displaying the pictures you have taken.
To change it just press the up arrow when the camera is showing the screen until you get a display without flashing.
Once you have done this the display will be steady.
If you get any other screen in future you may have accidently pressed the arrow again.
Just cycle thru the displays to get back to steady.
thank u
rate me!!
Jul 27, 2009 | Nikon D50 Digital Camera
"Err" message
ERR is like saying to your doctor your sick. It covers a very wide host of problems. Only Nikon once the camera is connector to there computer can give you a better diagnosis.
Jun 30, 2009 | Nikon D50 Digital Camera
Flashing "Err" message with a code 999. Can't shoot pictures.
Try resetting the camera.
First a soft reset is to just replace the battery. If that doesn't work try a hard reset - on the bottom the other side to the battery flap.
May 06, 2009 | Nikon D50 Digital Camera with 18-55mm and...
Shutter
I had the same problem but replaced the lens with a different lens and it worked just fine.
Aug 27, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50 Digital Camera with 18-55mm Lens Logo
1,105 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
