LG tromm washer has trouble code E1 - Washing Machines
SOURCE: LG Washer
brilliant! I had the same problem with the same symptoms so i ordered the hall sensor from mcm as well put it in and $17.70 + s&h later my machine is purring like a kitten once again thanks guys D.
Posted on Jan 21, 2008
rickzilla
  • 706 Answers
SOURCE: LE Error Code on Tromm
http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf page 18 of this service manual elaborates on the LE error code and what to check.. Hope this helps you..
Regards
Posted on Sep 20, 2008
  • 8 Answers
SOURCE: LG TROMM CLOTHES WASHER - "LE" ERROR CODE
I tried a solution I found elsewhere - worked great. I had turned my drum enough to cause the display to turn on (a glitch in their program, I think), then I got the LE code on the next cycle.
Unplug for 10 minutes. Turn back on and press the Rinse & Spin button, then set Spin Speed to No Spin. Run this cycle, which should work fine. Afterwards, you should be able to run your machine as normal. If this doesn't work, replacing the Hall sensor would be the next step.
Posted on Feb 28, 2009
SOURCE: LG Tromm washer WM2077CW reading code LE
LE means "Overload in Motor" Unplug the washer, remove clothes, wait 15 minutes for motor to cool down. try again. If problem persists you'll need a certified technician.
Posted on May 31, 2009
  • 5 Answers
SOURCE: LG Tromm washer WM2688HWM tE error code. Very easy
LG Tromm Washing machine te error. The manual says to call for service. Not much help there. The reason for the error is the thermistor circuit (resistive element that becomes less resistive as it increases in temperature). The thermistor acts as a heat sensor. In many cases, the error occurs because the wireing harness is too tight at the bottom of the drum and one of the wires in this circuit becomes disconnected with all of the movement of the drum (unbalanced load, normal cylcing etc).
1. Unplug the washing machine from the wall. The thermistor circuit is at line voltage (110 in the U.S.) and it will bite! So do this first before proceeding.
2. Move the washer out so you can get access to the back of it.
3. Remove the stainless panel (the one that is not painted, it is large (aprox. 16x18 inches). It is held in place by 4 phillips screws.
4. Locate the thermistor connection block near the bottom of the machine, at the center of the wash drum. It is the small white connector that has two wires running to it. One wire is dark blue, the other is light blue. Insure that neither wire has pulled out of the connector. If either of them have, repair the connector and provide enough extra wire ( aprox. 2") to provide cable relief.
5. If the cable connector and wires are ok, there are other solutions here that recommend either cleaning or replacing the thermistor.
Good luck to you.
Posted on Aug 04, 2009
I have LG ,Tromm washer machine front load have problem. Door is not closing completely .
The "dE" error code indicates that the LG Tromm washer's door has not been properly closed. Closing the door firmly usually clears this error. If the error does not go away once the doors closed, a service technician should be consulted.
Jun 03, 2011 | LG WM-2277HW Front Load Washer
I have an LG Tromm washer. I start it up it start
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jul 25, 2010 | LG WM0642H Front Load
An OE light comes on and the washer won't drain
I had something similar. It turned out that one of the option keys was stuck in an "in" position (did not jump back out after it was pressed) which disabled the functions of all the other keys. The lights in main dial came on but it was not possible to do anything else.
Jul 22, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm wm 1814cw makes loud noise
You will need to remove the back cover plate of the machine and locate the large pulley at the end of the drum. Remove the belt, then the pulley and you should see a bearing housing. Some models require a bearing and housing replacement, while others can simply be repaired with a bearing replacement alone.
Go here, and find the nearest Dealer for your part.
http://www.1stsourceparts.com/contact_us/branch_info.asp
Or you can try ordering direct from LG. If you are as handy with tools as you say, this should be a fairly easy job.
Mar 23, 2010 | LG WM1814CW Front Load Washer
Getting an E1 error code
It should be the 1E error code. LG standard is xE indicating a code followed by E for error. Except in the cae of power failure which is indicated by PF.
E1 means inadequete water supply. This can be cause by a kinked hose in the back of the machine (going to the hot or cold water supply). A water valve (at your hookup connection) that is not fully open, or a clogged filter in the inlet hose.
Insure the valves are completely open on the wall behind the washer, and that the lines connecting to the washing machine are not kinked coiled tightly. If neither of these are the problem, shut off the water valves and disconnect the water lines from the machine and wall and insure that the screens in the hose are clear.
Good luck to you.
Jul 03, 2009 | LG WM2688HWM TROMM SteamWasher
How to acces the diagnostic code an a new lg tromm washer
The codes should be in the manual
au.lge.com
Go to this site and download the pdf file for your
model
Jun 13, 2009 | LG WM2688HWM TROMM SteamWasher
LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Jun 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
382 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
