Question about Home
How do I use a conair thermal spa mbts2nw - Home
Conair hair dryer 1002axa stopped working
The thermal cut-out on hair dryers is usually self-resetting, the device will restore power once the unit cools down... Most of these types of problems are due to lint clogging the air intake and causing overheating, be sure to clean the intake before attempting a repair.
May 23, 2016 | Dryers
What is the watts of this machine?
not a clue but try looking on Google for make model and specs.
Jun 18, 2015 | Conair MBTS15 Ultimate Thermal Spa Bath...
How do I sanitize a foot spa
run a bleach solution thru it. be sure to rinse it well after wards.
Feb 15, 2015 | Conair Relaxing Foot Spa
Conair steamer green light comes on but low water beeps. water full.
How To Use The Conair® Deluxe Fabric Steamer
www.conair.com/how-to-use-the-conair-reg-deluxe-f...
Conair CorporationThe Conair® Deluxe Fabric Steamer (model # GS11DR) conveniently rolls to any spot in your ... This unit comes with a rotating hanger. ... The switch will light to indicate when power is on. ... Note: If the low water indicator lamp becomes illuminated but the water tank is not empty, follow the instructions for decalcification.
[PDF]Instruction Booklet - ExtremeSteam® Upright ... - Conair
www.conair.com/.../gs95_13pa140688_ib_final.pdf
Conair CorporationMar 1, 2013 - ... water only. 8. Plug the steamer unit into a standard 120V AC power outlet. 9. ... Push button on T-nozzle - light will go on and steam will start.
Customer Reviews: Conair Extreme Steam Fabric Steamer ...
Aug 16, 2013 | Irons
Need an operator/how to manual for the Conair Body Benefits Bubbling Foot Spa
If you know the model number you can type it in on the website just to the right for the user manual:
http://www.conair.com/cnt_ib.php?action=filter&type=category
But this one seems closely related to what you have so it might work just as well as guide:
http://www.conair.com/cnt_ib.php?action=download&id=980
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Health & Beauty
Manuel for model #pb5 hand/wax therapy .Lost manuel.
google it or email the company i am sure they will help
Jan 23, 2011 | Conair Home Spa Kit For Hands And Feet...
Hot tub pump stops and control panel says there is a flo problem
Yes a pump does have a thermal cut out. When the motor gets too hot the thermal cut out will activate and the pump won't restart until the motor has cooled.
If you were an electrician, or highly confident/competent with electrics, you could test the motor with a volt meter. Run the spa and as soon as the pump stops running, check the voltage at the pump. If there is voltage at the pump, then the thermal cut out on the motor has activated. Do not try checking this yourself if you're not competent to do so.
You could also do the same test at the spa pack if it's easier to do so, just locate the output to the pump.
What spa and which spa pack have you got?
Cheers,
Ian.
Apr 24, 2017 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Home Logo
43 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
