Question about Sharp Notevision PG-M25X Multimedia Projector
Sharp PG-M25X Flashing Power LED
While watching a movie, the projector shut down without notice, and will not
re-energize. The Power LED flashes constantly but unit will not turn on.
Many attempts to unplug the power cable from the wall and from the unit's connector are unsuccessful.
The Power LED is the only LED that illuminates. I have 1300 hours on the bulb.
Thank you.
  • 1 more comment
  • Anonymous Jan 22, 2009
    This just happened to us this afternoon, the projector was working fine, our presentation was ready to go and then blackness! We alsoo attempted to unplug, shut down, etc. and nothing worked. The instruction manual is useless! =0( Also, none of the lights that are supposed to indicate the projector running hot or the bulb lit up, which it's supposed to do if it's either of those problems! PLEASE HELP!
  • Anonymous Jan 31, 2009
    I've got a similar problem, and I only have 300 hours on the bulb, though the projector is about 4-5 years old.
    The lamp shuts down, but the fan is still on, and there appears to be effort to restart the lamp. The power LED is green, and the lamp LED flashes green.
  • thepcdoctor May 11, 2010
    While watching a movie, I powered off the DVD player rather than pause it.. After about 5 to 10 minutes with no video input, the projector shut down without notice, and will not
    re-energize. The Power LED flashes constantly at about a 2 Hz rate and will not turn on.
    Many attempts to power on the unit after disconnecting the power cable from the wall and from the unit are unsuccessful.
    I left the power cable disconnected overnight and the problem still exists.
    Thank you.
dhiman
  • 115 Answers
SOURCE: sharp digital multi media projector PG M10S repairs
pls tell the problem clearly as this is solveable
Posted on Mar 29, 2008
SOURCE: my projector says all keys are locked.
Just hold the "ON" key for 3 seconds until it frees up the keyboard. Then hit the "standby" button twice to shutdown.
Posted on May 08, 2008
Sinista
  • 6 Answers
SOURCE: Tech support for Sharp PG-B10S
Reset The Lamp Timer.
While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
Sinista
Posted on Jul 10, 2008
myrlex
  • 674 Answers
SOURCE: Need a new power cord for the Sharp projector
GO TO ANY NEAR SHOOROOM IN YOU AREA OR CITY..
Posted on Jun 08, 2009
projdoc
  • 2237 Answers
SOURCE: projector problem
if it is only when the computer is connected, replace the cable.
Posted on Aug 04, 2009
Sharp projector PG-M20X will not power on an power light is flashing red
I had the same problem with the blinking red light. I looks as if realy RL701 on the main power board is the problem. I removed the cover of the relay and cleaned the contacts. Despite the contacts being worn down it worked great. I have ordered a new relay from Sharp for about $35 to replace it (part # 95CK3102AL001).
Aug 18, 2010 | Sharp Notevision PG-M20X Multimedia...
Sharp PG-M20X digital projector runs 2-5 minutes then shuts off
the Fan has the problem , I had the same of yours. I noticed some particle was inserted in the center of the fan and removed it , worked perfectly. If old one produce little particles.
Good luck.
Dec 03, 2009 | Sharp Notevision PG-M20X Multimedia...
Projector not turning on after repalcing lamp
if power indicator is flashing, check that the innerswitch by the lamp cover is closed.
Dec 18, 2008 | Sharp Notevision PG-B10S Multimedia...
Sharp Notevision PG-B10S loses signal
found limited on phone support at 1-888-go-sharp (467-4277)... Ultimately they referred me to a local technician for fee. good luck
Dec 10, 2008 | Sharp Notevision PG-B10S Multimedia...
Sharp Notevision PG A10X
check the power supply heard issues with this system like that but was all related to the power supply
Aug 21, 2008 | Sharp Notevision PG-A10X Multimedia...
Sinista
Apr 15, 2008 | Sharp Notevision PG-B10S Multimedia...
Lost My Cords to Sharp PG-M25X
You can use any standard computer power cord. Can be found at any computer parts center or electronics store Best buy ETC...
Your projector has a DVI input for computer signals. If you want to use a 15 PIN cable they can be purchased from the same stores.(15pin to DVI cable.) On the internet I like NEWEGG.COM.
Here is a copy of your manual. You can purchase these item from sharp at a high cost. (Not worth it.)
http://www.sharpusa.com/files/pro_dow_PGM25X.pdf
Dec 10, 2007 | Sharp Notevision PG-M25X Multimedia...
Sharp Notevision PG-M25X Multimedia Projector Logo
158 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
