Question about Garden
I have a Troy Bilt pressure washer with a pin-hole leak where the manifold attachs to the pump unit. Can I just back-off the fasteners, scrape the old gasket off and replace with liquid automotive gasket maker, rather than replace the entire pump unit?
  • 760 Answers
Most likely the piston seals are leaking This is a good thing as since it leaks out it is keeping the water from entering the drive mechanism. If you can find the PUMP brand and model you can get parts fromm a place like www.pressure-washer-parts.com . The parts are inexpensive for just the seals before you ruin the complete pump.When replacing thee seals, you might as well replace the pump packing too since they wear. If you cannot find the pump numbers, then get the Troy Bilt model number and check their web site for parts. http://www.troybilt-gen-pw.com/pressure_washers/ They have parts listed there but i think they only list the complete pump not pump repair parts.
Posted on Oct 12, 2010
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
How to fix power washer with no pressure with out have to buy the hole pump what can i do to fix it
Cover soap inlet and retry. Mine will not pressurize without soap or without inlet covered.
Jul 22, 2014 | Annovi Reverberi Garden
Power washer wont pump
Call us when you can be at the washer so we can trouble shoot it with you over the phone.
http://www.ppe-pressure-washer-parts.com/troy-bilt-020416-1-pressure-washer-parts
Mar 20, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Change oil in Troy Bilt 020245 pressure washer pump
underneath base of motor look for a plug wuth a square slot,i normally use a 3/8" extension with ratchet.
Aug 20, 2013 | Troy-Bilt Troy - Bilt 020245 Pressure...
Change oil in Troy Bilt 020245 pump
if it,s a vertical motor it's at the base of motor look for a plug with a square slot.
Pressure Washer Troy Bilt 2700 PSI 2.3 GPM will not pick up soap. I am using the black tip low pressure head and it still does not pick up the detergent. Any recommendations?
Take the small soap line off and make sure you can blow air through. Where the line attaches to the soap container make sure the hole is clear if not take a streight pin and make sure the pin goes in the hole easily.
Mar 14, 2011 | Garden
Replacing manifold on troy bilt pressure washer
I was able to forcefully push it back until it clicked.
Jun 07, 2010 | Karcher 2500 PSI Pressure Washer
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
Troy bilt pressure washer 2200 psi
inlet valve connected to water inlet is stopped-up. Unscrew it, take a safety pin run through valve then take the pin and push through valve connected to pump. should do the trick. (the valve the suction hose for the soap is connect to)
Mar 31, 2008 | Washing Machines
Garden Logo
247 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
