Car Audio & Video Logo
Posted on Oct 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I store a radio station on my Clarion car radio once I have manually tuned it in?
Benedict Baron
Level 2:
New Friend:
  • Expert 144 Answers
  • Posted on Oct 11, 2010
Benedict  Baron
Expert
Level 2:
New Friend:
Answers
144
Questions
7
Helped
23500
Points
456
Hold in the numeric key you selected for the station for 10sec it will blink and it should be stored
How to program the radio in a 96Lincoln continental after battery was disconnected
Here is the link to the owners manual which you can download if you wish:
http://owner.ford.com/servlet/ContentServer?pagename=Owner/Page/OwnerGuidePage&year=1996&make=Lincoln&model=Continental
Here/below are the specific instructions on the radio programming (pg. 159 of above link).
Good luck & please flag if "HELPFUL". Thanks!
(from section) Luxury Audio System
Selecting the AM or FM frequency band
Push the "AM" or "FM1/FM2" button to select the desired frequency band. Pushing the "FM1/FM2" button more than once will alternate between FM1 and FM2. These functions are used with the station memory buttons described under How to tune radio stations.
HOW to tune radio stations
There are four ways for you to tune in a particular station. You can use the "TUNE", "SEEK", 'SCAN"or memory buttons.
• Using the "TUNE" function:
You can change the frequency up or down one increment at a time by Pressing and releasing either the left (< arrow/up) or - right (> arrow/down) side of the "TUNE" or "TUNE DISCS" button. To change frequencies quickly, press and hold down either the right or left side of the button.
Manual tuning adjusts your radio to any allowable broadcast frequency, whether or not a station is present on that frequency. (See All About Radio Frequencies in this section.)
• Using the "SEEK" function
: Press the right *) side of the "SEEK" button to select the next listenable station up the frequency band. Press the left (.4) side of the button to select the next listenable station down the frequency band. By holding the button down, listenable stations can be passed over to reach the desired station. Pressing the "SCAN" button will begin the scan mode up the frequency band, stopping on each listenable station for approximately five seconds. To stop the scan mode on the presently sampled station, press the "SCAN" button again.
Setting the station MEMORY PRESET buttons
: Your radio is equipped with 6 station memory buttons. These buttons can be used to select up to 6 preset AM stations and 12 FM stations (6 in FMI and 6 in FM2)
1. Select a band, then select a frequency.
2. Press one of the memory buttons and hold until the sound returns and the lamp above the memory button lights up. That
memory button is now set.
3. Follow the above steps for each memory preset button.
NOTE:
Custom memory presets can be recalled using the keyless entry system. See Memory Profile System in the Features chapter.
Using the Automatic Memory Store feature ("AUTOSET")
: If the memory buttons have been set, either by using the Auto Memory Load feature or if you have set them manually, the system is prepared tolet you use a convenient feature called Automatic Memory Store.
With Auto Memory Store, you can continually set strong stations into your memory buttons without losing your originally set stations. Your radio will automatically set your memory buttons to the strong local stations.
Activate Auto Memory Store by pushing the "AUTOSET" button once. Your radio will set the first six strong stations of the band you are in (AM, FMI or FM2) into the memory buttons. The display will flash "AUTO" and display the autoset icon "A" while the stations are being set in the memory buttons.
NOTE: If there are less than six strong stations in the frequency band, the remaining unfilled buttons will store the last strong station detected on the band. After all stations have been filled, the radio will begin playing the station stored on memory button 1.
To deactivate the Auto Memory Store mode and return to the manually-set memory button stations, simply push the "AUTOSET" button. Display will show "AUTO" then "OFF". The next time Auto Memory Store is activated on that band, the radio will store the next set of six strong stations.
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
How to tore radio stations on the u 2471A-G
Most car stereos are the same....Just tune to the station you want, then push and hold the number (1-6) that you want it stored at...Hold it until it either quits blinking or it beeps....Good luck.
1helpful
Unable to find and store radio stations
Go to a web site named clymer mannuals
2helpful
Clarion RAB250D w\casset need to set clock and stations.
While pressing the BAND button, press the DISP button for 2 seconds or MORE to enter the clock editing mode.
To move between the hour and nimute fields, use the left (hour) and right (minute) buttons.
To store the clock setting, press the BAND button.
Also to change between manual tuning and seek tuning press and hold the BAND button for 2 seconds of more. "SRCH" will appear in lower side of display when in search mode.
To preset a station manually press the BAND button to select the band at which to store the station (AM, FM1, FM2, FM3).
Tune to the desired station to be preset
Press and hold the corresponding preset button (1-6) for at least 2 seconds to store the station into memory.
Setting radio stations on clarion auto dbr2475 w magi-tune
try this on most units search the station that you want to save and when its on it press and hold the numbered buttons till it says on the display saved or you hear a tone
Cannot Manually Tune The Radio CLARION DRB4475R CAR CD PLAYER
check your setting on the itrip unit to make sure it is set for frequency
1helpful
Clarion drx9375r tuning radio
To change stations, make sure you are in radio mode(push the FUNC button in upper left corner), and move the 4-way button Left or right. To add station to presets, press and hold preset button until it is saved.
Losing station on cd radio
THAT TYPE OF CONFIGURATION MUST BE OBTAINED FROM THE USER MANUALS
Tunining Radio Stations on a Clarion ADX5555z
Google the model and download the manual.
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
