Question about Whirlpool DU930PWSS Stainless Steel Built-in Dishwasher
My dishwasher is less than 10 months old. I was running it last night and it just quit before the drying cycle. Now nothing on it will work. I checked the breaker, nothing was tripped.
  • tam2432 Oct 11, 2010
    I can't even get the dishwasher out from under the cabinet! Let alone try to figure it out, and just realized I never mailed my warranty card in so I guess I will have to call someone and just **** it up.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with try to leave the unit unplugged for 10-15 minutes and while its unplugged check for clogs in the drain hose.
Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Some of the most common reasons include that the drain hose isn't working properly, the drain pump isn't working correctly, or possibly there is a plumbing problem in your home's drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages, if everything appears to be fine then it is better to use warranty and get it replaced/repaired. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 11, 2010
  • Rylee Smith
    Rylee Smith Oct 11, 2010
    Okay, Please accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
How do I turn up the heat to remove most condensation after washing?
As part of the current ecological, energy-saving, environmentalist-wacko movement, dishwasher makers have cut back on the heating used to dry dishes. In fact in many dishwasher designs, they have eliminated the drying vent altogether, and instead use a condensate or condensation-drying system. In this system, the last rinse cycle is heated to a high temperature, to heat the dishes. The water is then pumped out, and the dishwasher shuts down. The theory is that water will evaporate off the hot dishes, condense on the sides of the dishwasher, and run back down into the sump area. Bosch was one of the first diswashers to do this, and it works fairly well for them. Other manufacturers have tried this, with varying results. Here's what you can do to improve drying:
1. It is imperative that you use rinse-aid (Jet-Dry). This allows more water to flow off the dishes and what flows off does not need to evaporate.
2. If the dishwasher has the options, turn on high-temperature wash and sani-rinse. This gets the dishes hotter for better evaporation.
It is possible that the heater may not be working at all, and that will cause poor washing performance and no drying. This is very rare in dishwashers less than 3 years old. Most likely, poor drying in a new dishwasher is caused because you are not using rinse-aid.
Sep 21, 2014 | Whirlpool Dishwashers
Sometimes dishwasher completes full cycle, but more often than not it stops after half way of cycle with flashing d14. Machine approx 4 years old and only started within the last month or so. All...
What is the brand name and model of your dishwasher? Different manufacturers can quite often use the same error codes for different faults.
Apr 15, 2011 | Dishwashers
AS PER DIRECTIONS FROM TECH, I PURCHASED AND INSTALLED A NEW CONTROL UNIT. THIS WAS BECAUSE MY WHIRLPOOL DISHWASHER GOLD GU2300XTLB3 QUIT WORKING IN ALL CYCLES EXCEPT SHORT CYCLE. PUT EVERYTHING BACK...
This is a common problem with Whirlpool washers.If the clean light is the one flashing then your dishwasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has until all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
Press the heated dry button followed by the normal cycle button, and then repeat once. You should see all of the lights come on for a second or two, and then the dishwasher will work again.
If you haven't already, take a look under the kick plate in front to see if there is a schematic tucked in there somewhere. Whirlpool has put their diagnostics for specific models on these.
I don't have the specific repair manual for you model.
So, if the above combination does not work here are two more that have worked for me.
HiTemp Wash + Air Dry + HiTemp Wash + Air Dry in less than 5 sec
or
Hi Temp Scrub/Scour + Air Dry + Hi Temp Scrub/Scour + Air Dry in less than 5 sec
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 01, 2010 | Dishwashers
In the last month I have noticed that my dishes aren't getting clean. My dishwasher is less than a year old and has done a great job so far. I tried adjusting the amount of rinse aid and the amount of...
First I would run the hot water until hot. Then start the dishwasher on the longest setting with the dispenser door closed( no detergent). Then after about 10-15 minutes open the door and check to see if the dispenser door opened, it should have. Then pour in about 1 cup of white vinegar and let the dishwasher finish. When the dishwasher reaches the end of the cycle open the door and it should be hot and steamy. If not check the heating element. If it is hot this should have cleaned it out, now try it with a load of dishes.
Dishwasher heating element replacement
Sep 28, 2010 | LG Dishwashers
LG LDS5811 top rack not cleaning
I Have the same issue, it sounds like the arms try and start up 4 times then each time power back down, the top arm is not spinning at all. On the fifth time a I hear grinding and then the mid and lower arms spin, soap streaks down the door, nothing stuck in any of the arms, 16 months old, 750.00 out of pocket for junk!
Oct 08, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwasher won't cycle
Sounds like you need a new timer. Costs about $50 - $60. I had the same problem. The knob now turns. Hope this helps.
May 18, 2009 | GE Nautilus 24" Built-in Dishwasher
Model gu2700xtss1, upper rack not clean at all,
I am here for the exact same reason. Mine is less than 3 months old. This may be a recall item. I bought, and paid more for a kitchen aide for the name and reputation.....Where can I find the model number?
Feb 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishes not drying and mildew growing in dishwasher
I totally agree with Solution #1. We have a Whirlpool (apparently Maytag is the same) and it gets moldy 2 days after it has been run. The maintenance guy came out and said we had to use the rinse cycle every day. For an $800 dollar dishwasher (which is less than 1 year old!) I expect more.
Jul 09, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Food Deposits left on dishes
I had an old machine with a similiar problem & I found that food had somehow entered into the arm that spins & sprays out water. The food blocked somewhat the holes which of course means less cleaning.
Mar 05, 2008 | Maytag 24 in. MDB5601AWS Stainless Steel...
Whirlpool DU930PWSS Stainless Steel Built-in Dishwasher Logo
133 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
