Question about Garmin nuvi 250 GPS Receiver
How do i charge my garmin by attaching via a usb cable to my mac
    President:
  • 1,514 Answers
When you connect the satnav to a computer with a usb cable it automatically starts to charge. However it takes about 8 hours to charge compared to around 4 on a car charger.
Posted on Oct 11, 2010
Garmin 705 - device not found by Training Center
Garmin has moved everything to Garmin Connect. Depending on your device, Training Center may or may not be supported anymore. You can go to the link to read more on Garmin Connect. Also, Garmin now uses Garmin Express to sync and update devices. I'll attach the link. https://www.garmin.com/en-US/software/express
Aug 16, 2017 | Garmin EDGE 705
Garmin 265 wt is charging via USB cable.It will not connect to the garmin website.
The Garmin Communicator Plugin needs to be installed on your computer.
http://www8.garmin.com/products/communicator
Also check to be sure that the data cable is the correct one.
When connect between the nuvi and the computer, the nuvi should show that it is in mass storage mode by displaying a computer on the screen.
The correct cable is Garmin part number 010-10723-01.
http://www.gpscity.com/garmin-usb-pc-cable.html
Aug 18, 2011 | Garmin nuvi 265WT Car GPS Receiver
How do I recharge the battery on my Garmin Nuvi 255WT? I would also like to know how to update my Garmin?
Recharging the battery is done by connecting the nuvi to a vehicle power cable in the car through the vehicle power accessory outlet or cigarette lighter.
The unit can also be charged via a powered USB port off your computer via the USB power/data cable or an AC power adapter through the USB power/data cable.
Aug 15, 2011 | Garmin nuvi 255W GPS Receiver
Can I charge my Nuvi 1310 via a usb cable on any pc for the first time for the 4 hour period, as instructed?
You can charge your nuvi via the USB cable on any pc but it will take 8 hours approx rather than the 4 it would take with a car charger or mains charger.
Feb 16, 2011 | Garmin nuvi 1310 Car GPS Receiver
Can I use my Garmin nuvi 1300 while it is charging via USB cable? This will be it's first use.
I HAD A PROBLEM CHARGING MY 1300 GARMIN. I PUT A SCREW DRIVER BLADE ON THE TWO SIDE CONTACTS OF THE CHARGING CABLE AND TURNED THE BLADE TO SPREAD THE CONTACTS OUT JUST A LITTLE. IT NOW WORKS FINE
Dec 26, 2010 | Garmin nuvi 1300 Car GPS Receiver
My garmin ran out of charge and when it was plugged in to the car charger it says loading maps then stays on the garmin page and goes no further...
Disconnect the nuvi from the car charger and connect it to your computer's USB port with the supplied cable (or any USB cable you have that fits it), and leave connected overnight (8 + hours).
You should be able to get the GPS to start up as expected after charging via USB port. if this happens again, simply repeat.
Jul 15, 2010 | Garmin nuvi 255W GPS Receiver
Battery
The unit will take a very slow charge via your computer. I tell most people no it doesnt charge VIA your PC just because it takes soooo long. I recommend getting a new power cable from GPSCity. Just call them up or follow the like to the cable you need.
** This cable is for the Nuvi 200 series GPS units
http://www.gpscity.ca/garmin-mini-usb-12v-cigarette-lighter-adapter-for-nuvi-in-web-packaging.html
Cheers
Jul 13, 2010 | Garmin nuvi 260W GPS Receiver
How can i configure my pc to recognize my garmin gps?
When you attach your Gamin to your PC via a USB cable, your PC should recognize it and add it as another drive letter on your computer. If it doesn't, you might try rebooting your computer while the Garmin is still attached.
Dec 31, 2009 | Garmin nuvi 255W GPS Receiver
How do i charge garmin nuvi 250 on my computer
HI,
I have the problem solved I at first had this problem after about 5 minutes of messing with my GARMIN NUVI and having many electronic gadget I thought about diffrent buttons to hit at the same time heres how you charge your NUVI with a computer and a usb cable
1st: make sure your NUVI is OFF then plug in the usb cable from the computer to the NUVI, after you hear your computer ding from new device connected, and the NUVI displays the computer icon move to step 2
step 2: if you have xp go to START and MY COMPUTER. with vista its START then COMPUTER button on the right side
step 3: with MY COMPUTER window open hold the NUVI power switch to the ON position and RIGHT CLICK the NUVI device logo (blue triangle) and select EJECT .. ( DON;T HIT SAFiLY REMOVE)
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disaper
Nov 09, 2008 | Garmin nuvi 250 GPS Receiver
Charging
From a complete drained battery it took me about 2 hours of charging via the USB cable hooked up to my computer to fully charge it.
Dec 26, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin nuvi 250 GPS Receiver Logo
211 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
