Question about Epson Stylus Photo 1290 InkJet Printer
My epson 1290 has both red and green lights flashing alternatly
  • 857 Answers
Follow these steps:
1.
Jammed paper or a foreign object is blocking print head movement. Turn off the printer, press the adjust lever down to the lowest position, and pull out the jammed paper. Open the cover and remove any jammed or torn paper, or foreign objects. Then do one of the following: Sheet Feeder: Return the adjust lever to the position. Turn on the printer, reload paper, and press the paper button.
2.
The waste ink collector pads are getting full and this is a protection indicator. Check it out.
3.
Check out the printer cartridges it may not be installed properly.
Posted on Oct 11, 2010
  • 4,472 Answers
This may help you:
1/ turn off printer. 2/ Press both buttons while turning printer on. 3/ Hold left hand button down then press the right hand button briefly.
If you continue to have issues I would consider replacing the printer as it is an 8 year old printer and you can get a much better printer starting at 40-50$.
Thank you,
Lee
  • Lee A.
    Lee A. Oct 11, 2010
    You passed on my solution but didn't offer me any feedback to be able to further assist you.
    Thank you and good luck,
    Lee
The green power light and the red warning light are flashing alternately E_Mail colin_hoyle@yahoo.co.uk
Check the printer properly, if there is any paper jam, or any thing that is preventing the print head moving . also check if there is any message showing on PC. Write in details.
Thanks.
Jan 16, 2011 | Epson Stylus Photo 1290 InkJet Printer
What does alternate red and green flashing lights means
Ink pad full. Reset waste ink counter using epson resetter. Replace inkpad or extend the pipe of head cleaning mechanic to outside printer.
Jan 01, 2011 | Epson Stylus Photo 1290 InkJet Printer
Red and green light flash
It`s mean "unknown error"
You need to contact with your dealer
Sep 21, 2010 | Epson Stylus Photo 1290 InkJet Printer
Photo 1290 Changing ink cartridge
You may have to reset your printer, for when the green an red are flashing. Please do the following in order to reset the printer;
1-switch off printer itself
2-switch off at socket for 20 seconds
3-hold down both black buttons on front
switch on at mains
4-switch on printer itself
green and red flash together
5-now switch off at mains and leave for 3 seconds
6-while holding down both front buttons again, switch on at mains
both green and red flash together so release
7-quickly hold down the left botton, the one with the scroll icon above it.
Hold this until it resets itself, - the print head will re
charge and it will be obvious.
Restting by unpluggin rather than turning off at mains tends not to work.
This must help you as it worked for me.
Regards,
Anirban Mazumdar
Jun 05, 2010 | Epson Stylus Photo 1290 InkJet Printer
Epson 1290 inkjet printer flashing lights
maybe the printer head is busted, try to replace the printercartrige
Mar 26, 2010 | Epson Stylus Photo 1290 InkJet Printer
Red and green lights flashing on epson c46. what do i do?
I guess your printer need to reset the counter ink pad, for reset the counter you must have a adjustment/reseter software, and for your printer type please download <a href="http://www.ziddu.com/downloadlink/7587521/sscserve4.3.exe">here</a>
I hope this link can solve your problem
Dec 16, 2009 | Epson Stylus Photo 1290 InkJet Printer
Red and green lights flashing, won't print or respond to commands. Problem started when cleaning heads and subsequently testing with the print pattern. Monitor says a general printing error and suggests...
The heads are clogged. Unplug the printer remove the cartridges and dump them (never use the same brand of it or the same ink),pour some cleaning fluid there and leave it to soak. If you have some empty cartridges fill them with cleaning fluid and use them.
Oct 04, 2009 | Epson Stylus Photo 1290 InkJet Printer
This is a maintenance request. Basically the internal counter has hit it's limit and now requires that the counter is reset and the ink pads are replaced or cleaned.
Ask at http://www.TheServiceManualShop.com if they do a Rescue Kit for your machine. This should include all the goodies you need to get running again. If they have no kit for machine, let me know as I may have an alternative.
Oct 13, 2007 | Epson Stylus Photo 1290 InkJet Printer
Epson Stylus Photo 1290 InkJet Printer Logo
73 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
