Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
No internet connection.
When I connect my modem directly to my computer I can connect to the internet, but when I connect from the modem to the router then to my computer I have no internet connection.
  • 1 more comment
  • Anonymous Jun 01, 2008
    same problem no internet connection
  • Matthew Menke Jun 04, 2008
    I got it fixed, I called dlink for support and it ended up being a software problem. Thanks for trying, very appreciated.
  • thatfingguy Jun 13, 2008
    I have the same problem, i cannot connect to the internet once i connect the router. I was wondering if it's because i have vista? I' ve tried cycling the power and so on. Is it a software problem?
Login on http://192.168.0.1 then on the left hand side click
on wireless settings go to the network name of your router
(SSID) type in your last name save then go to the
network and diagnistics then find your network name and
connect
Posted on Jul 15, 2008
Login to your router (default address is "http://192.168.0.1/" (default username = "admin" and default password = "" (blank))). Then click on "Manual Configure", scroll down and click on "Clone MAC Address".
I hope this works for you too.
Posted on Jun 04, 2008
  • 66 Answers
Try power cycling... turn off all devices -- modem, router, computer...
turn on modem then wait 2 minutes, turn on router then wait about 2 minutes, then turn on pc...
make sure you have the right connections... modem to router (internet port) then router port to pc...
Posted on Jun 02, 2008
SOURCE: configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
Posted on Aug 05, 2007
  • 173 Answers
SOURCE: NetGear wireless router model wpn 824 v2
  1. Then u have to setup ur router first
  2. Turn off the power on your computer.
  3. Securely connect an end of an Ethernet cable to your computer, as shown.
  4. Securely connect the other end to any of the router's four LAN ports.
  5. Connect a second Ethernet cable from the router's single WAN port to the modem.
  6. Make sure the modem is connected to the jack or cable to the Internet that was set up by your ISP.
    1. Start your network in this order:
      1. Turn the modem power off.
      2. Turn the router power off.
      3. Turn the modem power back on. Wait two minutes until the lights are stable.
      4. Turn the router power back on. Wait one minute until the lights are stable.
      5. Turn the computer power back on.
    2. Open an Internet browser, and type http://192.168.0.1. If a "Configuration Assistant" appears immediately, then do not follow the rest of these instructions. Follow the Configuration Assistant instructions, instead. Once you are finished, test your Internet connection by browing online, for example to http://kbserver.netgear.com.
    3. Type admin for User Name, and password for Password. (Older routers use 1234 as the password.)
    4. Click OK. This logs you into the router.
    5. Click Setup Wizard, on the left of the router settings page and set up your router
    6. that would fix your problem..
Posted on Nov 16, 2007
peglegcards
  • 89 Answers
SOURCE: L2TP connection problem
Hello, I've had the electric cut off and immediately back on and I lost my connection from Wireless router to modem. I could not connect in the same way. I could access the router settings with wireless laptop and PC but not to internet on either. I bypassed the router and connected the PC computer to modem then to internet verifying with a browser. I then reconnected the computer cable back to router and router to modem. It stayed connected. But I'm not sure if you have a PC connected to the router also. Sometimes just unplugging some cables and replugging will solve problems. Hope this helps.
Posted on Feb 19, 2008
serra_baby
  • 144 Answers
SOURCE: zhone linksys router
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
i have read the same problem on the supportrix forum and you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router and repeat the same steps.
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username (email address format) and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
Posted on Aug 07, 2008
mfg_bong
  • 35 Answers
SOURCE: Router not connecting to internet modem
Pls specify
-Who is the Internet service provider?
Posted on Oct 04, 2008
L cannot get internet when connected to my router, but l get internet when connected to modem directly.
Your ISP allows only one device to connect to their network.
When you change devices (router versus computer),
you need to power-off the ISP's modem, and unplug it.
Connect the router to the modem, and connect your computer to your router.
Plug the modem back in, and the modem will "forget" what device was previously connected.
