Question about Samsung SyncMaster 172N 17" LCD Monitor
On/off switch is erratic? - Samsung SyncMaster 172N 17" LCD Monitor
  • 11,361 Answers
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 12, 2010
2.3 liters, 4 cylinder turbo coupe engine idles erratically and cuts off. Black smoke comes out of exhust pipe. One of the radiator electrical fan comes on even when the motor is cold,
Sounds like you have two issues.
Black smoke and erratic tickover is a rich mixture.
Radiator fan is a separate issue and is the thermostat switch that is connected to that fan. If you have two fans, you need to make sure the other one actually runs as the switch may control both.
Mar 09, 2016 | 1988 Ford F 150
I have a read screen on my 2001 Jaguar S- Type that says " Fail Safe Engine Mode. What does it mean
Hi, fail safe engine mode means that the ECM (Electronic control module) or computer box as some know it, is running in a mode whereby it is bypassing a particular component in the engine that has gone faulty in order to keep the car from cutting out, or has picked up an erratic function in any component, which is more than likely an electrical problem and could be one of the following which have to be checked by computer analysis equipment at the Jaguar agents or any one else that is familiar with the process that is required to trace the fault. Here are the possible causes: 1.Erratic wire connection 2, Engine cooling Fan thermal switch. 3. Control module 4. CKP sensor 5. Computer box not functioning correctly (a rare fault) 6.Engine coolant fan not working, or running erratically. Unfortunately only a computer analyis will depict the location of the fault and if the repair man is very experienced will be able to sort it out quickly with the computer analysis.( Although I strongly suspect it to be the cooling fan thermal switch which is working erratically and will soon fail completely.)
So get your car to the experts as soon as possible especially if it could be the cooling fan thermal switch, which could cost you a major expensive engine repair job if your Jaguar overheats.
Have a good day.
Oct 02, 2014 | 2001 Jaguar S-Type
How do you test and/or replace a clutch for an EZ4824?
sounds like it could be the clutch!!!!!!
Sep 11, 2014 | Garden
Cursor freezes or is erratic
Ow, I have had this problem myself. Do you have an iPhone or other Apple device that you've connected lately?
I am assuming your mouse is either Bluetooth or uses a proprietary 'dobgle'...Which?
Dec 28, 2013 | Computers & Internet
V70 windshield washers erratic
You have plugged hoses or nozzles. You can get a filter to put in line after you clear all the parts. You have some sort of particle floating around in the system causing the erratic failures.
Apr 05, 2012 | 2000 Volvo V70
Why do the wiper blade on my 2003 saturn will go erratic or just stop working?
Hi, Check the ground wires and switch they may have corrosion. Clean them up with a little sand paper on contacts. Then you'll be good to go.
Dec 08, 2011 | 2003 Saturn ION
Upwardly movement of the joystick erratic and the keying slow
Just switched off for a little while and again switched on the mobile and the problem solved
Mar 25, 2009 | Sony Ericsson Cell Phones
Car Stereo Volume Goes Up and Down Erratically
prolly buy a truck and a amp from this century
Oct 05, 2007 | Car Audio & Video
Samsung SyncMaster 172N 17" LCD Monitor Logo
50 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
