Question about Cameras
When I turn my camera on, it tries to adjust the lens and then it retracts. the screen says lens error.
  • 3,287 Answers
This is a common problem for these pocket cameras with zoom lenses. It is usually a result of the camera being switched on while in a pocket or case or other place that restricts the lens from being able to be extended fully.
The camera does a sort of "self check" when turned on to make sure the pictures you take will be right. If it can't perform the test successfully, it shuts off and displays an error message.
Something is preventing the lens from running the self test completely. This could be a damaged mechanism (as a result of trying to open all the way earlier), or a simple "grain of sand" that has become caught between the lens barrel and camera body.
The camera will need to have the offending object removed / mechanism repaired to let the lens complete the self test before it can be used again. You might have some luck fully charging the batteries or or leave connected to a power source - and attempt to power up again. This is a "brute force" method - the fully charged batteries / power source my provide enough "oomph" for the lens to dislodge the object. Make sure the camera is pointed lens down - so it can fall out - rather than INTO the camera even further. You could try pulling the lens while powering up - but this could make things worse. If the camera is expendable, you could try that. If the camera is more than a couple / few years old, you might just want to simply buy a newer, more feature packed one instead of going the repair route - as this *can* be an fairly expensive repair give the cost of most mainstream cameras purchased a few years ago and the cost of them today.
If it is a dirt issue, it will likely NOT be covered under warranty. Of course, contacting the manufacturer and discussing the problem certainly can't hurt.
I hope this helps... good luck!
Posted on Oct 11, 2010
The words "Lens Error" appears on the viewing screen
The lens does not fully extend, that's why it tries again. The lens probably does not extend or retract because of debris or a misaligned gear box. The lens can in about 50% of the cases be repaired without having to replace it. Try to return to manufacturer first. If you're out of warranty, there are third party place that fix them such as camera lens repairs. If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Jul 07, 2010 | Nikon Coolpix S210 Digital Camera
Lens Error on L18
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 23, 2009 | Nikon COOLPIX L18 Digital Camera
Lens will not retract. orange and green lights come on, but preview screen remains dark and lens will not retract when I trun it off.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
May 02, 2009 | Cameras
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
C875 lens won't retract
Camera (with new rechargable batteries) won't let the lens come out or if it does it instantly retracts.
Nov 14, 2008 | Kodak EasyShare C875 Digital Camera
Lens error
Same problem here - the forum posting on the SD 500 seems to be a bit more active (for the same problem).
http://www.fixya.com/support/t102982-e_18_problem
I have been trying to get some images or a service manual for the SD 700, with no luck...
Mar 15, 2008 | Canon PowerShot SD700 IS Digital ELPH /...
I had exactly the same problem and I went to this site and got my solution. I banged the bottom of the camera with my palm and turned it off and on at the same time. On about the fourth bang the lens retracted and cleared the error codes. I know, "Caveman Maintenence" but it worked. Can't hurt to try...
Dec 10, 2006 | Kodak EasyShare CD33 Digital Camera
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