Feb 18, 2015 | BestPriceCables TP-LINK Ultimate 300Mbps...
How to connect to the internet
Connect the computer directly to the modem and make sure that Internet is working through the modem.
Connect the modem and computer to the router with the Ethernet cable.
Open the setup page of the router and change the settings manually. So that your computer can access Internet through the router.
You can this website to know how to connect to the Internet using NETGEAR router.
May 21, 2012 | NetGear WGR614 Wireless Router
The signal is strong but there's no connection to internet
I have this problem sometimes. If you lose connection to the modem, you can't connect back to it, you have to reset the modem. Goto the modem, unplug it, wait 10 seconds, then plug it back in. Goto your connections, select yours, disconnect and then reconnect, wait a few seconds and it should connect. Hope this helps, let me know if it does or doesn't.
May 14, 2010 | NetGear WGR614 Wireless Router
Moved router to connect directly to the Comcast modem that also provides VOIP. Comcast activated modem and internet works when computer is connected directly to Comcast modem. Router does not connect to...
Your ISP should have given you the following information...
Static IP, Internet IP Address, Subnet Mask, Gateway, Static DNS 1-3.
With that information at hand, follow tis link to the router user manual and go to Page 11 of the manual to go through the step by step process of setting the router up for an internet connection.
http://downloads.linksysbycisco.com/downloads/WRT54GX2v2_ug,1.pdf
Nov 26, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Cannot get to the internet using this router ...does it need to be connected directly to a computer? we have it connected to the modem
For the initial set up of the router , the computer should be connected to the router.
Once you set up the router then you can use it wireless.
Are you able to go online when connected to the modem.
Click Here to know more about network and router
Oct 25, 2009 | Linksys Wireless-G WRT54GS Router...
I have an ADSL D-Link modem (DSL-300G)that works fine. I hooked a D Link wired router, EBR-2310 and can't get to the internet. It use to work until one day recently the kid moved wires arround because no...
First: Connect your computer directly to the ADSL modem. It has an Ethernet port.
If you can't get to the Internet while your computer is connected directly to the modem, then ytour router never will either. Call ISP if you can't connect to the Internet when directly conencted to the modem.
Next: Check your router wires again, The modem must be connected to the "special" port on the router. Look at the router. There is one port separated from the rest. Connect the modem to that port. Conenct to the Internet.
Still no Internet?
Reset your router by pushing a stylus (straightened-out paperclip) into the reset "hole" on the router (with router powered ON).
Push & hold for 30 seconds or until the lights do their reset dance. Connect to the INternet.
Oct 07, 2009 | D-Link 4-Port Ethernet Broadband Router...
I have two computers that I want to share my cable internet connection. When connected directly to the modem the first computer conects to teh internet fine. But when I connect the computer to my Belkin...
Perhaps one of your ethernet cables is bad?
When everything is connected, the "WAN" light on your router should go on, as well as the lights for whatever network connections your are using for your computer.
Obviously the cable that you used to connect your computer directly to the modem is working, so try replacing the other one.
Sep 05, 2008 | Belkin Computers & Internet
The network is working but I can't get the internet
If the internet is not working first thing to check here is the internet connection from your modem without the router, make sure that your computer can access the internet when computer is connected directly to modem, if no internet without the router you need to contact your ISP for that, but if there's internet without the router you need to reset and reconfigure the router.....if you have the setup CD of the router just run that to reconfigure it back.........
Aug 12, 2008 | Linksys WRT54GL Wireless-G 54Mbps...
My Roadrunner Modem works fine when connected to an individual computer. When connected through my netgear modem I cannot get an internet connection on any computer wired directly to the router
does the modem worked fine with ANY computer connected directly to it, or just ONE computer connected to it?
did you have to install a connection program on one of your computers when you first installed the modem?
do you have an account name and password from your internet service provider, which is required to connect?
Mar 24, 2008 | NetGear WGR614 Router
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
314 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
