After 10 years of function a problem appears with the technics se-a900s power amplifier: When the power output reaches or aprox the 10wrms the protection circuit enabled,and the unit goes off! (no sound) I have to turned off power,and start again (power on) The unit is not overheating. The built in cooling fan working fine. I dont want to think that the problem caused from the 15y.old,speakers,they playing music fine as the first time! (tested with other type of amplifiers at high levels of power with the same cables) I think something going wrong with the thermal detector or low impedance speaker detector - i couldn't found any adjastments for this inside the unit!
  • qluser Oct 12, 2010
    After a close look at the schematic diagram of the amplifier, i saw there is no thermal protection circuits with discrette componets.
    However the problem i think caused from bad voltage,combined with poor current from power supply unit. Special from the capacitors. They are aged...
    I will try to replace them,and i will post a comment,with test results.
    Somehow ,if i run the amplifier from the first at high level output, the unit working fine!
    If i run the amplifier at low power output for several hours,and then want to hear at high level,the problem appear especially at night! (diefrent and higher ac voltage)
    Also important is this: I don't hear music verry often from this system. The amplifier is in st.by function for 2-3 months,and sometimes more for the last 5 years! Before this period the amplifier working fine day by day for a several hours per day.
    Genius:
  • 1,175 Answers
I would have the power supply capacitors replaced. After several years ( from heat and age) they dry out and dont put out proper DC voltages to run the amp.
Posted on Oct 12, 2010
  • 2 more comments
    I thought that too... Thanks any way!
  • fastbladerun Jan 18, 2011
    Can you let me know if that was the solution please?
    I have the same problem en where did you buy these capacitors.
    Thanks Paul
  • fastbladerun Apr 05, 2011
    Please can you tel me if the capacitors where the problem or something else
  • Scott Frye
    Scott Frye Apr 05, 2011
    Digikey (dot) com or
    mouser (dot) com
Ok, i interested in the technics se a900s amplifier, just for vu meter use, not amplifier,and...
Pre-amp only needed for phono. Otherwise, line in is just fine.
10 to 20 ohm load resisters to substitute for speakers. get 50 watt rated ones at least, they can get hot....
May 12, 2016 | RCA Car Audio & Video
I will buy a Technics se a900s amplifier, but
I think you are saying you want to connect the amp and use it's vu meters but not connect it to speakers?
Presumably you are already well catered for in the matter of amplification but lacking good vu meters?
There is a fair amount of information about this premium amp online including operating and service manuals that can provide a better answer than I can.
One note of caution; it is generally bad practice to operate a power amplifier without a load at the output and it might damage the amplifier. If it is desired to operate it without speakers providing the load, dummy loads are available.
I suggest you have a look through ebay or Amazon where you might find digital or analogue vu meters at a reasonable cost or alternatively I believe computer software could turn your laptop into vu meters.
May 11, 2016 | Technics Audio Players & Recorders
Technics 1080 pre amp volume control is not functioning correctly
Technics SE CA1080 Service Manual
there is a chip called an operational amplifier under a heat sink on the pcb,that fails when it get top volumed for two long theres regulators with heatsinks.
it is listed as,
Technics SE -CA1080 amplifier F61 fault,
May 13, 2015 | Technics Audio Players & Recorders
What is the speaker output per channel for technic se-350?
seems to be 22 watts rms, 35 watts peak at a 4 ohm load. with 8 ohm speakers, the power would be reduced 50%, but the distortion levels would also be drastically reduces
Jan 02, 2015 | Audio Players & Recorders
My technics intergrated amplifier says over load
overload is protection from very big signal input-or high current output.
1-keep your input signal between -10db-----to 0db.
2-confirm that amplifier power is greater than total power of loudspeakers by 20%(if loudspeaker total power is 8 watt-amp watt must be 10 watt at least.
Nov 30, 2009 | Technics SUV500 2-Channel Amplifier
My aplifier Denon UDRA F-10 says "protect"
Blingking Light or Protect usually means that there is DC appearing in output stage and is protecting Connected Speakers.
It can be faulty Output Stage (Bad ICs/Transistors/Resistors/Capacitors) or Faulty Power Supply.
Working on These types of Problem is not user friendly at all.
Advising to take local Authorized Shop.
Jan 30, 2009 | Denon PMA-100M Amplifier
Parts for Technics SE A900S Audio Power Amplifier
Here ya go.
http://www.vancebaldwin.com/products/?MSCAN7062
Mar 13, 2008 | Audio Players & Recorders
Technics SH-AC300 Connection to Power Amp & Pre-Amp
Hi!
The problem is, that your SH-AC300 needs an amp with 5.1 input (but no decoder). For this purpose technics delivered SA-AX710.
So if you'd like to use your current equipment it would be impossible.
The only option is for you to buy 2 more Power Amps (SE-A900S), so that each of 3 amps would take care for one part of music. (one for FL, FR; one for RL, RR; and one for sub and center).
Another option is for you to buy SA-AX710. Then all the problems would be solved with it.
Jan 15, 2008 | Technics SA-DX950 Receiver
482 people viewed this question
 Grubhead
Grubhead
