Question about Goodman CLQ36AR49 Air Conditioner
The Inner Fam Will Not Stop Turning And Continues To Blow Un Cooled Air
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. Make sure the fan switch on the thermostat is set to auto to turn the indoor blower off. If its the outside unit that will not shut off take the cover off the thermostat and disconnect the y wire and see if the outside unit shuts off. If the unit doesn't shut off then pull the cover to the outside unit and check to be sure that the contactor is not welded shut not allowing the outside unit to shut off.
Posted on Oct 11, 2010
Tip
Projector Beep Alerts
When a projector beeps on power up you have a couple things to be concerned about. If the projector is hot, the beeps can mean that it needs longer to cool down.
If you have not used the projector for several hours then it is cooled down. When cold, the beep alerts usually mean the blower fan bearing is restricted.
Clean the air filter and blow out the fan housing. You should just blow with your mouth because compressed air may damage your wiring connections.
If the projector is cleaned and you power it back up AND the beeps continue listen to the fan. The fan may need a little air pressure to help it start turning and then once it does the beeps should stop.
on Jun 21, 2010 | Audio Players & Recorders
Burners light but ignition keeps clicking
use a blow drier to dry the igniter and knobs.
May 21, 2014 | Jenn-Air Kitchen Ranges
1996 Buick Riviera Cooling fan won't shut off. we
COOLING FAN IS CONTROLLED BY COOLANT TEMPERATURE SENSOR (CTS). REMOVE THE CONNECTOR FROM IT AND IT SHOULD STOP THE FAN.
OR JUST REMOVE BATTERYGROUND CABLE.
ITEMS TO CHECK OUT :
CTS,RELAY,CIRCUIT FOR SHORTS.
NOT LIKELY BUT IS A POSSIBILITY, THR ECU.
Jun 09, 2010 | 1996 Buick Riviera
Water will not stop when level is reached but starts next cycle
If the water will stop when you turn the washer off then the problem is the water level switch. It's a switch connected to a hose which goes between the inner and outer tub. You can blow on it and the water should cut off. The filling water puts pressure on the switch with the air in the hose.
If the water doesn't stop when you cut the washer off then the water inlet valve is probably stuck open. The water supply hoses on the back connect to the valves.
Aug 22, 2009 | Washing Machines
Hot Air Blast
this is the probleme with luxury cars ...the venting systheme works with vacum and some thime smal electris motor ...if one is broken or a hose craked ...this kind of stuff appens not much to do but to take the under dash apart and look for the problem, it could also just need a little lubrification on all the moving parts !
Jul 21, 2009 | 1995 Mercedes-Benz E-Class
Over heating
clean the dust out of it. blow it out with canned air. the dust keeps in the heat that the projector is trying to expel.
Apr 22, 2009 | Office Equipment & Supplies
1991 Honda accord
I would suggest checking to make sure your electric fan(s) are turning on. When you are moving they may be enough air flowing through the radiator to cool it enough not to run extremely hot, but as soon as you stop and the air stops it heats up. Check the fan(s) to see if they turning on. If not, check the fuse block ad see if the fuse or relay for the fan is bad. Hope this helps.
Mar 13, 2009 | 1987 Honda Accord
Ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
May 02, 2007 | Amana PTH123B25AJ Heat Pump Air...
Goodman CLQ36AR49 Air Conditioner Logo
135 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
