Question about Video Game Consoles & Games
Have described this problem 3 times now!!!! - Video Game Consoles & Games
    Novelist:
    Champion:
  • 210 Answers
Whats the problem?
I will try and help...!
Cheers
Posted on Jun 04, 2008
I have a Hyundai accent 2005. Bought it 3 months ago. Every time i push the gas pedal, it makes a noise. Noise is not too bad, but what could it be? Please help
would you describe the noise 1 metallic/scrapping, 2 slight roar ,3 squeal, 4 something else
1,loose drive belt pulleys, something may have dropped onto driven parts
2. loose or worn air intake hose , air filter box not secured
3. alternater etc drive belts , spray WD40 onto them when revving engine , if squeal goes check condition of belts
4. can you describe it
hope this gives you a starting point
Jul 08, 2015 | 2005 Hyundai Accent
Customer care service
Open monitor and look at power supply board for capacitors which are "balooning" or deformed in any way. These look like cylindars on the board. These tend to dry out and make what you are describing occur. Replacing them usually fixes about 80% of the problem you are describing. Those parts run about $0.25 to $0.75 each.. well worth trying, right?
Jan 30, 2014 | ViewSonic Computers & Internet
Menu does not come up on screen
One hit is all you need....three hits do as you describe. Be patient and wait for the 1st tap to work.
Feb 17, 2013 | Keurig Single Cup Coffee Maker B77
Can t time it
1) Copy following link for analog timers:
http://waterheatertimer.org/How-to-set-timers.html
2) Use google translate for foreign language.
http://translate.google.com/
3) Add comment and describe timer.
Dec 12, 2012 | Hardware & Accessories
This is a dual time watch and the minute hands are not in sync. How do I open the crown on this model to access the hands.
It honestly depends on the model. If the model is a dual movement model, there is usually a crown at the 3:00 and 9:00 positions on the case. You would want to:
1) Pull each crown out when the second hand is at 12:00, if there is no second hand, then the minute hand should be over the next 1-2 minutes for proper syncing.
2) go to: http://www.time.gov/ , select the proper time zone(s) that you would like to sync to.
3) Count down to the next minute time change, and simultaneously press in the crowns on both sides, engaging the hands to the movement.
If this is a different model than what I have described, please describe the watch brand, model, and buttons / features that you see, and I am happy to help!
Feb 04, 2011 | Watches
I have a 1997 323i 2.5 the engine sometimes idles erratically and lacks power or hesitates in acceleration
Hello my solution is have your ignition timing checked your symptoms described fits incorrect ignition timing.Most garages will check and set your ignition timing for a set rate,
Jan 06, 2011 | 1994 BMW 3 Series
Set the clock for current time, but lights come on 3 hours before the on tripper.
You posted under T103 Intermatic timer
Add a comment if you have different brand.
Current time lines up with silver pointer.
Sounds like silver pointer is not at 6:00 position
Review timer operation:
T-103 timer dial rotates around until tripper contacts mechanical lever:
On tripper pushes lever one direction until it clicks, OFF tripper pushes lever other direction.
Each time lever clicks into position, manual-override lever also moves back and forth.
Manual override is connected to same lever that trippers push.
Troubleshoot:
Watch if timer functions as described above.
Click manual override and check that lights turn on-off correctly.
Add a comment if timer is doing something other than described.
Nov 16, 2010 | Intermatic T103 Indoor 120-Volt 40-amp...
How to re program remote locking key on a 2000 ford
On most vehicles, pressing the lock and unlock buttons at the same time for 3-5 seconds will hand shake the systems.
Oct 11, 2009 | 2000 Ford Focus
Describe your Husqvarna "Chain Saw -
Remove the spark plug and test for spark. If ok, try some starting fluid in the plug hole, install the plug, and try to start. If it runs a short time, it is not getting fuel. Check fuel lines including inside the tank. Clean or replace the air filter. If this saw is fairly old, the carburetor probably needs a re-kit and cleaning. Does it have good compression? Check the muffler for plugging. Make sure the fuel/oil mix is fresh. Good luck!
Sep 12, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Red Light Blinks 3 times
that models plagued with bad capacitors 1000uf and above the problem you describe is 2 bad capacitors on the PWV board if you would like more information you can go to this link they have service manuals,parts and experts online for these tv's leave them an e-mail with your model number and problem and they will help you I have used this sight many many times myself
http://servicemanuals.vstore.ca/
May 10, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Video Game Consoles & Games Logo
16 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
