Question about Brother MFC-3240C All-In-One InkJet Printer
Brother mfc -3240c unit
I need a part number for the white part that the ink cartrages plug into,, my unit. the ink runs out into the machine in about 3 min, then i get no ink display.. the clear plastic cover on the bottom of this white part is off the bottom of the ink holder unit
or is there a glue or somethng that would work taht would not melt the parts.. i assume i need to get the sticky tape for the bottom of the asambley. .or a whole assembly..for the ink cartigease to plug into and not leak out. .. thank you for your time. allan gusse
  • a9198d Jun 07, 2008
    i finllay got a ahold of one at brother.. i have a phone number.. they found the part number.the part cost $17.00 plus shipping.. it is called a ink carriage.
    the part is suppose to be improved in design and construction.. i have not received the part yet...
    Novelist:
  • 85 Answers
Hi I have a similar problem with a DPC-111c brother printer. The clear plastic you mention if underneath the cartridge cradle it is designed to act as a canals to feed the print head.
Once damaged... the canals are no longer canals and leak everywhere if this is your case then sorry but your printer is FINISHED !!! Time to buy a new one!
Tinteiros (Ebay)
Posted on May 31, 2008
Mfc-3240c shows ink cartridge missing. I don't need the color so what leads do I short to show a circuit complete?
Simple answer.
You can't, doing so will cause the printhead to fail electronically wich will destroy the machine.
If you only ever print Black and White get yourself a Mono-Laser machine.
Dec 21, 2015 | Brother MFC Office Equipment & Supplies
Where is the absober pad to clean on the Brother MFC-3240c
Hi there
There no easy way the printers are been made this way so you take them to the shop, but if you are handy with your hands and know what you are doing then you will need to take all apart and take out the ink pads inside the printer and clean them up make sure they nice dry when put back in, then you are going to need a program that you can find on the internet it will be called waste reset tools, or your printer will not work even after you done the clean out.
May 08, 2010 | Brother MFC-3240C All-In-One InkJet...
Unable to init.after period of none use
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the error is 48 - defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Nov 23, 2009 | Brother MFC-3240C All-In-One InkJet...
My Brother MFC-3240C printer says unable to clean and to troubleshoot in user's guide but I can't access the guide RCT
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the error is 48 -defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Nov 16, 2009 | Brother MFC-3240C All-In-One InkJet...
I have a brother mfc 3240C. I have changed the
Light/faint prints usually are a result from clogged ink or air bubbles between the cartridge and print head (thus changing cartridge wont fix problem). Try printing the test page print from the machine (Ink Management -> set/ok twice). Answer the question(s) in the display and repeat this up to five times. The colors should be improved after 1-3 test prints usually.
Apr 23, 2009 | Brother Office Equipment & Supplies
Oh brother
I don't think there is a reset procedure for resetting MFC 3240c cartridges.
Professional refill facilities use a code reset device on cartridges.
Users that want to refill their own cartridges often use a piece of cellotape or plastic bag to cover cartridge sensor. This can damage printers head if ink goes too low and printer keeps printing.
My suggestion: stay away from troubles and buy original cartridges.
Here is a link on howto:
Reset ink sensor for Brother MFC 3100C - fixyourownprinter.com
Aug 17, 2008 | Brother MFC-3240C All-In-One InkJet...
Brother MFC 3240C
I had the same problem. It corrected itself when I turned the printer power off and then back on after it went through it's shut down procedure.
Aug 14, 2008 | Brother MFC-3240C All-In-One InkJet...
Brother 3240x
See this page. The models of Brother's cartridges for the MFC-3240C are as follows:
  • black: LC41BK
  • cyan: LC41C
  • magenta: LC41M
  • yellow: LC41Y
Jul 12, 2008 | Brother MFC-3240C All-In-One InkJet...
Brother MFC-3240C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
