Question about Garmin nuvi 255W GPS Receiver
I have garmin gps it not chargeing my car onl by computer whe?
  • 1,514 Answers
It's most likely that the fuse in the charger has blown. The fuse is located in the plug that goes into the cigarette lighter socket. On the end of the plug there's a ring. Unscrew the ring and it comes apart. Be careful not to lose any parts when you open it. You'll see the fuse which needs to be replaced. If this does not solve the problem it's possible that the cigarette lighter is faulty.
Posted on Oct 11, 2010
How will you charge a gps nuvii garmin 1450 using computer?
To charge a garmin nuvi gps with your computer you connect your satnav to the computer's usb port using a mini USB lead. Turn on the computer and the satnav and the satnav will begin to charge. It will take approx 8 hours to charge compared to 4 using a car charger or mains charger.
Feb 05, 2011 | GPS
Garmin gps powers off even when fully charged
If you're "recharging" via the car charger - you might want to try charging via USB jack on your computer - or AC adapter (if your GPS shipped with one) for 5 or more hours.
Many Garmin units develop this condition when used strictly in the car / cigar outlet power source. While connected to your computer, you should go to Garmin's website and download, install & run the "webupdater" software. When complete, your Garmin GPS will have the latest firmware and patches to the software (not maps!).
After charging via USB or AC adapter, your GPS should stay on. If your GPS turns on via a slide switch on the top, Slide the switch from OFF and hold in the ON position for 10 seconds before letting go of the switch. This should force a "boot" on the GPS.
If you're unable to get the device to power up, contact Garmin Support to determine if your device is affected by a a recent battery recall or if there are other suggestions they have to solve the problem.
I hope this helps!
Oct 08, 2010 | Garmin nuvi 650 GPS Receiver
I have a garmin GPS and a car charger...But when we plug it into the car to charge it...it comes up with a pic of a computer rather than charging and working as a gps...is that because there is a different...
The reason is that the plug is not pushed far enough into the satnav and it thinks it's being connected to a computer. Push it in fully and it should be ok.
Jul 27, 2010 | Garmin nuvi 250 GPS Receiver
My gps72 just started going off and a thin vertical line appears on the screen. the onl way I can get to come back on is to remove one of the batteries and then it will turn on again and the problem starts...
You need to update the software version to 2.50. You will need a data cable that connects to a serial port on a computer. Be sure to have fresh batteries in the unit and set it to simulator mode when you turn it on and then update. The update is on garmins website.
Mar 03, 2010 | Garmin GPS 72 GPS Receiver
How to charge garmin 765 on computer
Very simple: connect the cable that came with the GPS: USB end to computer, mini USB to the GPS. When the unit is charging, the battery icon will disappear.
Unfortunately, Garmin did not think you would want to know the percentage of charge completed (they confirmed it to me in email), so you have to guess that after 2-4 hours your GPS is fully charged.
Nov 29, 2009 | Garmin n?vi 765T Car GPS Receiver
How long does it take to charge a garmin 255W gps?
Are you charging through the computer or wall charge,I charge my Garmin 255w with a wall charger for about 3 hours and I have all the bars.There are different strengths of chargers but even so,overnight is excessive,try a different charger.
Aug 08, 2009 | Garmin nuvi 255W GPS Receiver
Garmin 2005 will not charge, new in November of
Make sure the internal battery is charged by connecting it to your computer with the included USB cable. Make sure the computer is on and running. Let it charge at least a couple of hours and then try to turn the GPS on while still connected to the computer. If the unit still will not turn on you might need to return it to Garmin.
Apr 03, 2009 | Garmin nuvi 250W GPS Receiver
My windows xp does not recognize my garmin200
Go to the Garmin site and download you USB driver. Install the driver with out the GPS connected. Aftter the USB driver is installed reboot you computer and then connect the GPS. Let us know if that works.
Dec 16, 2008 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi dead
You can either charge it on your computer with a USB cord or in your car (should have came w/ a car adaptor.)
Nov 21, 2008 | Garmin nuvi 200W GPS Receiver
NO OUTLET TO PLUG INTO CAR
Most GPS would have a cigarette lighter adapter to charge the unit while in the car. If you vehicle has onle 1, then it would be needed to pullout the cigarette lighter and use that for the charger. If your unit does not have a cigarette lighter adapter/charger, then pls post back the brand/model.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 26, 2008 | Garmin GPS
Garmin nuvi 255W GPS Receiver Logo
62 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
