Turn switch to pilot,push in wait then press igniter but nothing happens
  • 3,287 Answers
Normally, the proceedure is to turn to Pilot, Press & Hold In then press igniter within a few seconds. You should hear a snapping sound as long as you are pressing the igniter button. If not, there is probably an issue with the igniter or even a clogged pilot tube. Neither of these are very expensive repairs, really.
You should contact your gas company or a reputable HVAC or plumbing contractor to get this fixed. Explain the symptoms and ask for a "ball park" price. Realize that unless they can come to the house to diagnose the problem properly, many will not offer a price - or one that they will be obligated to honor - especially if it is not what they expected.
Natural gas and propane leaks are very dangerous and often end badly for those making their own repairs and are not vigilant about checking for leaks.
Posted on Oct 11, 2010
Model mgh-055 furnace. Why won't it light?
Pushing down the button causes enough gas to be fed to the pilot to allow it to be lit and remain burning. If nothing happened, the gas valve could be at fault.
Sep 20, 2015 | Heating & Cooling
Pilot light on furnace went out. how to i re-ignite?
I have experience with coleman furnaces installed in mobile homes. There is a red switch on the gas valve. Some models require you to slide the red switch to the top and hold. Holding is allowing gas to the pilot. You have to stick a long match,grill igniter, to stick through the inspection hole (a little flap or door to see inside the burner area) and hold the match over the pilot while holding the switch upwards at the same time. Others have a pilot selection on the gas valve which you slide the red switch to pilot and push down and hold while liting the pilot. You may need help with holding the door open while doing this. If you can you can use the copper line for the thermocouple to hold the door open for you. Good luck
Jan 15, 2011 | Coleman Heating & Cooling
We have a fairly new heater. went to turn on the pilot light and it won't ignite. what do you think is wrong? gas has been turned on before igniting
Sometimes it takes a few seconds for gas to reach the pilot. When you place the thermostat knob/gas control in the pilot position you must then depress it (push it down and hold it down). Wait a few seconds while holding it down, then press the ignitor button with your other hand while continuing to keep the thermostat knob depressed. You may have to hold the knob down and press the ignitor several times. You should see a spark at the pilot if the ignitor is working properly. Continue to hold the knob down for 30 seconds after the pilot lights, then release the knob, it will pop up & you can then rotate it to lo/med/hi and the heater will come on.,
Dec 02, 2010 | Procom (177653) Utility Heater
The burners will not ignite
if the unit is used you might have to removed the burner and clean the pilot sometimes rust built in the hole and need to be clean out. I had the same problem.
Apr 11, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
My magic chef kitchen range oven won't turn on, no gas
Some of the models require you to push in the oven thermostat knob to set the pilot if it blows out. So try pushing in the knob and hold it while lighting the pilot. When the pilot lights continue to hold the knob in for about a minute. When you let go of the knob the pilot should stay lit. If it does not stay lit then try it one more time. If it continues to go out the thermocouple or aso might be bad and will need service.
Sep 11, 2009 | Magic Chef 31000 Gas Kitchen Range
Bike wont start/crank over
starter solenoid sounds like it jamming knock itaround and
Sep 02, 2009 | 2000 Suzuki SV 650
My heater will not ignite. The pilot is on but
The gasvalve has a pilot solenoid which is powered by in essence a thermocouple called a thermopile which converts heatfrom the pilot to to a millivolt output which is why you have to hold the pilot valve till it makes electricty. The main gas valve goes through a series of safety switches and through the thermostat so if any switch has a badoropen contact the heater will never fire find the bad part with a continuity tester and replace it.
Jul 18, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
I have an older Maytag D8512 with an electric igniter. When I push the start button, nothing happens. I checked the pilot light and it is off. I used a long matchstick to see if I could start the pilo
there is no pilot light. electric igniter will glow and pull amps allowing gas valve to open. if you do not see igniter glow it is bad or thermal fuse has blown. look for 120 volts at the igniter when running. if voltage found bad igniter, if no voltage trace back to fuse/stats.this assumes dryer is actually running. if drum not turning could be a number of things. door switch, fuse, etc
May 24, 2009 | Maytag Dryers
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
