Question about Dell Dimension 3000 PC Desktop
Error: Page_Fault_in_Nonpaged_Area My Dell PC keeps pop up a blue window with"Page_Fault_In_Nonpaged_Area" and it auto freeze the system. How do i fix this problem or how to disable BIOS memory, caching and shadowing? thanks
    Guru:
  • 1,342 Answers
Click HERE for an explanation of this error and what to do about it.
Posted on May 31, 2008
Page in fault in nonpaged area
you have a faulty RAM. try switching it with a new one, it should solve your problem
May 23, 2017 | Acer Aspire One Netbook
I have a dell xps m140, when I turn on the computer I get a blue screen with the message, STOP: c000021a {FATAL SYSTEM ERROR} the windows logon process system process terminated unexpectedy without...
Hi
You do not say which operating system you are using.
A blue screen can have many causes, so you need to undertake an elimination process to identify the cause.
Most importantly, do not repeatedly keep trying to boot if blue screen keeps appearing, as this could lead to hasrdware failure. It is important to identify and fix the fault as soon as possible.
If you read the full error message, there will usually be an indication of the likely cause of the crash as well as some suggested remedies.
Typical causes are:
Conflict with newly installed software
Driver conflict or corruption
Malware infection
Insufficient Hard Drive space
Operating system corruption
Hard Drive fault
Overheating
Memory corruption
Graphics card fault
Each of these will have a different remedy.
Start by studying the error message in more detail, try the suggested remedy options, then post again with more specific information, if necessary.
Hope this helps.
Aug 22, 2011 | Dell Inspiron XPS M140 Notebook
Having trouble playing a game .game will start but two minutes into the game will get a blue screen stating a problem has been detected and windows has been shut down. message: the problem seems to be...
This is a problem with the drivers for your motherboard video. You need to download and install the latest intel video drivers from your PC Manufacturer. Intel has "locked" them so you can only use the ones from your OEM PC Vendor.
Apr 17, 2011 | Computers & Internet
Windows xp quit loading blue screen says page-fault-in-nonpaged-area tech info ***stop:0x00000050(oxc9464269,0x00000000,0x870e208c,0x00000000)
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set frist boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windwos " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Jan 08, 2010 | Microsoft Windows XP Home Edition
Where should I look in the computer (Dell dimension 8400) for the problem windows shuts down and a blue screen error message saying page fault in a non page area.
Hi friend,
You need to check your ram in your computer.. i think your RAM is not good running...so try to change then ram ...then it will work..
Jan 06, 2010 | Dell Dimension 8400 PC Desktop
Dell Lat d620 duo: ran a full system scan yesterday as I normally do for maintenance and got the BSOD. Message: page fault in nonpaged area. Tried all options to reboot, always eventually gets to BSOD and...
Take out the memory and replace with the old one.
If you have a 32 bit Windows and have more that 4GB RAM then you need to upgrade to 64 BIT.
This is the RAM you need:
Standard Memory : 256MB (Removable) Maximum Memory : 2GB Total Memory Slots : 2 Memory Type : DDR2 533MHz (PC2-4200) 200-PIN SODIMM Notes :
http://orcamemory.com/asp/prodtype.asp?prodtype=11759&ft=m
Jan 06, 2010 | Dell Latitude D620 Notebook
Lap top computer
Sounds to me like a windows problem or maybe a driver error. if it boots up in safe mode and it dont boot up in regular mode, one of the drivers that dont have to load in safe mode keeps crashing it. check all startup programs and disable as many as you can
Oct 18, 2009 | Computers & Internet
Page fault in nonpage area
Restart the Computer and keep tapping the F8 key for 5 to 7 seconds to display the Advanced Boot Option screen. On that screen, select "Last Known Good Configuration" option. Furthermore, if you've installed any new hardware then uninstall it.
Once the Computer is able to boot successfully, run "chkdsk /f /r" utility to detect and repair any disk errors.
Faulty hardware, a buggy system service, anti-virus software, and a corrupted NTFS volume can all generate this type of error.
Aug 29, 2009 | Computers & Internet
Blue Screen with various STOP error messages appearing.
This is a tough one to troubleshoot since there are several issues which can result in this error. Let me start by listing known causes.
Corrupt pagefile.sys file
Corrupt or wrong drivers for system devices. printer, camera, ect.
Corrupt program drivers, adobe elements, capture card software.
Bad System Ram Modules.
You didn't specify if you installed anything new, hardware or software but to trouble shoot this issue begin by download Memtest86. This will test your system boards memory for errors.
If your ram passes the test you might try removing other devices such as printers and its software. Testing the issue after each uninstall.
Last you can try replacing system files or performing a system repair using your operating system cd. If you need to run the repair option and need help just post back here.
Hope this helps.
Apr 07, 2009 | Dell Computers & Internet
Dell Dimension 3000 PC Desktop Logo
201 people viewed this question
Alun Cox
