Question about Car Audio & Video
Ineed a digram to change the timing belt on an 05 Jeep Liberty 2.8 crd.
  • 17,970 Answers
2005 Jeep Liberty 4WD 2.8L Turbo Diesel 4cyl
Fig. Typical drive belt automatic tensioner wear indicator
  1. Disconnect negative battery cable.
  2. Rotate belt tensioner until it contacts its stop. Remove belt, then slowly rotate the tensioner into the free arm position.
To install:
  1. Check condition of all pulleys.
    CAUTION When installing the serpentine accessory drive belt, the belt MUST be routed correctly. If not, the engine may overheat due to the water pump rotating in the wrong direction.
  2. Install new belt. Route the belt around all pulleys except the idler pulley . Rotate the tensioner arm until it contacts its stop position. Route the belt around the idler and slowly let the tensioner rotate into the belt. Make sure the belt is seated onto all pulleys.
Timing Belt - Removal & Installation 2.8L Engine
  1. Before servicing the vehicle, refer to the Precautions section.
    WARNING Before removing the timing belt, the engine must be placed at 90° after TDC. Failure to do so may result in valve and/or piston damage during assembly.
  2. Disconnect negative battery cable.
  3. Remove engine cover.
  4. Remove cooling fan and fan drive viscous clutch assembly.
  5. Remove accessory drive belt.
  6. Remove cooling fan support.
  7. Remove vibration damper.
  8. Bring piston #1 to TDC, turn crankshaft until the witness line on the crankshaft hub is at the 12 o-clock position.
  9. Looking at the engine from the belt side, rotate the crankshaft 90° clockwise so the witness mark is now at the 3 o-clock position.
  10. Remove the alternator.
  11. Remove the intake and exhaust camshaft plugs from the camshaft cover, to introduce the camshaft timing pins VM.1052 Intake, and VM.1053 Exhaust (if the engine is timed correctly, the pins can be installed flush with the intake manifold/cylinder head cover).
  12. Remove timing belt outer cover.
  13. Loosen timing belt tensioner and remove timing belt.
  14. Remove the intake and exhaust camshaft alignment pins.
  15. Loosen camshaft gears using special tool VM 1085 to retain the gears when loosening the bolts.
  16. Remove special tool VM 1085.
    Fig. Timing belt and sprockets-2.8L diesel engine
    Fig. Injection pump gear timing marks-2.8L diesel engine
    Fig. Timing belt routing-2.8L diesel engine
    Fig. Timing belt tensioner adjustment-2.8L diesel engine
To install:
NOTE There are marks on both camshaft gears. These ARE NOT alignment marks and should be disregarded.
  1. With both camshaft alignment pins still installed and the engine rotated at 90° after TDC, verify that the camshaft gears are loose.
  2. Align the timing mark on the high pressure injection pump gear with the timing mark on the inner cover.
    NOTE DO NOT remove the timing belt from the package until it-s ready to be installed. DO NOT expose timing belt to oil, grease or water contamination. DO NOT crimp belt at a sharp angle. DO NOT clean belt, pulleys or tensioner with solvent. Check that pulleys and bearings are not seized or damage before installing belt.
  3. Install timing belt on crankshaft hub.
  4. Route the belt around high pressure injection pump, idler pulley, intake camshaft gear, exhaust camshaft gear, idler pulley, and water pump gear.
  5. Adjust the timing belt tensioner (turn it clockwise) using special tool VM.9660, lining up the center notch with the aluminum cover dowel pin. Tighten the retaining bolt to 20 ft. lbs. (28 Nm).
  6. Install special tool VM.1085 between camshaft gears and tighten thumb screws to engage and retain the camshaft gears.
  7. Tighten the camshaft gear bolts to 80 ft. lbs. (108 Nm) while holding the gears with special tool VM 1085.
  8. Remove camshaft gear locking tool.
  9. Remove intake and exhaust alignment pins.
    WARNING If intake manifold/cylinder head cover was removed wait 30 minutes before rotating crankshaft.
  10. Rotate the engine clockwise 2 revolutions (looking at engine from the belt side).
  11. With the crankshaft hub witness mark aligned to 90 degrees ATDC, or the 3 o-clock position, check that the intake and exhaust camshaft alignment pins (VM 1052 and VM 1053) can be installed into the camshaft alignment access holes.
  12. Install timing belt outer cover.
    WARNING If the camshaft alignment pins can not be installed at this time, repeat the procedure from the beginning.
  13. Install the camshaft access plugs.
  14. Install vibration damper.
  15. Install the alternator.
  16. Install cooling fan support.
  17. Install accessory drive belt.
  18. Install cooling fan and fan drive viscous clutch assembly.
  19. Install engine cover.
  20. Connect negative battery cable.
Hope helps; keep us updated.
Posted on Oct 11, 2010
Where is the camshaft position sensor on a jeep liberty 2.5 crd. car doesnt start show fault code p0340
on the right side of the engine block near the front engine mount for a four-cylinder engine
Apr 30, 2014 | 2002 Jeep Liberty
No power.
What color is the smoke?
White,blue or grey?
Please post the color of smoke on reply.
Use a bottle of yellow HEET dry gas to remove any moisture problem in the fuel.
Clean / replace air filter.
Top off ATF to MAX level.
Use starting fluid to aid starting.
Jan 16, 2014 | 2005 Jeep Liberty
Our 2005 Jeep Liberty pulls right when accelerating and pulls left when we let up on the accelerator - hit the gas again and pulls right again. When maintaining speed It drives straight and true
I have the exact same problem with my 05 CRD, thought it was the motor or tranny mounts but both are in excellent condition. The problem started just after turning 100,000 mi. I don't have the answer, just wanted to let you know that you are not alone on this issue, hopefully someone will post a solution soon!
May 14, 2011 | 2005 Jeep Liberty
I need a 2005 jeep Liberty CRD serpentine belt diagram and which of nine pullies to place the belt on first
belt snapped?, some have diagram under hood, look yet?
ok , i guess you dont have the FSM?
and want us to read ours. is that it>?
https://www.techauthority.com/en-US/Pages/Home.aspx
The USA JEEP LIBERTY IS KJ
that year.
2.8L CRD engine, serp
page 9-165 FSM
Nov 23, 2010 | 2005 Jeep Liberty
Liberty Jeep 2002 at what milage do I change the timing belt?
First does it have a belt ore a chain and most newer one recomend at like 60k ore 90. If got a chain it stretch and you will not get great gas milage but it will not break like a belt
Jul 26, 2009 | 2002 Jeep Liberty
2005 jeep liberty with 2.8lt diesl engine.
THE CRD DIESEL 2.8 LITER ENGINE WHICH IS MADE IN ITALY HAS A TIMING BELT.
Jul 24, 2009 | 2005 Jeep Liberty
EGR Location
On the left side at the rear of the engine, and it isn't fun to change.
May 29, 2009 | 2005 Jeep Liberty
2003 jeep cherokee 2.8 CRD engine sqeeking noise
It could be that you got some water on your serpentine belt and that will cause it to squeak. Try buying a can of "belt dressing" from an auto store and spray it all over your belt and see if that will stop it. It's a cheap and easy thing to try before replacing expensive parts. Hope this works for you, let me know how it goes. Goodluck!
May 05, 2009 | 2003 Jeep Liberty
Car Audio & Video Logo
4,863 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
