Question about Hurst 1630051 White Sidewinder Shifter Knob
NEED THE INSTALLTION INSTRUCTIONS FOR A HURST 3 SPEED INDY SHIFTER
    New Friend:
Need installation guide for a 3 speed Huster Indy shifter.1964 chevy C10 truck.327 ci motor.The problem is is has been installed but the gears are reversed.Revrse is left and back 1st left and up.2nd is right and back,3rd right and up.
Posted on Oct 08, 2013
1968 FR100 pickup stuck in 2ed gear 3 speed manual aqny ideas besides replacing it ?
The pressure plate needs to be replaced...when working this allows the clutch to disengage, so you can manually change gears...Hope this helps.
Jul 06, 2012 | Ford Cars & Trucks
Shifter Rattles
was the flywheel turned or replaced and how was the pilot bearing ?
Jan 03, 2018 | 1972 Chevrolet Corvette
Hi guys. i have a 1956 chevy with a three on the tree shifter. it has an overdrive also do you make a floor shifter i can retro-fit ? thank you.
Generally speaking - a three on the tree would indicate a three speed manual trany and OD would suggest an automatic. If it is a manual trany - hurst used to make a floor shift kit for the chevy tri-fives - I put them in my '57 chevys when I was a teen. (Bought my first '57 for $25)
Nov 23, 2010 | Hurst 1630051 White Sidewinder Shifter...
The threads brock off the shifter lever that hold the shifter knob on. what is the true name of this part and what is the part number. it is a 1995 Jeep Cherokee Sport 4.0L strait 6. 5 speed manual...
you need a shifter its one piece what you are looking at goes into the top of the transmission with 4 bolts you are better off getting a short throw from b&m or hurst for about 200.00 try 4wd hardware.com or quadratec.com or ebay you will spent that much from dealer and the short throw is way better !
Aug 14, 2010 | 1995 Jeep Cherokee
Dual gate Hurst shifter adjustment
Hello! Here is what I was able to track down:
Hurst Dual Gate Shifter Assembly Parts Breakdown:
Removing & Replacing The Hurst Dual/Gate
1. Disconnect car battery.
2. Remove Knob. Remove four Phillips head screws that hold escutcheon plate down to console.
NOTE: SHORT SCREW IS USED IN REAR RIGHT - HAND HOLE. Remove escutcheon plate and console from floor tunnel.
3. Lift selector indicator lamp housing out of shifter and pull bulb socket out of lamp housing. Disconnect wire connectors from combination Back - up light / Neutral safety switch.
4. Remove two 1/4 - 20 x 1/2 hex-head cap screws that fasten Dual / Gate shifter to rear mounting bracket. Remove 1/4 - 20 x 1/2 hex - head cap screw that holds cable bracket to shifter frame. Remove two #10 - 32 x 3/8 slotted head cap screws that fasten Dual / Gate shifter to front bracket. Free shifter from cable by removing cotter pin and washer.
5. Remove combination Neutral - safety / and Back - up light switch. Install switch on Replacement unit.
6. Install replacement shifter unit in reverse order of removal of original unit.
7. ADJUST CABLE: SEE FIGURE 1 (Below)
Loosen nut that fastens cable pin to transmission control arm. Loosen nut enough to allow pin to slide in the slot in the arm. Turn the arm to NEUTRAL position. Move the stick to NEUTRAL. Tighten the adjusting nut. Test movement of stick and check to be sure that stick positions agree with transmission control operation.
8. SEE FIGURE 2 (Below)
Connect car battery. Apply hand brake. Move stick to NEUTR AL position. Press foot on brake pedal. Start engine. If starter fails to operate, Neutral Safety switch must be adjusted. Adjustment is made with a long-bladed Phillips screwdriver through the "Street" gate. This screw is directly in front of the st ick. Turn the screw about 1/2 turn past the point where starter operates. (STICK MUST REMAIN IN "NEUTRAL" WHILE ADJUSTMENT IS MADE). Starter should operate ONLY when stick is in PARK or NEUTRAL position.
Hope this helps and thanks for using FixYa!
Oct 22, 2009 | Pontiac GTO Cars & Trucks
most gm nuet safety is yellow and purple .....out of ignition switch is a big yellow wire that is crank out and input to nuet saf switch......out of nuet switch is color purple that goes strieght to start selenoid.....purple wire also goes to the crank fuse 5amp.. in the fuse box under dash... this fuse goes to the pcm main computer.. same for auto and clutch
Sep 04, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
I have lost my book for installing #501-0016
Call Hurst here to see if they can fax, mail or email you a manual. here is there #'s
818 483-1366 or Fax 818 882-6694. Ask for customer service.
Good Luck and Please Rate FixYa!
Feb 23, 2009 | Hurst Electrical Supplies
Hurst 1630051 White Sidewinder Shifter Knob Logo
241 people viewed this question
Top Hurst Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Hurst Electrical Supply Expert? Answer questions, earn points and help others
