Question about Toshiba Satellite Satellite 5200 Series 15 SXGA LCD Display-LQ150F1LH16-P000353350 CD-ROM Drive
My screen is black in very high light i can decipher some writing but also not possible to make the mouse work. what can i do?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 72 Answers
With regards to the screen problem, it sounds like the inverter may have failed. If possible, try connecting to laptop to a monitor to see if you can see the display on the monitor. (You will need to press fn+f4 keys together to change to the monitor). If you can that it is most likely that the inverter has failed. I would recommend you get a local professional to check it out as inverters carry high voltage currents.
Rytech Computer Services Ltd.
Posted on Oct 11, 2010
Dell dimension C521
What does the white writing say? Is it trying to boot into Safe Mode?
Apr 04, 2012 | Computers & Internet
Black screen with flashing horizontal lines
You may have a bad backlight screen power supply board and that is usually mounted in the bottom part of the screen right behind the front bezel. This supply's high voltage to the backlight tube that lights the screen. This is kind of like a small florescent tube that uses high voltage to fire the backlight and is a common failure point in laptop screens. Easy to fix, just pop the front bezel off and the module will be in the center bottom section of the screen. Do a YouTube search on how to disassemble your model's screen and the parts can be found on Ebay. Good luck.
Apr 14, 2017 | Compaq Computers & Internet
My Acer AL2216W monitor this morning went blank. I woke up, turned on pc and went to sleep like an hour more, when I woke up, the screen was black and light orange, as usual, when pc is not used for a...
Go to Control Panel, (top right View Small Icons). Then look for Power Options. On this page, you'll have the option to leave the monitor on. You should also check "Advanced Power Options". Don't be afraid of the word, "Advanced." It only means "customizeable"
If your mouse isn't waking your monitor, try the keyboard's space bar. I found it works better than the mouse at waking a sleeping computer
Apr 04, 2017 | Acer AL2216W LCD Monitor
AM5BOXM683974
Hi, I think i know what the problem is. Bose as well as quite a few high end stereo manufacturers use proprietary connections-that means their equipment may only be connected with and connected to Bose equipment, sadly this may apply to accessories too. So bottom line is: if you have acquired a separated component that appears to have an odd connection it may not work without its mated part. If you happen to be technically inclined it is occasionally possible to disassemble the unit and decipher the "PIN OUT" for what you're missing to try and get it to work. I hope this was of help and thanks for choosing FixYa, write back to let us know how we did or even with particulars on your problem so we may be of further help if necessary,Good luck Prodzilla.
Apr 15, 2011 | Bose Cinemate Digital Home Theater System...
My acer aspire 5810TZ-4657 will boot up, but won't display the logon screen, it stays black and the mouse cursor works.
Hi friends , some time it will be happening when you laptop will be attack by virus or the mouse will defect.If the mouse will ok, think your laptop already control by virus.Please download F-secure bootable cd or kaspersky bootable CD and write and boot scan through the CD.If your problem will same, please Delete, and create, all partition, through installation proses your XP .
Hope it will you
Dec 17, 2010 | Computers & Internet
I forgot my passcode!
There isn't any actual HACK type thing that will get you your account back but you can get your Passcode deciphered. There are only a certain number of buttons on the 360 controller that are able to be part of the Passcode. Write all the buttons down on a piece of paper and using and organized manner, find every single possibility and try each one until Voila!! You have deciphered your Passcode! I know this may seem like a long, boring, and tedious process but it is the only way, sorry. Hope my advice helped! =)
Jul 05, 2009 | Polaroid PoGo Digital Photo Printer
Blank screen
Possible that the HV inverter or the CFL tubes are going bad / defective. I suggest to bring the unit to an authorized Acer service center for proper check-up / test & fix the problem. regards
May 16, 2009 | Acer X221WSD Monitor
PROBLEMS WITH STARTING IN NORMAL MODE AM LEFT WITH A BLACK SCREEN
You most likely have a problem with your hard disk. It's possible a virus did some damage, or a power surge interrupted it while it was writing to a critical file. You can try connecting a mouse to one of your USB ports and booting into safe mode to do a virus scan but most likely you will save time and trouble by simply re-installing your operating system and reloading all of your software.
Dec 28, 2008 | Acer Computers & Internet
Logitech Wireless mouse stopped working
Logitech cordless devices are designed to always achieve at least 4 feet of good signal. Generally speaking, if you ahve the green light on the connect unit and the batteries are good on your actual mouse then it should work when you perform the synchronization procedure in the manual.
If it is still not working after you re-perform that you should consider relocating your laptop to try again from another environment (any electronic or electrical devices like zip drives, cd drives, etc can cause interferance). try it on a non metallic surface and if possible even try elevating the connect unit a few inches.
If it's still not working, uninstall and reinstall the drivers for your mouse and try again. If after all that it is still not working it's probably a hardware problem and you should contact logitech support for a possible warranty item replacement.
Jun 26, 2008 | Logitech Computers & Internet
Toshiba Satellite Satellite 5200 Series 15 SXGA LCD Display-LQ150F1LH16-P000353350 CD-ROM Drive Logo
44 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
