Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Not turning on can hear the noise when its starts and then dosent come on also no light on in the bottom left corner
  • 144 Answers
Sounds like power supply problem will have to opened up and inspected
Posted on Oct 11, 2010
A scrapping noise from the bottom left corner.
if its a dryer then you have a bad tub wheel or something got down in the tub inside
Jan 15, 2013 | Washing Machines
OK all i did was turn my computer of by the switch because it was getting real slow and i couldn't do much because of the speed it was going so when i turned it back on it came up with the hp start up with...
You will require a start up/recovery/system disc as the boot sector has been damaged.
If you can get it to boot with a start up disc, run Scandisk to try and recover the sectors. If that doesn't work, reinstall Windows, bearing in mind most XP drivers are now obsolete.
Jan 23, 2011 | HP Computers & Internet
Low level growling noise at rt. front wheel increases with speed. No change if in or out of gear. Can start hearing noise begining about 38 mph. very slight vibration Car has 77,000 miles and is well...
first rotate the tires see if there is a change. If that does not have a desirable effect there may be a worn wheel bearing,take note if the sound or vibration gets louder as you turn a corner, try left turns as well as right turns if the noise increases it is a wheel bearing.
Sep 22, 2009 | 2004 Toyota Camry
Hello my problem is when i try to start the bike with the eletric start the bike dosent start all all . all that happens is that the i hear a buzzing noise coming from behind the tank and the bike dosent...
The starter solenoid is not engaging.or the throughout drive is sticking.If you can hear the starter turning and not engaging,this is the 2 most common problems.Probably a job for an auto electrician.Its not a big problem and easy to fix.Hope this helps
Sep 03, 2009 | Honda NSR 125 Motorcycles
Dosent open
Slide power key to left for 8+ seconds, to re-boot,
try holding for 30+ seconds to calibrate
hole in bottom poss, press hole to reboot,
Hard reset ~( data loss )
hold bottom right corner, while you turn it on, keep pressing until you get the message
" do you want to erase all data " say no to test it.
or, yes if it fails again
Re-register it
Re-update it
If system software missing, check the link
http://www.fixya.com/support/t1891815-garmin_seems_lost_all_its_maps
Regards
Richard.
May 18, 2009 | Garmin nuvi 250W GPS Receiver
T.v. clicking and wont turn on..
Hello:
The loud pop you heard is usually indicative of a failed lamp. The clicking noise you hear is likely the ballast trying to turn the lamp on.
If you need assistance with a new lamp, please feel free to contact us at www.dlplampsource.com or 866-764-5822.
Regards
Dan
Apr 12, 2009 | Mitsubishi WD-65731 65" HDTV
I have a rca tv model d52w17 chassis # D416c30WC.
sounds like the flyback if your talking about the lower left when looking at the rear of the set.
Apr 12, 2009 | RCA HD52W59 HDTV Projection Television
I hit a bump on the right front side and it makes a roaring type noise and shimmies a bit .. can feel it under my left foot. also at times it will make that soud when i make a right hand turn... it is ...
Sounds like your left front wheel bearing is going bad. When you make a right turn, or compress the right front suspension over a bump, it forces the car to roll to the left. This loads the suspension on the left side, which will exaggerate a wheel bearing problem. Are you hearing the noise at all when travelling on the highway in a straight line? If so, it'd be either a grinding sound or a hollow humming noise. If you aren't, it may be that the bearing is just starting to go bad.
A quick test to see if the bearing is bad is to jack the car up at that corner, grab the wheel at the top and bottom, and shake it hard - if there is any movement or looseness, your bearing is shot. If there is none, it doesn't mean the bearing is fine, but it could be that it's just starting to go bad (which would be why you only hear it in turns and bumps, but not straight-line yet).
Aug 01, 2008 | Chevrolet Avalanche Cars & Trucks
Saeco vienna deluxe
Try this:
  1. Power on the machine
  2. Open the door and look up to the right corner, you will see a little hole.
  3. Take a screw driver and put in the hole, now take another and put in the hole down in the left corner.
Now you shold hear the machine give little noise, if not it can be the micro switch in the left corner that has to be replaced.
If you open the steam knob, can you hear the pump start?
Hope this will help you.
Jul 26, 2008 | Saeco Vienna De Luxe Espresso Machine
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
19 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
