Question about Asrock K7VT4A-Pro Motherboard
Asrock K7VT4A-Pro Motherboard with 1TB SATA harddisk. BIOS doesn't pick the disk up. It works fine with a 500GB SATA disk. I've tried flashing the BIOS to the latest version but this doesn't help. Any other ideas short of new motherboard or standalone SATA controller?
5 Suggested Answers
SOURCE: Does Asrock P4VM8 support 500GB SATA hard disks?
me pasa exactamente la misma guevonada
Posted on Sep 05, 2008
pogiboi
  • 85 Answers
SOURCE: P4P800SE and 1TB USB harddisk
thas a conflick to the loading system....
Posted on Apr 05, 2009
romsky79
  • 822 Answers
SOURCE: ASRock P4VM890 SATA HDD NOT ROCOGNIZED
enable sata1 and sata2 from bios. make sure motherboard is supported by sata.
Posted on May 30, 2009
  • 1027 Answers
SOURCE: I am using Asrock 775VM800 Motherboard with 80GB
There should be a jumper on the hard drive to select between 3G and 1.5G speeds. It appears that your MB only supports the 1.5G speed.
Posted on May 15, 2010
P4i45gv motherboard hard disk capacity
You can still buy a 1tb hard drive for those,however the cost is more than you can replace the MB and HDD with the newer sata format.
cost wise a 500gb or less .
Aug 22, 2014 | Asrock 845GV (P4I45GV) Motherboard
My asrock k7vt4a-pro motherboard did not detect IDE hard disk whats the problem
The disk has died and everything on it is lost. Junk it and install a new one.
Jul 07, 2010 | Asrock K7VT4A-Pro Motherboard
Hi my computer have problem in starting. few days
Disconnect the power from the diskette-drive, from the disk-drive, and from the CD/DVD devices. Then, try to start your computer.
If it still fails, then try a different power-supply.
Dec 08, 2009 | Asrock K7VT4A-Pro Motherboard
I have the 500GB Deskstar SATA HDD. I am running XP Pro. I have flashed the bios to version 1.80 (the latest) No-where in the POST screen or the Bios screens is a SATA drive recognised. Likewise,...
Hi john25090,
Have you gone into Bios and made sure the Bios is reading the drive? If not you can sometimes manually tell Bios that the drive is there and then the rest will see it.
Try that first.
Good Luck
Mark
Nov 21, 2009 | Asrock K7VT4A-Pro Motherboard
Sata on k7vt4a-pro. wont boot into windows with any dvd drive in sata plug.does motherboard support sata dvd drives
not usually No.
You need to setup the Pc with an IDE drive First. Then load The Sata drivers, usually on the setup CD. ( obtained with motherboard )
Alternative, is to create a SATA/Raid boot Disk et,c.
Mike @ compurepair.
Nov 04, 2009 | Asrock K7VT4A-Pro Motherboard
My sata Dvd Writer 22xsuper-writermaster SH-223 is not bootable
Try pressing F12 at splashscreen (compaq splashscreen) and it will give you bootable options. Choose DVD drive.
If that doesn't work, press F2 (bios options) and change the bootable disk drives. The DVD should be the first, followed by the hard drive and then the floppy next.
Reboot and your PC will tell you to press any key to boot from CD.
Sep 12, 2009 | Asrock K7VT4A-Pro Motherboard
near the interface port of the hard drive you have to put a jumper that limit the connection speed from 3.0giga per second to 1.5giga per second, I think that would solve the problem because the hard drive speed goes to 3 giga per second and the motherboard p4vm8 serial ata port can support up to 1.5giga per second.
Jun 23, 2008 | Asrock P4VM8 Motherboard
1 TB HD of Samsng is not recognized
some motherboards and processors are compatiable with certain hd's only. Here is a list:
Pentium: 2GB through 5GB
Pentium 2:5GB through 20GB
Pentium 3: 20GB through 40GB
Pentium 4: 40GB through 500GB
Pentium D: 40GB through 1TB
Celeron: 2GB through 500GB
All AMD's: 300MB to whatever.
so, that's probably your problem. I suggest
Jun 05, 2008 | Asrock K7VT4A-Pro Motherboard
Device Manager shows VIA SATA RAID Controller with Yellow "!"
same problem.....for help contact dragosdogaru1985 yahoo messenger
May 27, 2008 | Asrock K7VT4A-Pro Motherboard
Asrock K7VT4A-Pro Motherboard Logo
368 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
