Question about Arris SURFboard SB5120 Modem
Dropping connection I also had no problems until my cable company was bought out. Then my system started to drop signal. Literally every 5 - 10 minutes. I have to unplug the modem for 30 sec. to reestablish connection or restart the computer. I have had the cable company check the hard line and they say signal is good. The modem is a sb5120 Surfboard. The system is a dual Pentium 4 and the hook up is usb and acting as network host. Here is my connection info Downstream Value Frequency 597000000 Hz Signal to Noise Ratio 36 dB QAM QAM256 Network Access Control Object ON Power Level -2 dBmV The Downstream Power Level reading is a snapshot taken at the time this page was requested. Please Reload/Refresh this Page for a new reading Upstream Value Channel ID 5 Frequency 32000000 Hz Ranging Service ID 8173 Symbol Rate 2.560 Msym/s Power Level 48 dBmVThanks for any help you can give,
  • Anonymous Jul 17, 2008
    i have the same problem
  • Anonymous Aug 24, 2008
    i have 5101 and 5120. both modems do the same thing they will work for a while then they will stop. unplug the power from the modem a few times and eventually it will work again for awhile. went to 192.168.100.1, every thing looks ok till i read the log. trouble codes d103 and d003. does anyone know how to read the logs?
Replace your modem. I had the same issue. Replacing the modem solved everything.
Posted on Sep 19, 2008
Netgear D7000 modem keeps dropping offline
Cordless phones, microwave ovens and wireless surveillance cameras between the modem and the device will do it. If it's hard wired to the computer, the signal strength from the phone company may be low. Call the phone company to have them come out and test the signal level that is applied to the modem.
Sep 21, 2016 | NetGear Computers & Internet
Why does it keep loosing Wi-Fi connection?
I
is your wireless connection dropping? - We Rock Your Web
www.werockyourweb.com > Tech > Troubleshooting
Jun 22, 2014 - The symptoms are a wireless connection that literally will drop out .... the 5th router is wireless CPE AP, wifi signal keep droppings all the time I ...
WiFi problems! Keep losing connection! - Tom's Hardware
www.tomshardware.com/.../wifi-problems-losing-...
Tom's Hardware Guide
Nov 15, 2015 - 9 posts - ‎5 authors
Ok so for some reason ever since we got a new modem and router my HP laptop willhave a full connection and all of a sudden ill lose it and my wifi says "No Networks available" and a red X appears by my bars at the bottom. ... I dont know if maybe my network adapter is going bad or ...
A fix for my Windows 8
Jan 04, 2016 | Tablets & eReaders
Cooling system
Raise the car front end as high as possible with a floor jack, fill the coolant tank to the top, run the engine until it reaches just short of overheating, shut it down and run water over the radiator, this will burp the air out. Repeat as needed. Don't let the coolant recovery tank run dry during procedure.
Aug 31, 2012 | 2000 Jeep Cherokee 2WD
Video Telconferencing drops at various times
If you changed providers I bet they forgot to provide disconnect signal on your lines.
This signal is sent to your system from the provider when a calling party hangs up and is transferred to VM.
A good tech with his phone should be able to see this while on monitor. You will need a system tech to verify this. Most likely it's the provider.
Typically between 450 and 900 ms. The higher the better.
Apr 05, 2010 | Inter-Tel Axxess Corded Phone
Bought a NetGear WPN111 RangeMax Wireless USB 2.0 Adapter a few months ago. It was working fine up until a few days ago. It started dropping my internet connection, and now it won't even detect any...
Hi
firstly you can try upgrading the drivers on the adapter. following is the link for the latest drivers http://kb.netgear.com/app/answers/detail/a_id/12520
If the problem still persists
try changing the wireless settings on the wireless router.
Nov 12, 2009 | NetGear WPN111 RangeMax Wireless USB 2.0...
Signal drops out, displays "No Signal"
My best guess is the signal to the Cable box. It is not a hardeware problem if you replaced the box it has to be the cable signal. Loose connections are sometimes the problem.
Nov 08, 2009 | Daewoo DP42SM 42 in. HD-Ready Plasma...
My Belkin N1 router can't seem to establish connection with the cable modem - the router light flashes and connects but as the internet light flashes it loses the router light again. It is still allowing...
the modem is working fine. the connection might be dropping from the router side.
You can try to upgrade the Firmware of the router.
reduce the MTU on the router. If it is on 1500 the reduce it to 1400.
Click Here from more info about routers
Oct 31, 2009 | Belkin (F5D8231-4) Wireless Router...
My internet connection keeps dropping every 2 minutes!!
That particular series of HP computers has a recall with an extended warranty for just this problem. Call HP, they will have you go through all the first line cures but tell them you know of the extended warranty for lost wireless problems. They'll replace the mother board. Make sure you back up all your data when you send it in. I've sent them nearly a dozen and some they reformatted the hard drives.
Apr 27, 2009 | HP Pavilion dv4000 Notebook
Poor signal bush hd set top box
I have a saterllite reciver just bought a bush hd freesat top box i am running my virgin cable tv through my samsung hd television i put my satallite cable in to my bush top box connect the hdmi cable to get the freesat turn my virgin box off source the hdmi cable on tv get the freesat logo but nothing else what am i doing wrong
Aug 31, 2008 | Televison & Video
Losing connection
I assume this is a cable modem? You need to call your cable company and have a trouble ticket created. I worked for the cable company installing cable for quite a while and I bet my paycheck the signal getting to the modem are below specs and that's why the modem gets dropping the internet connection.
Hope this helps.
Aug 13, 2008 | Arris SURFboard SB4100 Modem
Arris SURFboard SB5120 Modem Logo
605 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
